Problemi stampa con asse Z March 28, 2017 08:14AM |
Re: Problemi stampa con asse Z March 28, 2017 03:34PM |
Re: Problemi stampa con asse Z March 29, 2017 04:05AM |
Re: Problemi stampa con asse Z March 29, 2017 06:50AM |
Re: Problemi stampa con asse Z March 29, 2017 08:57AM |
Re: Problemi stampa con asse Z March 29, 2017 09:13AM |
Re: Problemi stampa con asse Z March 29, 2017 09:16AM |
Re: Problemi stampa con asse Z March 29, 2017 09:57AM |
Re: Problemi stampa con asse Z March 29, 2017 05:34PM |
Re: Problemi stampa con asse Z March 30, 2017 12:10PM |
Re: Problemi stampa con asse Z March 31, 2017 08:31AM |
Re: Problemi stampa con asse Z March 31, 2017 09:25AM |
Re: Problemi stampa con asse Z March 31, 2017 09:35AM |
Re: Problemi stampa con asse Z March 31, 2017 09:36AM |
gpau
#define DEFAULT_AXIS_STEPS_PER_UNIT {78.74,78.74,400,95} // MXL, Z M8=1.25, MK8
Re: Problemi stampa con asse Z March 31, 2017 10:05AM |
Re: Problemi stampa con asse Z March 31, 2017 10:21AM |
gpau
Se le impostazioni sono giuste come dici, perché fa cosi?
Re: Problemi stampa con asse Z March 31, 2017 10:37AM |
Re: Problemi stampa con asse Z March 31, 2017 10:50AM |
gpau
Io utilizzo simplify3D e non so come si fa vedere il G-code pero ho provato con repieter e fa la stessa cosa.
; generated by Slic3r 1.2.9 on 2017-03-31 at 16:34:40
; external perimeters extrusion width = 0.30mm
; perimeters extrusion width = 0.30mm
; infill extrusion width = 0.40mm
; solid infill extrusion width = 0.40mm
; top infill extrusion width = 0.40mm
M107
M190 S80 ; wait for bed temperature to be reached
M104 S200 ; set extruder temperature
G28 ; home all axis
G1 Z5 F5000 ; lift nozzle
G21 ; set units to millimeters
G90 ; use absolute coordinates
M82 ; use absolute distances for extrusion
Re: Problemi stampa con asse Z March 31, 2017 10:53AM |
MagoKimbra
Perché stai usando i dati in eeprom...
Dai il comando M503 e leggi i valori che hai vedrai che hai ancora 440
Re: Problemi stampa con asse Z March 31, 2017 11:05AM |
Re: Problemi stampa con asse Z March 31, 2017 11:08AM |
Re: Problemi stampa con asse Z March 31, 2017 11:21AM |
gpau
Questo problema é dovuto a cosa, regolazioni nel firmware o altro.
Ha iniziato a farlo di punto in bianco, senza nessun preavviso
Re: Problemi stampa con asse Z March 31, 2017 11:23AM |
Re: Problemi stampa con asse Z March 31, 2017 11:26AM |
il video non serve a nulla, serve il fil G-Code per vedere cosa scrive lo slicer al cambio layer!Quote
gpau
OK ti faccio il video con simplify3D
Re: Problemi stampa con asse Z March 31, 2017 11:53AM |
Re: Problemi stampa con asse Z March 31, 2017 12:11PM |
Re: Problemi stampa con asse Z April 01, 2017 04:57AM |
Re: Problemi stampa con asse Z April 02, 2017 12:56PM |
Re: Problemi stampa con asse Z April 03, 2017 02:28PM |
Re: Problemi stampa con asse Z April 12, 2017 04:20AM |
