Non stampa al centro del piatto January 19, 2019 06:00PM |
Re: Non stampa al centro del piatto January 20, 2019 05:32AM |
; generated by Slic3r 1.3.0 on 2018-05-26 at 16:20:58 ; external perimeters extrusion width = 0.44mm (3.38mm^3/s) ; perimeters extrusion width = 0.48mm (7.54mm^3/s) ; infill extrusion width = 0.48mm (10.05mm^3/s) ; solid infill extrusion width = 0.48mm (5.03mm^3/s) ; top infill extrusion width = 0.33mm (1.20mm^3/s) ; support material extrusion width = 0.44mm (6.76mm^3/s) M190 S100 ; set bed temperature and wait for it to be reached M104 S245 ; set temperature G28 ; home all axes M420 S1 ; activate Mesh Bed Levelling with saved value G1 Z5 F5000 ; lift nozzle G1 X10 Y10 ; move to a safe positionin the bed to avoid the nuts ; Filament gcode M92 E296 T0 M109 S245 ; set temperature and wait for it to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ; reset extrusion distance G1 Z0.270 F18000.000 ; move to next layer (0) G1 E-4.00000 F48000.00000 ; retract extruder 0 G92 E0 ; reset extrusion distance G1 Z0.420 F18000.000 ; lift Z G1 X57.266 Y69.122 F18000.000 ; move to first skirt point G1 Z0.270 F18000.000 ; restore layer Z G1 E4.00000 F48000.00000 ; unretract extruder 0 G1 F1800
G1 X58.888 Y68.269 E4.17167 ; skirt G1 X59.856 Y68.122 E4.26336 ; skirt G1 X71.299 Y67.715 E5.33574 ; skirt G1 X98.520 Y67.717 E7.88526 ; skirt G1 X114.311 Y68.119 E9.36467 ; skirt G1 X116.091 Y68.560 E9.53635 ; skirt G1 X117.928 Y70.321 E9.77477 ; skirt
Re: Non stampa al centro del piatto January 20, 2019 12:28PM |
Re: Non stampa al centro del piatto January 25, 2019 12:56PM |
