Errore download firmware MarlinKimbra con Arduino July 28, 2016 05:01AM |
Arduino:1.6.9 (Windows 8.1), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\Configuration_adv.h:529:0,
from sketch\Configuration.h:613,
from F:\Davide backup\Windows\Documenti\Stampante 3D\Firmware & configurations\MarlinKimbra_mod\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z.ino:31:
sketch\conditionals.h:238:0: warning: "DRIVER_EXTRUDERS" redefined [enabled by default]
#define DRIVER_EXTRUDERS EXTRUDERS // This defines the number of Driver extruder
In file included from F:\Davide backup\Windows\Documenti\Stampante 3D\Firmware & configurations\MarlinKimbra_mod\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z.ino:31:0:
sketch\Configuration.h:76:0: note: this is the location of the previous definition
#define DRIVER_EXTRUDERS 1
In file included from sketch\conditionals.h:253:0,
from sketch\Configuration_adv.h:529,
sketch\pins.h:5447:0: warning: "X_MAX_PIN" redefined [enabled by default]
#define X_MAX_PIN -1
In file included from sketch\pins.h:5440:0,
from sketch\conditionals.h:253,
sketch\pins2tool.h:59:0: note: this is the location of the previous definition
#define X_MAX_PIN ORIG_X_MAX_PIN
sketch\pins.h:5453:0: warning: "Y_MAX_PIN" redefined [enabled by default]
#define Y_MAX_PIN -1
sketch\pins2tool.h:61:0: note: this is the location of the previous definition
#define Y_MAX_PIN ORIG_Y_MAX_PIN
sketch\pins.h:5459:0: warning: "Z_MAX_PIN" redefined [enabled by default]
#define Z_MAX_PIN -1
sketch\pins2tool.h:63:0: note: this is the location of the previous definition
#define Z_MAX_PIN ORIG_Z_MAX_PIN
from sketch\Marlin.h:25,
from sketch\ultralcd.h:4,
from sketch\ultralcd.cpp:1:
In file included from sketch\Marlin.h:25:0,
In file included from sketch\ultralcd.cpp:4:0:
sketch\language.h:230:0: warning: "MSG_WATCHDOG_RESET" redefined [enabled by default]
#define MSG_WATCHDOG_RESET "Something is wrong, please turn off the printer."
sketch\language.h:93:0: note: this is the location of the previous definition
#define MSG_WATCHDOG_RESET " Watchdog Reset"
In file included from sketch\language.h:246:0,
sketch\language_en.h:69:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
#define MSG_MIN " "LCD_STR_THERMOMETER " Min"
sketch\language_en.h:70:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
#define MSG_MAX " "LCD_STR_THERMOMETER " Max"
sketch\language_en.h:71:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
#define MSG_FACTOR " "LCD_STR_THERMOMETER " Fact"
In file included from sketch\language.h:259:0,
sketch\language_it.h:20:0: warning: "WELCOME_MSG" redefined [enabled by default]
#define WELCOME_MSG MACHINE_NAME " pronta."
sketch\language_en.h:20:0: note: this is the location of the previous definition
#define WELCOME_MSG MACHINE_NAME " ready."
sketch\language_it.h:21:0: warning: "MSG_SD_INSERTED" redefined [enabled by default]
#define MSG_SD_INSERTED "SD Card inserita"
sketch\language_en.h:21:0: note: this is the location of the previous definition
#define MSG_SD_INSERTED "Card inserted"
sketch\language_it.h:22:0: warning: "MSG_SD_REMOVED" redefined [enabled by default]
#define MSG_SD_REMOVED "SD Card rimossa"
sketch\language_en.h:22:0: note: this is the location of the previous definition
#define MSG_SD_REMOVED "Card removed"
sketch\language_it.h:23:0: warning: "MSG_MAIN" redefined [enabled by default]
#define MSG_MAIN "Menu principale"
sketch\language_en.h:23:0: note: this is the location of the previous definition
#define MSG_MAIN "Main"
sketch\language_it.h:25:0: warning: "MSG_DISABLE_STEPPERS" redefined [enabled by default]
#define MSG_DISABLE_STEPPERS "Disabilita Motori"
sketch\language_en.h:25:0: note: this is the location of the previous definition
#define MSG_DISABLE_STEPPERS "Disable steppers"
sketch\language_it.h:26:0: warning: "MSG_AUTO_HOME" redefined [enabled by default]
#define MSG_AUTO_HOME "Auto Home"
sketch\language_en.h:26:0: note: this is the location of the previous definition
#define MSG_AUTO_HOME "Auto home"
sketch\language_it.h:35:0: warning: "MSG_SET_HOME_OFFSETS" redefined [enabled by default]
#define MSG_SET_HOME_OFFSETS "Setta offset home"
sketch\language_en.h:35:0: note: this is the location of the previous definition
#define MSG_SET_HOME_OFFSETS "Set home offsets"
sketch\language_it.h:36:0: warning: "MSG_SET_ORIGIN" redefined [enabled by default]
#define MSG_SET_ORIGIN "Imposta Origine"
sketch\language_en.h:36:0: note: this is the location of the previous definition
#define MSG_SET_ORIGIN "Set origin"
sketch\language_it.h:37:0: warning: "MSG_PREHEAT_PLA" redefined [enabled by default]
#define MSG_PREHEAT_PLA "Preriscalda PLA"
sketch\language_en.h:37:0: note: this is the location of the previous definition
#define MSG_PREHEAT_PLA "Preheat PLA"
sketch\language_it.h:38:0: warning: "MSG_PREHEAT_PLA_ALL" redefined [enabled by default]
#define MSG_PREHEAT_PLA_ALL "Prer. PLA Tutto"
sketch\language_en.h:38:0: note: this is the location of the previous definition
#define MSG_PREHEAT_PLA_ALL "Preheat PLA All"
sketch\language_it.h:39:0: warning: "MSG_PREHEAT_PLA_BEDONLY" redefined [enabled by default]
#define MSG_PREHEAT_PLA_BEDONLY "Prer. PLA Piatto"
sketch\language_en.h:39:0: note: this is the location of the previous definition
#define MSG_PREHEAT_PLA_BEDONLY "Preheat PLA Bed"
sketch\language_it.h:40:0: warning: "MSG_PREHEAT_PLA_SETTINGS" redefined [enabled by default]
#define MSG_PREHEAT_PLA_SETTINGS "Config. prer. PLA"
sketch\language_en.h:40:0: note: this is the location of the previous definition
#define MSG_PREHEAT_PLA_SETTINGS "Preheat PLA conf"
sketch\language_it.h:41:0: warning: "MSG_PREHEAT_ABS" redefined [enabled by default]
#define MSG_PREHEAT_ABS "Preriscalda ABS"
sketch\language_en.h:41:0: note: this is the location of the previous definition
#define MSG_PREHEAT_ABS "Preheat ABS"
sketch\language_it.h:42:0: warning: "MSG_PREHEAT_ABS_ALL" redefined [enabled by default]
#define MSG_PREHEAT_ABS_ALL "Prer. ABS Tutto"
sketch\language_en.h:42:0: note: this is the location of the previous definition
#define MSG_PREHEAT_ABS_ALL "Preheat ABS All"
sketch\language_it.h:43:0: warning: "MSG_PREHEAT_ABS_BEDONLY" redefined [enabled by default]
#define MSG_PREHEAT_ABS_BEDONLY "Prer. ABS Piatto"
sketch\language_en.h:43:0: note: this is the location of the previous definition
#define MSG_PREHEAT_ABS_BEDONLY "Preheat ABS Bed"
sketch\language_it.h:44:0: warning: "MSG_PREHEAT_ABS_SETTINGS" redefined [enabled by default]
#define MSG_PREHEAT_ABS_SETTINGS "Config. prer. ABS"
sketch\language_en.h:44:0: note: this is the location of the previous definition
#define MSG_PREHEAT_ABS_SETTINGS "Preheat ABS conf"
sketch\language_it.h:45:0: warning: "MSG_PREHEAT_GUM" redefined [enabled by default]
#define MSG_PREHEAT_GUM "Preriscalda GOMMA"
sketch\language_en.h:45:0: note: this is the location of the previous definition
#define MSG_PREHEAT_GUM "Preheat GUM"
sketch\language_it.h:46:0: warning: "MSG_PREHEAT_GUM_ALL" redefined [enabled by default]
#define MSG_PREHEAT_GUM_ALL "Preri. GOMMA Tutto"
sketch\language_en.h:46:0: note: this is the location of the previous definition
#define MSG_PREHEAT_GUM_ALL "Preheat GUM All"
sketch\language_it.h:47:0: warning: "MSG_PREHEAT_GUM_BEDONLY" redefined [enabled by default]
#define MSG_PREHEAT_GUM_BEDONLY "Preri. GOMMA Piatto"
sketch\language_en.h:47:0: note: this is the location of the previous definition
#define MSG_PREHEAT_GUM_BEDONLY "Preheat GUM Bed"
sketch\language_it.h:48:0: warning: "MSG_PREHEAT_GUM_SETTINGS" redefined [enabled by default]
#define MSG_PREHEAT_GUM_SETTINGS "Config. prer. GOMMA"
sketch\language_en.h:48:0: note: this is the location of the previous definition
#define MSG_PREHEAT_GUM_SETTINGS "Preheat GUM conf"
sketch\language_it.h:49:0: warning: "MSG_COOLDOWN" redefined [enabled by default]
#define MSG_COOLDOWN "Raffredda"
sketch\language_en.h:49:0: note: this is the location of the previous definition
#define MSG_COOLDOWN "Cooldown"
sketch\language_it.h:50:0: warning: "MSG_SWITCH_PS_ON" redefined [enabled by default]
#define MSG_SWITCH_PS_ON "Accendi aliment."
sketch\language_en.h:50:0: note: this is the location of the previous definition
#define MSG_SWITCH_PS_ON "Switch power on"
sketch\language_it.h:51:0: warning: "MSG_SWITCH_PS_OFF" redefined [enabled by default]
#define MSG_SWITCH_PS_OFF "Spegni aliment."
sketch\language_en.h:51:0: note: this is the location of the previous definition
#define MSG_SWITCH_PS_OFF "Switch power off"
sketch\language_it.h:52:0: warning: "MSG_EXTRUDE" redefined [enabled by default]
#define MSG_EXTRUDE "Estrudi"
sketch\language_en.h:52:0: note: this is the location of the previous definition
#define MSG_EXTRUDE "Extrude"
sketch\language_it.h:53:0: warning: "MSG_RETRACT" redefined [enabled by default]
#define MSG_RETRACT "Ritrai"
sketch\language_en.h:53:0: note: this is the location of the previous definition
#define MSG_RETRACT "Retract"
sketch\language_it.h:54:0: warning: "MSG_MOVE_AXIS" redefined [enabled by default]
#define MSG_MOVE_AXIS "Muovi Asse"
sketch\language_en.h:54:0: note: this is the location of the previous definition
#define MSG_MOVE_AXIS "Move axis"
sketch\language_it.h:56:0: warning: "MSG_MOVE_X" redefined [enabled by default]
#define MSG_MOVE_X "Muovi X"
sketch\language_en.h:56:0: note: this is the location of the previous definition
#define MSG_MOVE_X "Move X"
sketch\language_it.h:57:0: warning: "MSG_MOVE_Y" redefined [enabled by default]
#define MSG_MOVE_Y "Muovi Y"
sketch\language_en.h:57:0: note: this is the location of the previous definition
#define MSG_MOVE_Y "Move Y"
sketch\language_it.h:58:0: warning: "MSG_MOVE_Z" redefined [enabled by default]
#define MSG_MOVE_Z "Muovi Z"
sketch\language_en.h:58:0: note: this is the location of the previous definition
#define MSG_MOVE_Z "Move Z"
sketch\language_it.h:59:0: warning: "MSG_MOVE_E" redefined [enabled by default]
#define MSG_MOVE_E "Estrusore"
sketch\language_en.h:59:0: note: this is the location of the previous definition
#define MSG_MOVE_E "Extruder"
sketch\language_it.h:60:0: warning: "MSG_MOVE_01MM" redefined [enabled by default]
#define MSG_MOVE_01MM "Muovi di 0.1mm"
sketch\language_en.h:60:0: note: this is the location of the previous definition
#define MSG_MOVE_01MM "Move 0.1mm"
sketch\language_it.h:61:0: warning: "MSG_MOVE_1MM" redefined [enabled by default]
#define MSG_MOVE_1MM "Muovi di 1mm"
sketch\language_en.h:61:0: note: this is the location of the previous definition
#define MSG_MOVE_1MM "Move 1mm"
sketch\language_it.h:62:0: warning: "MSG_MOVE_10MM" redefined [enabled by default]
#define MSG_MOVE_10MM "Muovi di 10mm"
sketch\language_en.h:62:0: note: this is the location of the previous definition
#define MSG_MOVE_10MM "Move 10mm"
sketch\language_it.h:63:0: warning: "MSG_SPEED" redefined [enabled by default]
#define MSG_SPEED "Velocità "
sketch\language_en.h:63:0: note: this is the location of the previous definition
#define MSG_SPEED "Speed"
sketch\language_it.h:64:0: warning: "MSG_NOZZLE" redefined [enabled by default]
#define MSG_NOZZLE "Ugello"
sketch\language_en.h:64:0: note: this is the location of the previous definition
#define MSG_NOZZLE "Nozzle"
sketch\language_it.h:65:0: warning: "MSG_BED" redefined [enabled by default]
#define MSG_BED "Piatto"
sketch\language_en.h:65:0: note: this is the location of the previous definition
#define MSG_BED "Bed"
sketch\language_it.h:66:0: warning: "MSG_FAN_SPEED" redefined [enabled by default]
#define MSG_FAN_SPEED "Ventola"
sketch\language_en.h:66:0: note: this is the location of the previous definition
#define MSG_FAN_SPEED "Fan speed"
sketch\language_it.h:67:0: warning: "MSG_FLOW" redefined [enabled by default]
#define MSG_FLOW "Flusso"
sketch\language_en.h:67:0: note: this is the location of the previous definition
#define MSG_FLOW "Flow"
sketch\language_it.h:68:0: warning: "MSG_CONTROL" redefined [enabled by default]
#define MSG_CONTROL "Controllo"
sketch\language_en.h:68:0: note: this is the location of the previous definition
#define MSG_CONTROL "Control"
sketch\language_it.h:69:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
sketch\language_it.h:70:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
sketch\language_it.h:71:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
sketch\language_it.h:82:0: warning: "MSG_ACC" redefined [enabled by default]
#define MSG_ACC "Accel."
sketch\language_en.h:82:0: note: this is the location of the previous definition
#define MSG_ACC "Accel"
sketch\language_it.h:86:0: warning: "MSG_VMAX" redefined [enabled by default]
#define MSG_VMAX "Vmax"
sketch\language_en.h:86:0: note: this is the location of the previous definition
#define MSG_VMAX "Vmax "
sketch\language_it.h:93:0: warning: "MSG_AMAX" redefined [enabled by default]
#define MSG_AMAX "Amax"
sketch\language_en.h:93:0: note: this is the location of the previous definition
#define MSG_AMAX "Amax "
sketch\language_it.h:103:0: warning: "MSG_TEMPERATURE" redefined [enabled by default]
#define MSG_TEMPERATURE "Temperatura"
sketch\language_en.h:103:0: note: this is the location of the previous definition
#define MSG_TEMPERATURE "Temperature"
sketch\language_it.h:104:0: warning: "MSG_MOTION" redefined [enabled by default]
#define MSG_MOTION "Movimento"
sketch\language_en.h:104:0: note: this is the location of the previous definition
#define MSG_MOTION "Motion"
sketch\language_it.h:105:0: warning: "MSG_VOLUMETRIC" redefined [enabled by default]
#define MSG_VOLUMETRIC "Filamento"
sketch\language_en.h:105:0: note: this is the location of the previous definition
#define MSG_VOLUMETRIC "Filament"
sketch\language_it.h:106:0: warning: "MSG_VOLUMETRIC_ENABLED" redefined [enabled by default]
#define MSG_VOLUMETRIC_ENABLED "E in mm³"
sketch\language_en.h:106:0: note: this is the location of the previous definition
#define MSG_VOLUMETRIC_ENABLED "E in mm3"
sketch\language_it.h:107:0: warning: "MSG_FILAMENT_SIZE_EXTRUDER" redefined [enabled by default]
#define MSG_FILAMENT_SIZE_EXTRUDER "Diam. filo"
sketch\language_en.h:107:0: note: this is the location of the previous definition
#define MSG_FILAMENT_SIZE_EXTRUDER "Fil. Dia."
sketch\language_it.h:108:0: warning: "MSG_CONTRAST" redefined [enabled by default]
#define MSG_CONTRAST "Contrasto LCD"
sketch\language_en.h:108:0: note: this is the location of the previous definition
#define MSG_CONTRAST "LCD contrast"
sketch\language_it.h:109:0: warning: "MSG_STORE_EPROM" redefined [enabled by default]
#define MSG_STORE_EPROM "Salva in EEPROM"
sketch\language_en.h:109:0: note: this is the location of the previous definition
#define MSG_STORE_EPROM "Store memory"
sketch\language_it.h:110:0: warning: "MSG_LOAD_EPROM" redefined [enabled by default]
#define MSG_LOAD_EPROM "Carica da EEPROM"
sketch\language_en.h:110:0: note: this is the location of the previous definition
#define MSG_LOAD_EPROM "Load memory"
sketch\language_it.h:111:0: warning: "MSG_RESTORE_FAILSAFE" redefined [enabled by default]
#define MSG_RESTORE_FAILSAFE "Impostaz. default"
sketch\language_en.h:111:0: note: this is the location of the previous definition
#define MSG_RESTORE_FAILSAFE "Restore failsafe"
sketch\language_it.h:112:0: warning: "MSG_REFRESH" redefined [enabled by default]
#define MSG_REFRESH "Aggiorna"
sketch\language_en.h:112:0: note: this is the location of the previous definition
#define MSG_REFRESH "Refresh"
sketch\language_it.h:113:0: warning: "MSG_WATCH" redefined [enabled by default]
#define MSG_WATCH "Guarda"
sketch\language_en.h:113:0: note: this is the location of the previous definition
#define MSG_WATCH "Info screen"
sketch\language_it.h:114:0: warning: "MSG_PREPARE" redefined [enabled by default]
#define MSG_PREPARE "Prepara"
sketch\language_en.h:114:0: note: this is the location of the previous definition
#define MSG_PREPARE "Prepare"
sketch\language_it.h:115:0: warning: "MSG_TUNE" redefined [enabled by default]
#define MSG_TUNE "Adatta"
sketch\language_en.h:115:0: note: this is the location of the previous definition
#define MSG_TUNE "Tune"
sketch\language_it.h:116:0: warning: "MSG_PAUSE_PRINT" redefined [enabled by default]
#define MSG_PAUSE_PRINT "Pausa"
sketch\language_en.h:116:0: note: this is the location of the previous definition
#define MSG_PAUSE_PRINT "Pause print"
sketch\language_it.h:117:0: warning: "MSG_RESUME_PRINT" redefined [enabled by default]
#define MSG_RESUME_PRINT "Riprendi Stampa"
sketch\language_en.h:117:0: note: this is the location of the previous definition
#define MSG_RESUME_PRINT "Resume print"
sketch\language_it.h:118:0: warning: "MSG_STOP_PRINT" redefined [enabled by default]
#define MSG_STOP_PRINT "Arresta Stampa"
sketch\language_en.h:118:0: note: this is the location of the previous definition
#define MSG_STOP_PRINT "Stop print"
sketch\language_it.h:119:0: warning: "MSG_CARD_MENU" redefined [enabled by default]
#define MSG_CARD_MENU "SD Card Menu"
sketch\language_en.h:119:0: note: this is the location of the previous definition
#define MSG_CARD_MENU "Print from SD"
sketch\language_it.h:120:0: warning: "MSG_NO_CARD" redefined [enabled by default]
#define MSG_NO_CARD "No SD Card"
sketch\language_en.h:120:0: note: this is the location of the previous definition
#define MSG_NO_CARD "No SD card"
sketch\language_it.h:121:0: warning: "MSG_DWELL" redefined [enabled by default]
#define MSG_DWELL "Sospensione..."
sketch\language_en.h:121:0: note: this is the location of the previous definition
#define MSG_DWELL "Sleep..."
sketch\language_it.h:122:0: warning: "MSG_USERWAIT" redefined [enabled by default]
#define MSG_USERWAIT "Attendi Utente..."
sketch\language_en.h:122:0: note: this is the location of the previous definition
#define MSG_USERWAIT "Wait for user..."
sketch\language_it.h:123:0: warning: "MSG_RESUMING" redefined [enabled by default]
#define MSG_RESUMING "Riprendi Stampa"
sketch\language_en.h:123:0: note: this is the location of the previous definition
#define MSG_RESUMING "Resuming print"
sketch\language_it.h:124:0: warning: "MSG_PRINT_ABORTED" redefined [enabled by default]
#define MSG_PRINT_ABORTED "Stampa abortita"
sketch\language_en.h:124:0: note: this is the location of the previous definition
#define MSG_PRINT_ABORTED "Print aborted"
sketch\language_it.h:125:0: warning: "MSG_NO_MOVE" redefined [enabled by default]
#define MSG_NO_MOVE "Nessun Movimento"
sketch\language_en.h:125:0: note: this is the location of the previous definition
#define MSG_NO_MOVE "No move."
sketch\language_it.h:126:0: warning: "MSG_KILLED" redefined [enabled by default]
#define MSG_KILLED "UCCISO "
sketch\language_en.h:126:0: note: this is the location of the previous definition
#define MSG_KILLED "KILLED. "
sketch\language_it.h:127:0: warning: "MSG_STOPPED" redefined [enabled by default]
#define MSG_STOPPED "ARRESTATO "
sketch\language_en.h:127:0: note: this is the location of the previous definition
#define MSG_STOPPED "STOPPED. "
sketch\language_it.h:128:0: warning: "MSG_CONTROL_RETRACT" redefined [enabled by default]
#define MSG_CONTROL_RETRACT "Ritrai mm"
sketch\language_en.h:128:0: note: this is the location of the previous definition
#define MSG_CONTROL_RETRACT "Retract mm"
sketch\language_it.h:129:0: warning: "MSG_CONTROL_RETRACT_SWAP" redefined [enabled by default]
#define MSG_CONTROL_RETRACT_SWAP "Scamb. Ritrai mm"
sketch\language_en.h:129:0: note: this is the location of the previous definition
#define MSG_CONTROL_RETRACT_SWAP "Swap Re.mm"
sketch\language_it.h:130:0: warning: "MSG_CONTROL_RETRACTF" redefined [enabled by default]
#define MSG_CONTROL_RETRACTF "Ritrai V"
sketch\language_en.h:130:0: note: this is the location of the previous definition
#define MSG_CONTROL_RETRACTF "Retract V"
sketch\language_it.h:131:0: warning: "MSG_CONTROL_RETRACT_ZLIFT" redefined [enabled by default]
#define MSG_CONTROL_RETRACT_ZLIFT "Salta mm"
sketch\language_en.h:131:0: note: this is the location of the previous definition
#define MSG_CONTROL_RETRACT_ZLIFT "Hop mm"
sketch\language_it.h:133:0: warning: "MSG_CONTROL_RETRACT_RECOVER_SWAP" redefined [enabled by default]
#define MSG_CONTROL_RETRACT_RECOVER_SWAP "Scamb. UnRet +mm"
sketch\language_en.h:133:0: note: this is the location of the previous definition
#define MSG_CONTROL_RETRACT_RECOVER_SWAP "S UnRet+mm"
sketch\language_it.h:135:0: warning: "MSG_AUTORETRACT" redefined [enabled by default]
#define MSG_AUTORETRACT "AutoArretramento"
sketch\language_en.h:135:0: note: this is the location of the previous definition
#define MSG_AUTORETRACT "AutoRetr."
sketch\language_it.h:136:0: warning: "MSG_FILAMENTCHANGE" redefined [enabled by default]
#define MSG_FILAMENTCHANGE "Cambia filamento"
sketch\language_en.h:136:0: note: this is the location of the previous definition
#define MSG_FILAMENTCHANGE "Change filament"
sketch\language_it.h:137:0: warning: "MSG_INIT_SDCARD" redefined [enabled by default]
#define MSG_INIT_SDCARD "Iniz. SD-Card"
sketch\language_en.h:137:0: note: this is the location of the previous definition
#define MSG_INIT_SDCARD "Init. SD card"
sketch\language_it.h:138:0: warning: "MSG_CNG_SDCARD" redefined [enabled by default]
#define MSG_CNG_SDCARD "Cambia SD-Card"
sketch\language_en.h:138:0: note: this is the location of the previous definition
#define MSG_CNG_SDCARD "Change SD card"
sketch\language_it.h:145:0: warning: "MSG_ENDSTOP_ABORT" redefined [enabled by default]
#define MSG_ENDSTOP_ABORT "Finecorsa abort"
sketch\language_en.h:145:0: note: this is the location of the previous definition
#define MSG_ENDSTOP_ABORT "Endstop abort"
sketch\language_it.h:146:0: warning: "MSG_END_HOUR" redefined [enabled by default]
#define MSG_END_HOUR "ore"
sketch\language_en.h:146:0: note: this is the location of the previous definition
#define MSG_END_HOUR "hours"
sketch\language_it.h:147:0: warning: "MSG_END_MINUTE" redefined [enabled by default]
#define MSG_END_MINUTE "minuti"
sketch\language_en.h:147:0: note: this is the location of the previous definition
#define MSG_END_MINUTE "minutes"
sketch\language_it.h:155:0: warning: "MSG_DEBUG_ECHO" redefined [enabled by default]
#define MSG_DEBUG_ECHO "DEBUG RIPETI"
sketch\language_en.h:155:0: note: this is the location of the previous definition
#define MSG_DEBUG_ECHO "DEBUG ECHO ENABLED"
sketch\language_it.h:156:0: warning: "MSG_DEBUG_INFO" redefined [enabled by default]
#define MSG_DEBUG_INFO "DEBUG INFO"
sketch\language_en.h:156:0: note: this is the location of the previous definition
#define MSG_DEBUG_INFO "DEBUG INFO ENABLED"
sketch\language_it.h:157:0: warning: "MSG_DEBUG_ERRORS" redefined [enabled by default]
#define MSG_DEBUG_ERRORS "DEBUG ERRORI"
sketch\language_en.h:157:0: note: this is the location of the previous definition
#define MSG_DEBUG_ERRORS "DEBUG ERRORS ENABLED"
sketch\language_it.h:158:0: warning: "MSG_DEBUG_DRYRUN" redefined [enabled by default]
#define MSG_DEBUG_DRYRUN "DEBUG STAMPA A VUOTO"
sketch\language_en.h:158:0: note: this is the location of the previous definition
#define MSG_DEBUG_DRYRUN "DEBUG DRYRUN ENABLED"
sketch\language_it.h:174:0: warning: "MSG_CONFIG" redefined [enabled by default]
#define MSG_CONFIG "Configurazione"
sketch\language_en.h:174:0: note: this is the location of the previous definition
#define MSG_CONFIG "Configuration"
sketch\ultralcd.cpp:53:55: fatal error: ultralcd_implementation_hitachi_HD44780.h: No such file or directory
#include "ultralcd_implementation_hitachi_HD44780.h"
compilation terminated.
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Re: Errore download firmware MarlinKimbra con Arduino July 28, 2016 07:58AM |
In file included from sketch\SdFile.h:27:0,
from sketch\cardreader.h:8,
from sketch\Marlin_main.cpp:37:
SdBaseFile.h:38: error: using typedef-name 'fpos_t' after 'struct'
struct fpos_t {
In file included from sketch\Marlin.h:10:0,
from sketch\Marlin_main.cpp:22:
c:\users\davide\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
__extension__ typedef long long fpos_t;
exit status 1
Re: Errore download firmware MarlinKimbra con Arduino July 28, 2016 08:24AM |
Re: Errore download firmware MarlinKimbra con Arduino July 28, 2016 12:41PM |
[Risolto] Errore download firmware MarlinKimbra con Arduino July 28, 2016 01:00PM |
