Errore download firmware MarlinKimbra con Arduino
July 28, 2016 05:01AM
Salve a tutti,
sto cercando di caricare il fw di MarlinKimbra sulla scheda della mia stampante 3D con Arduino Mega 2560, purtroppo quando faccio la verifica ho degli errori che mi vengono riportati dall' IDE Arduino 1.6.9. Qualcuno sa consigliarmi la soluzione? Grazie
Arduino:1.6.9 (Windows 8.1), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\Configuration_adv.h:529:0,
                 from sketch\Configuration.h:613,
                 from F:\Davide backup\Windows\Documenti\Stampante 3D\Firmware & configurations\MarlinKimbra_mod\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z.ino:31:
sketch\conditionals.h:238:0: warning: "DRIVER_EXTRUDERS" redefined [enabled by default]
     #define DRIVER_EXTRUDERS EXTRUDERS // This defines the number of Driver extruder
In file included from F:\Davide backup\Windows\Documenti\Stampante 3D\Firmware & configurations\MarlinKimbra_mod\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z\MarlinKimbra_15lug16_asse_x_y_z.ino:31:0:
sketch\Configuration.h:76:0: note: this is the location of the previous definition
 #define DRIVER_EXTRUDERS 1
In file included from sketch\conditionals.h:253:0,
                 from sketch\Configuration_adv.h:529,
sketch\pins.h:5447:0: warning: "X_MAX_PIN" redefined [enabled by default]
   #define X_MAX_PIN -1
In file included from sketch\pins.h:5440:0,
                 from sketch\conditionals.h:253,
sketch\pins2tool.h:59:0: note: this is the location of the previous definition
 #define X_MAX_PIN        ORIG_X_MAX_PIN
sketch\pins.h:5453:0: warning: "Y_MAX_PIN" redefined [enabled by default]
   #define Y_MAX_PIN -1
sketch\pins2tool.h:61:0: note: this is the location of the previous definition
 #define Y_MAX_PIN        ORIG_Y_MAX_PIN
sketch\pins.h:5459:0: warning: "Z_MAX_PIN" redefined [enabled by default]
   #define Z_MAX_PIN -1
sketch\pins2tool.h:63:0: note: this is the location of the previous definition
 #define Z_MAX_PIN        ORIG_Z_MAX_PIN
                 from sketch\Marlin.h:25,
                 from sketch\ultralcd.h:4,
                 from sketch\ultralcd.cpp:1:
In file included from sketch\Marlin.h:25:0,
In file included from sketch\ultralcd.cpp:4:0:
sketch\language.h:230:0: warning: "MSG_WATCHDOG_RESET" redefined [enabled by default]
 #define MSG_WATCHDOG_RESET                  "Something is wrong, please turn off the printer."
sketch\language.h:93:0: note: this is the location of the previous definition
 #define MSG_WATCHDOG_RESET                  " Watchdog Reset"
In file included from sketch\language.h:246:0,
sketch\language_en.h:69:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
 #define MSG_MIN                             " "LCD_STR_THERMOMETER " Min"
sketch\language_en.h:70:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
 #define MSG_MAX                             " "LCD_STR_THERMOMETER " Max"
sketch\language_en.h:71:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
 #define MSG_FACTOR                          " "LCD_STR_THERMOMETER " Fact"
In file included from sketch\language.h:259:0,
sketch\language_it.h:20:0: warning: "WELCOME_MSG" redefined [enabled by default]
 #define WELCOME_MSG                         MACHINE_NAME " pronta."
sketch\language_en.h:20:0: note: this is the location of the previous definition
 #define WELCOME_MSG                         MACHINE_NAME " ready."
sketch\language_it.h:21:0: warning: "MSG_SD_INSERTED" redefined [enabled by default]
 #define MSG_SD_INSERTED                     "SD Card inserita"
sketch\language_en.h:21:0: note: this is the location of the previous definition
 #define MSG_SD_INSERTED                     "Card inserted"
sketch\language_it.h:22:0: warning: "MSG_SD_REMOVED" redefined [enabled by default]
 #define MSG_SD_REMOVED                      "SD Card rimossa"
sketch\language_en.h:22:0: note: this is the location of the previous definition
 #define MSG_SD_REMOVED                      "Card removed"
sketch\language_it.h:23:0: warning: "MSG_MAIN" redefined [enabled by default]
 #define MSG_MAIN                            "Menu principale"
sketch\language_en.h:23:0: note: this is the location of the previous definition
 #define MSG_MAIN                            "Main"
sketch\language_it.h:25:0: warning: "MSG_DISABLE_STEPPERS" redefined [enabled by default]
 #define MSG_DISABLE_STEPPERS                "Disabilita Motori"
sketch\language_en.h:25:0: note: this is the location of the previous definition
 #define MSG_DISABLE_STEPPERS                "Disable steppers"
sketch\language_it.h:26:0: warning: "MSG_AUTO_HOME" redefined [enabled by default]
 #define MSG_AUTO_HOME                       "Auto Home"
sketch\language_en.h:26:0: note: this is the location of the previous definition
 #define MSG_AUTO_HOME                       "Auto home"
sketch\language_it.h:35:0: warning: "MSG_SET_HOME_OFFSETS" redefined [enabled by default]
 #define MSG_SET_HOME_OFFSETS                "Setta offset home"
sketch\language_en.h:35:0: note: this is the location of the previous definition
 #define MSG_SET_HOME_OFFSETS                "Set home offsets"
sketch\language_it.h:36:0: warning: "MSG_SET_ORIGIN" redefined [enabled by default]
 #define MSG_SET_ORIGIN                      "Imposta Origine"
sketch\language_en.h:36:0: note: this is the location of the previous definition
 #define MSG_SET_ORIGIN                      "Set origin"
sketch\language_it.h:37:0: warning: "MSG_PREHEAT_PLA" redefined [enabled by default]
 #define MSG_PREHEAT_PLA                     "Preriscalda PLA"
sketch\language_en.h:37:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_PLA                     "Preheat PLA"
sketch\language_it.h:38:0: warning: "MSG_PREHEAT_PLA_ALL" redefined [enabled by default]
 #define MSG_PREHEAT_PLA_ALL                 "Prer. PLA Tutto"
sketch\language_en.h:38:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_PLA_ALL                 "Preheat PLA All"
sketch\language_it.h:39:0: warning: "MSG_PREHEAT_PLA_BEDONLY" redefined [enabled by default]
 #define MSG_PREHEAT_PLA_BEDONLY             "Prer. PLA Piatto"
sketch\language_en.h:39:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_PLA_BEDONLY             "Preheat PLA Bed"
sketch\language_it.h:40:0: warning: "MSG_PREHEAT_PLA_SETTINGS" redefined [enabled by default]
 #define MSG_PREHEAT_PLA_SETTINGS            "Config. prer. PLA"
sketch\language_en.h:40:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_PLA_SETTINGS            "Preheat PLA conf"
sketch\language_it.h:41:0: warning: "MSG_PREHEAT_ABS" redefined [enabled by default]
 #define MSG_PREHEAT_ABS                     "Preriscalda ABS"
sketch\language_en.h:41:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_ABS                     "Preheat ABS"
sketch\language_it.h:42:0: warning: "MSG_PREHEAT_ABS_ALL" redefined [enabled by default]
 #define MSG_PREHEAT_ABS_ALL                 "Prer. ABS Tutto"
sketch\language_en.h:42:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_ABS_ALL                 "Preheat ABS All"
sketch\language_it.h:43:0: warning: "MSG_PREHEAT_ABS_BEDONLY" redefined [enabled by default]
 #define MSG_PREHEAT_ABS_BEDONLY             "Prer. ABS Piatto"
sketch\language_en.h:43:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_ABS_BEDONLY             "Preheat ABS Bed"
sketch\language_it.h:44:0: warning: "MSG_PREHEAT_ABS_SETTINGS" redefined [enabled by default]
 #define MSG_PREHEAT_ABS_SETTINGS            "Config. prer. ABS"
sketch\language_en.h:44:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_ABS_SETTINGS            "Preheat ABS conf"
sketch\language_it.h:45:0: warning: "MSG_PREHEAT_GUM" redefined [enabled by default]
 #define MSG_PREHEAT_GUM                     "Preriscalda GOMMA"
sketch\language_en.h:45:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_GUM                     "Preheat GUM"
sketch\language_it.h:46:0: warning: "MSG_PREHEAT_GUM_ALL" redefined [enabled by default]
 #define MSG_PREHEAT_GUM_ALL                 "Preri. GOMMA Tutto"
sketch\language_en.h:46:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_GUM_ALL                 "Preheat GUM All"
sketch\language_it.h:47:0: warning: "MSG_PREHEAT_GUM_BEDONLY" redefined [enabled by default]
 #define MSG_PREHEAT_GUM_BEDONLY             "Preri. GOMMA Piatto"
sketch\language_en.h:47:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_GUM_BEDONLY             "Preheat GUM Bed"
sketch\language_it.h:48:0: warning: "MSG_PREHEAT_GUM_SETTINGS" redefined [enabled by default]
 #define MSG_PREHEAT_GUM_SETTINGS            "Config. prer. GOMMA"
sketch\language_en.h:48:0: note: this is the location of the previous definition
 #define MSG_PREHEAT_GUM_SETTINGS            "Preheat GUM conf"
sketch\language_it.h:49:0: warning: "MSG_COOLDOWN" redefined [enabled by default]
 #define MSG_COOLDOWN                        "Raffredda"
sketch\language_en.h:49:0: note: this is the location of the previous definition
 #define MSG_COOLDOWN                        "Cooldown"
sketch\language_it.h:50:0: warning: "MSG_SWITCH_PS_ON" redefined [enabled by default]
 #define MSG_SWITCH_PS_ON                    "Accendi aliment."
sketch\language_en.h:50:0: note: this is the location of the previous definition
 #define MSG_SWITCH_PS_ON                    "Switch power on"
sketch\language_it.h:51:0: warning: "MSG_SWITCH_PS_OFF" redefined [enabled by default]
 #define MSG_SWITCH_PS_OFF                   "Spegni aliment."
sketch\language_en.h:51:0: note: this is the location of the previous definition
 #define MSG_SWITCH_PS_OFF                   "Switch power off"
sketch\language_it.h:52:0: warning: "MSG_EXTRUDE" redefined [enabled by default]
 #define MSG_EXTRUDE                         "Estrudi"
sketch\language_en.h:52:0: note: this is the location of the previous definition
 #define MSG_EXTRUDE                         "Extrude"
sketch\language_it.h:53:0: warning: "MSG_RETRACT" redefined [enabled by default]
 #define MSG_RETRACT                         "Ritrai"
sketch\language_en.h:53:0: note: this is the location of the previous definition
 #define MSG_RETRACT                         "Retract"
sketch\language_it.h:54:0: warning: "MSG_MOVE_AXIS" redefined [enabled by default]
 #define MSG_MOVE_AXIS                       "Muovi Asse"
sketch\language_en.h:54:0: note: this is the location of the previous definition
 #define MSG_MOVE_AXIS                       "Move axis"
sketch\language_it.h:56:0: warning: "MSG_MOVE_X" redefined [enabled by default]
 #define MSG_MOVE_X                          "Muovi X"
sketch\language_en.h:56:0: note: this is the location of the previous definition
 #define MSG_MOVE_X                          "Move X"
sketch\language_it.h:57:0: warning: "MSG_MOVE_Y" redefined [enabled by default]
 #define MSG_MOVE_Y                          "Muovi Y"
sketch\language_en.h:57:0: note: this is the location of the previous definition
 #define MSG_MOVE_Y                          "Move Y"
sketch\language_it.h:58:0: warning: "MSG_MOVE_Z" redefined [enabled by default]
 #define MSG_MOVE_Z                          "Muovi Z"
sketch\language_en.h:58:0: note: this is the location of the previous definition
 #define MSG_MOVE_Z                          "Move Z"
sketch\language_it.h:59:0: warning: "MSG_MOVE_E" redefined [enabled by default]
 #define MSG_MOVE_E                          "Estrusore"
sketch\language_en.h:59:0: note: this is the location of the previous definition
 #define MSG_MOVE_E                          "Extruder"
sketch\language_it.h:60:0: warning: "MSG_MOVE_01MM" redefined [enabled by default]
 #define MSG_MOVE_01MM                       "Muovi di 0.1mm"
sketch\language_en.h:60:0: note: this is the location of the previous definition
 #define MSG_MOVE_01MM                       "Move 0.1mm"
sketch\language_it.h:61:0: warning: "MSG_MOVE_1MM" redefined [enabled by default]
 #define MSG_MOVE_1MM                        "Muovi di   1mm"
sketch\language_en.h:61:0: note: this is the location of the previous definition
 #define MSG_MOVE_1MM                        "Move 1mm"
sketch\language_it.h:62:0: warning: "MSG_MOVE_10MM" redefined [enabled by default]
 #define MSG_MOVE_10MM                       "Muovi di  10mm"
sketch\language_en.h:62:0: note: this is the location of the previous definition
 #define MSG_MOVE_10MM                       "Move 10mm"
sketch\language_it.h:63:0: warning: "MSG_SPEED" redefined [enabled by default]
 #define MSG_SPEED                           "Velocità"
sketch\language_en.h:63:0: note: this is the location of the previous definition
 #define MSG_SPEED                           "Speed"
sketch\language_it.h:64:0: warning: "MSG_NOZZLE" redefined [enabled by default]
 #define MSG_NOZZLE                          "Ugello"
sketch\language_en.h:64:0: note: this is the location of the previous definition
 #define MSG_NOZZLE                          "Nozzle"
sketch\language_it.h:65:0: warning: "MSG_BED" redefined [enabled by default]
 #define MSG_BED                             "Piatto"
sketch\language_en.h:65:0: note: this is the location of the previous definition
 #define MSG_BED                             "Bed"
sketch\language_it.h:66:0: warning: "MSG_FAN_SPEED" redefined [enabled by default]
 #define MSG_FAN_SPEED                       "Ventola"
sketch\language_en.h:66:0: note: this is the location of the previous definition
 #define MSG_FAN_SPEED                       "Fan speed"
sketch\language_it.h:67:0: warning: "MSG_FLOW" redefined [enabled by default]
 #define MSG_FLOW                            "Flusso"
sketch\language_en.h:67:0: note: this is the location of the previous definition
 #define MSG_FLOW                            "Flow"
sketch\language_it.h:68:0: warning: "MSG_CONTROL" redefined [enabled by default]
 #define MSG_CONTROL                         "Controllo"
sketch\language_en.h:68:0: note: this is the location of the previous definition
 #define MSG_CONTROL                         "Control"
sketch\language_it.h:69:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
sketch\language_it.h:70:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
sketch\language_it.h:71:45: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
sketch\language_it.h:82:0: warning: "MSG_ACC" redefined [enabled by default]
 #define MSG_ACC                             "Accel."
sketch\language_en.h:82:0: note: this is the location of the previous definition
 #define MSG_ACC                             "Accel"
sketch\language_it.h:86:0: warning: "MSG_VMAX" redefined [enabled by default]
 #define MSG_VMAX                            "Vmax"
sketch\language_en.h:86:0: note: this is the location of the previous definition
 #define MSG_VMAX                            "Vmax "
sketch\language_it.h:93:0: warning: "MSG_AMAX" redefined [enabled by default]
 #define MSG_AMAX                            "Amax"
sketch\language_en.h:93:0: note: this is the location of the previous definition
 #define MSG_AMAX                            "Amax "
sketch\language_it.h:103:0: warning: "MSG_TEMPERATURE" redefined [enabled by default]
 #define MSG_TEMPERATURE                     "Temperatura"
sketch\language_en.h:103:0: note: this is the location of the previous definition
 #define MSG_TEMPERATURE                     "Temperature"
sketch\language_it.h:104:0: warning: "MSG_MOTION" redefined [enabled by default]
 #define MSG_MOTION                          "Movimento"
sketch\language_en.h:104:0: note: this is the location of the previous definition
 #define MSG_MOTION                          "Motion"
sketch\language_it.h:105:0: warning: "MSG_VOLUMETRIC" redefined [enabled by default]
 #define MSG_VOLUMETRIC                      "Filamento"
sketch\language_en.h:105:0: note: this is the location of the previous definition
 #define MSG_VOLUMETRIC                      "Filament"
sketch\language_it.h:106:0: warning: "MSG_VOLUMETRIC_ENABLED" redefined [enabled by default]
 #define MSG_VOLUMETRIC_ENABLED              "E in mm³"
sketch\language_en.h:106:0: note: this is the location of the previous definition
 #define MSG_VOLUMETRIC_ENABLED              "E in mm3"
sketch\language_it.h:107:0: warning: "MSG_FILAMENT_SIZE_EXTRUDER" redefined [enabled by default]
 #define MSG_FILAMENT_SIZE_EXTRUDER          "Diam. filo"
sketch\language_en.h:107:0: note: this is the location of the previous definition
 #define MSG_FILAMENT_SIZE_EXTRUDER          "Fil. Dia."
sketch\language_it.h:108:0: warning: "MSG_CONTRAST" redefined [enabled by default]
 #define MSG_CONTRAST                        "Contrasto LCD"
sketch\language_en.h:108:0: note: this is the location of the previous definition
 #define MSG_CONTRAST                        "LCD contrast"
sketch\language_it.h:109:0: warning: "MSG_STORE_EPROM" redefined [enabled by default]
 #define MSG_STORE_EPROM                     "Salva in EEPROM"
sketch\language_en.h:109:0: note: this is the location of the previous definition
 #define MSG_STORE_EPROM                     "Store memory"
sketch\language_it.h:110:0: warning: "MSG_LOAD_EPROM" redefined [enabled by default]
 #define MSG_LOAD_EPROM                      "Carica da EEPROM"
sketch\language_en.h:110:0: note: this is the location of the previous definition
 #define MSG_LOAD_EPROM                      "Load memory"
sketch\language_it.h:111:0: warning: "MSG_RESTORE_FAILSAFE" redefined [enabled by default]
 #define MSG_RESTORE_FAILSAFE                "Impostaz. default"
sketch\language_en.h:111:0: note: this is the location of the previous definition
 #define MSG_RESTORE_FAILSAFE                "Restore failsafe"
sketch\language_it.h:112:0: warning: "MSG_REFRESH" redefined [enabled by default]
 #define MSG_REFRESH                         "Aggiorna"
sketch\language_en.h:112:0: note: this is the location of the previous definition
 #define MSG_REFRESH                         "Refresh"
sketch\language_it.h:113:0: warning: "MSG_WATCH" redefined [enabled by default]
 #define MSG_WATCH                           "Guarda"
sketch\language_en.h:113:0: note: this is the location of the previous definition
 #define MSG_WATCH                           "Info screen"
sketch\language_it.h:114:0: warning: "MSG_PREPARE" redefined [enabled by default]
 #define MSG_PREPARE                         "Prepara"
sketch\language_en.h:114:0: note: this is the location of the previous definition
 #define MSG_PREPARE                         "Prepare"
sketch\language_it.h:115:0: warning: "MSG_TUNE" redefined [enabled by default]
 #define MSG_TUNE                            "Adatta"
sketch\language_en.h:115:0: note: this is the location of the previous definition
 #define MSG_TUNE                            "Tune"
sketch\language_it.h:116:0: warning: "MSG_PAUSE_PRINT" redefined [enabled by default]
 #define MSG_PAUSE_PRINT                     "Pausa"
sketch\language_en.h:116:0: note: this is the location of the previous definition
 #define MSG_PAUSE_PRINT                     "Pause print"
sketch\language_it.h:117:0: warning: "MSG_RESUME_PRINT" redefined [enabled by default]
 #define MSG_RESUME_PRINT                    "Riprendi Stampa"
sketch\language_en.h:117:0: note: this is the location of the previous definition
 #define MSG_RESUME_PRINT                    "Resume print"
sketch\language_it.h:118:0: warning: "MSG_STOP_PRINT" redefined [enabled by default]
 #define MSG_STOP_PRINT                      "Arresta Stampa"
sketch\language_en.h:118:0: note: this is the location of the previous definition
 #define MSG_STOP_PRINT                      "Stop print"
sketch\language_it.h:119:0: warning: "MSG_CARD_MENU" redefined [enabled by default]
 #define MSG_CARD_MENU                       "SD Card Menu"
sketch\language_en.h:119:0: note: this is the location of the previous definition
 #define MSG_CARD_MENU                       "Print from SD"
sketch\language_it.h:120:0: warning: "MSG_NO_CARD" redefined [enabled by default]
 #define MSG_NO_CARD                         "No SD Card"
sketch\language_en.h:120:0: note: this is the location of the previous definition
 #define MSG_NO_CARD                         "No SD card"
sketch\language_it.h:121:0: warning: "MSG_DWELL" redefined [enabled by default]
 #define MSG_DWELL                           "Sospensione..."
sketch\language_en.h:121:0: note: this is the location of the previous definition
 #define MSG_DWELL                           "Sleep..."
sketch\language_it.h:122:0: warning: "MSG_USERWAIT" redefined [enabled by default]
 #define MSG_USERWAIT                        "Attendi Utente..."
sketch\language_en.h:122:0: note: this is the location of the previous definition
 #define MSG_USERWAIT                        "Wait for user..."
sketch\language_it.h:123:0: warning: "MSG_RESUMING" redefined [enabled by default]
 #define MSG_RESUMING                        "Riprendi Stampa"
sketch\language_en.h:123:0: note: this is the location of the previous definition
 #define MSG_RESUMING                        "Resuming print"
sketch\language_it.h:124:0: warning: "MSG_PRINT_ABORTED" redefined [enabled by default]
 #define MSG_PRINT_ABORTED                   "Stampa abortita"
sketch\language_en.h:124:0: note: this is the location of the previous definition
 #define MSG_PRINT_ABORTED                   "Print aborted"
sketch\language_it.h:125:0: warning: "MSG_NO_MOVE" redefined [enabled by default]
 #define MSG_NO_MOVE                         "Nessun Movimento"
sketch\language_en.h:125:0: note: this is the location of the previous definition
 #define MSG_NO_MOVE                         "No move."
sketch\language_it.h:126:0: warning: "MSG_KILLED" redefined [enabled by default]
 #define MSG_KILLED                          "UCCISO "
sketch\language_en.h:126:0: note: this is the location of the previous definition
 #define MSG_KILLED                          "KILLED. "
sketch\language_it.h:127:0: warning: "MSG_STOPPED" redefined [enabled by default]
 #define MSG_STOPPED                         "ARRESTATO "
sketch\language_en.h:127:0: note: this is the location of the previous definition
 #define MSG_STOPPED                         "STOPPED. "
sketch\language_it.h:128:0: warning: "MSG_CONTROL_RETRACT" redefined [enabled by default]
 #define MSG_CONTROL_RETRACT                 "Ritrai mm"
sketch\language_en.h:128:0: note: this is the location of the previous definition
 #define MSG_CONTROL_RETRACT                 "Retract mm"
sketch\language_it.h:129:0: warning: "MSG_CONTROL_RETRACT_SWAP" redefined [enabled by default]
 #define MSG_CONTROL_RETRACT_SWAP            "Scamb. Ritrai mm"
sketch\language_en.h:129:0: note: this is the location of the previous definition
 #define MSG_CONTROL_RETRACT_SWAP            "Swap Re.mm"
sketch\language_it.h:130:0: warning: "MSG_CONTROL_RETRACTF" redefined [enabled by default]
 #define MSG_CONTROL_RETRACTF                "Ritrai  V"
sketch\language_en.h:130:0: note: this is the location of the previous definition
 #define MSG_CONTROL_RETRACTF                "Retract  V"
sketch\language_it.h:131:0: warning: "MSG_CONTROL_RETRACT_ZLIFT" redefined [enabled by default]
 #define MSG_CONTROL_RETRACT_ZLIFT           "Salta mm"
sketch\language_en.h:131:0: note: this is the location of the previous definition
 #define MSG_CONTROL_RETRACT_ZLIFT           "Hop mm"
sketch\language_it.h:133:0: warning: "MSG_CONTROL_RETRACT_RECOVER_SWAP" redefined [enabled by default]
 #define MSG_CONTROL_RETRACT_RECOVER_SWAP    "Scamb. UnRet +mm"
sketch\language_en.h:133:0: note: this is the location of the previous definition
 #define MSG_CONTROL_RETRACT_RECOVER_SWAP    "S UnRet+mm"
sketch\language_it.h:135:0: warning: "MSG_AUTORETRACT" redefined [enabled by default]
 #define MSG_AUTORETRACT                     "AutoArretramento"
sketch\language_en.h:135:0: note: this is the location of the previous definition
 #define MSG_AUTORETRACT                     "AutoRetr."
sketch\language_it.h:136:0: warning: "MSG_FILAMENTCHANGE" redefined [enabled by default]
 #define MSG_FILAMENTCHANGE                  "Cambia filamento"
sketch\language_en.h:136:0: note: this is the location of the previous definition
 #define MSG_FILAMENTCHANGE                  "Change filament"
sketch\language_it.h:137:0: warning: "MSG_INIT_SDCARD" redefined [enabled by default]
 #define MSG_INIT_SDCARD                     "Iniz. SD-Card"
sketch\language_en.h:137:0: note: this is the location of the previous definition
 #define MSG_INIT_SDCARD                     "Init. SD card"
sketch\language_it.h:138:0: warning: "MSG_CNG_SDCARD" redefined [enabled by default]
 #define MSG_CNG_SDCARD                      "Cambia SD-Card"
sketch\language_en.h:138:0: note: this is the location of the previous definition
 #define MSG_CNG_SDCARD                      "Change SD card"
sketch\language_it.h:145:0: warning: "MSG_ENDSTOP_ABORT" redefined [enabled by default]
 #define MSG_ENDSTOP_ABORT                   "Finecorsa abort"
sketch\language_en.h:145:0: note: this is the location of the previous definition
 #define MSG_ENDSTOP_ABORT                   "Endstop abort"
sketch\language_it.h:146:0: warning: "MSG_END_HOUR" redefined [enabled by default]
 #define MSG_END_HOUR                        "ore"
sketch\language_en.h:146:0: note: this is the location of the previous definition
 #define MSG_END_HOUR                        "hours"
sketch\language_it.h:147:0: warning: "MSG_END_MINUTE" redefined [enabled by default]
 #define MSG_END_MINUTE                      "minuti"
sketch\language_en.h:147:0: note: this is the location of the previous definition
 #define MSG_END_MINUTE                      "minutes"
sketch\language_it.h:155:0: warning: "MSG_DEBUG_ECHO" redefined [enabled by default]
 #define MSG_DEBUG_ECHO                      "DEBUG RIPETI"
sketch\language_en.h:155:0: note: this is the location of the previous definition
 #define MSG_DEBUG_ECHO                      "DEBUG ECHO ENABLED"
sketch\language_it.h:156:0: warning: "MSG_DEBUG_INFO" redefined [enabled by default]
 #define MSG_DEBUG_INFO                      "DEBUG INFO"
sketch\language_en.h:156:0: note: this is the location of the previous definition
 #define MSG_DEBUG_INFO                      "DEBUG INFO ENABLED"
sketch\language_it.h:157:0: warning: "MSG_DEBUG_ERRORS" redefined [enabled by default]
 #define MSG_DEBUG_ERRORS                    "DEBUG ERRORI"
sketch\language_en.h:157:0: note: this is the location of the previous definition
 #define MSG_DEBUG_ERRORS                    "DEBUG ERRORS ENABLED"
sketch\language_it.h:158:0: warning: "MSG_DEBUG_DRYRUN" redefined [enabled by default]
 #define MSG_DEBUG_DRYRUN                    "DEBUG STAMPA A VUOTO"
sketch\language_en.h:158:0: note: this is the location of the previous definition
 #define MSG_DEBUG_DRYRUN                    "DEBUG DRYRUN ENABLED"
sketch\language_it.h:174:0: warning: "MSG_CONFIG" redefined [enabled by default]
 #define MSG_CONFIG                          "Configurazione"
sketch\language_en.h:174:0: note: this is the location of the previous definition
 #define MSG_CONFIG                          "Configuration"
sketch\ultralcd.cpp:53:55: fatal error: ultralcd_implementation_hitachi_HD44780.h: No such file or directory
   #include "ultralcd_implementation_hitachi_HD44780.h"
compilation terminated.
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Edited 1 time(s). Last edit at 07/28/2016 05:06AM by davgiuffrida.
Re: Errore download firmware MarlinKimbra con Arduino
July 28, 2016 07:58AM
Adesso ho provato ad aggiornare alcune librerie sull'i IDE di Arduino e gli errori sembrano diversi.
In file included from sketch\SdFile.h:27:0,
                 from sketch\cardreader.h:8,
                 from sketch\Marlin_main.cpp:37:
SdBaseFile.h:38: error: using typedef-name 'fpos_t' after 'struct'
 struct fpos_t {
In file included from sketch\Marlin.h:10:0,
                 from sketch\Marlin_main.cpp:22:
c:\users\davide\appdata\local\arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2\avr\include\stdio.h:950:33: note: 'fpos_t' has a previous declaration here
 __extension__ typedef long long fpos_t;
exit status 1
Edited 2 time(s). Last edit at 07/28/2016 08:03AM by davgiuffrida.
July 28, 2016 08:24AM
Anche dopo aver aggiornato la libreria U8glib appare sempre lo stesso errore.
Edited 1 time(s). Last edit at 07/28/2016 08:25AM by davgiuffrida.
July 28, 2016 12:41PM
prova ad allegare il configuration_overall.h (allegalo non metterlo nel codice).
Il primo errore era legato come avrai visto al tipo di display, il secondo non so esattamente...ma Marlin_main.cpp è un file di Marlin e non c'è nel pacchetto MK (almeno non nel mio).
la directory dove espandi i file è vuota vero? la u8glib la stai piazzando in documenti\Arduino\Libraries? hai tutto di defalut nell'installazione dell'Ide?
hai configurazioni strane di stampante? cosa stai configurando?
[Risolto] Errore download firmware MarlinKimbra con Arduino
July 28, 2016 01:00PM
Ho risolto utilizzando la versione IDE di Arduino 1.0.6.e il file era corrotto.
Grazie a tutti
Edited 1 time(s). Last edit at 07/28/2016 01:01PM by davgiuffrida.
