Un aiuto con Dondolo
Posted by lanjazz
Re: Un aiuto con Dondolo
March 22, 2020 01:56AM
Questo e' il risultato di M503:
Send: M503
Recv: Config: G21 ; Units in (mm)
Recv: Configconfused smileyteps per unit:
Recv: Config: M92 X198.200 Y198.600 Z787.200
Recv: Config: M92 T0 E193.000
Recv: Config: M92 T1 E625.000
Recv: Config:Maximum Acceleration (units/s2):
Recv: Config: M201 X3000 Y3000 Z50
Recv: Config: M201 T0 E3000
Recv: Config: M201 T1 E3000
Recv: Config:Maximum feedrates (units/s):
Recv: Config: M203 X300.000 Y300.000 Z2.000
Recv: Config: M203 T0 E100.000
Recv: Config: M203 T1 E100.000
Recv: Config:Acceleration (units/s2): P V T* R
Recv: Config: M204 P3000.000 V3000.000
Recv: Config: M204 T0 R10000.000
Recv: Config: M204 T1 R10000.000
Recv: Config:Advanced: B S V
Recv: Config: M205 B20000 S0.000 V0.000
Recv: Config:Jerk: X Y Z T* E
Recv: Config: M205 X10.000 Y10.000 Z0.400
Recv: Config: M205 T0 E5.000
Recv: Config: M205 T1 E5.000
Recv: Configconfused smileyet axis max travel:
Recv: Config: M228 S0 X200.000 Y200.000 Z200.000
Recv: Configconfused smileyet axis min travel:
Recv: Config: M228 S1 X10.000 Y10.000 Z0.000
Recv: Config:Total number D E H B C
Recv: Config: M353 D2 E2 H2 B1 C0 F2
Recv: Config:Hotend assignment T H
Recv: Config: M563 T0 D0 H0
Recv: Config: M563 T1 D1 H1
Recv: Config:Heater Sensor parameters: H P S A B C R L O:
Recv: Config: M305 H0 P0 S1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0
Recv: Config:Heater parameters: H P A B C F L O U I R Q:
Recv: Config: M306 H0 P13 A40 B230 C255 F250 L0 O275 U1 I0 Q1 R0
Recv: Config:Heater PID parameters: H P I D:
Recv: Config: M301 H0 P24.35 I2.20 D67.47
Recv: Config: M305 H1 P1 S1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0
Recv: Config: M306 H1 P12 A40 B230 C255 F250 L5 O275 U1 I0 Q1 R0
Recv: Config: M301 H1 P40.00 I7.00 D60.00
Recv: Config:Heater Sensor parameters: H T P S A B C R L O:
Recv: Config: M305 H-1 T0 P4 S1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0
Recv: Config:Heater parameters: H T P A B C F L O U I R Q:
Recv: Config: M306 H-1 T0 P7 A40 B230 C255 F100 L0 O150 U0 I0 Q1 R0
Recv: Config:Nozzle Park: X Y Z
Recv: Config: M217 X10.00 Y10.00 Z20.00
Recv: Config:Hotend offset (unit): T X Y Z:
Recv: Config: M218 T0 X0.000 Y0.000 Z0.000
Recv: Config: M218 T1 X0.000 Y0.000 Z0.000
Recv: Config:Fans: P U L X I H T F
Recv: Config: M106 P0 U9 L0 X255 F250 I0 H-1
Recv: Config: M106 P1 U8 L0 X255 I0 H0 T50
Recv: Config:Endstops logic:
Recv: Config: M123 X0 Y0 Z0
Recv: Config:Endstops pullup:
Recv: Config: M124 X1 Y1 Z1
Recv: Config: M149 C ; Units in Celsius
Recv: Configconfused smileyervo Angles: P L U:
Recv: Config: M281 P0 L50 U26
Recv: Config:Material heatup parameters
Recv: Config: M145 S0 H205 B50 F255
Recv: Config: M145 S1 H240 B100 F255
Recv: Config: M145 S2 H243 B60 F255
Recv: Configconfused smileytepper driver pins E DEdited 2 time(s). Last edit at 03/22/2020 02:02AM by lanjazz.
Assolutamente neofita ma appassionato di elettronica, meccanica e Arduino...... e con la testa dura. Radioamatore dal 2013 con il nominativo IZ3ZLU, appassionato di musica suonata, polistrumentista. Il miglior progetto realizzato con la mia stampante 3D? [www.youtube.com]
March 22, 2020 02:03AM
Dando M122 il risultato e' uguale a prima:
Send: M122
Recv: echo : Soft endstopsyawning smileyn
Recv: Min : X10.00 Y10.00 Z10.00 Max : X200.00 Y200.00 Z210.00
Recv: ok P31 B7
Prima di abilitare Dondolo vedevo:
Minangry smiley -10 Y -10 Z 0 Max X200 Y200 Z180 che sono i valori da me impostati sul tuo firmware.
Edited 1 time(s). Last edit at 03/22/2020 02:04AM by lanjazz.
March 22, 2020 05:18AM
Ok infatti ora ho capito da dove esce quello Z10, hai i softendstop settati male, Z infatti è 10 quindi sotto a 10 non può scendere....
I softendstop di solito sono uguali ai valori di min e max che hai.
Fai cosi prova a dare il comando M228 S1 Z0 e poi di nuovo M122 e vedi se ti da correttamente i valori giusti dei soft endstop...
My Blog - My Thingiverse
March 22, 2020 05:50AM
A me dispiace romperti.... davvero.... grazie, ma niente da fare.
Malgrado io abbia mandato a zero con G28, dando il comando che mi hai detto il risultato e' questo:
Send: M228 S1 Z0
Recv: ok P31 B7
Send: M122
Recv: echo : Soft endstops : on
Recv: ok P31 B7
Non ho modo di modificarli dal firmware?
Edited 2 time(s). Last edit at 03/22/2020 05:55AM by lanjazz.
March 22, 2020 05:54AM
Non riesco a capire perché si settano a 10 quando il min è a 0...
Edited 1 time(s). Last edit at 03/22/2020 05:56AM by MagoKimbra.
March 22, 2020 05:57AM
MagoKimbra
Questo ho fatto.
Risultato questo:
Send: M228 S1 Z0
Recv: ok P31 B7
Send: M122
Recv: ok P31 B7
March 22, 2020 06:38AM
Una info in piu' Mago.
Facendo :
Send: M228 S1 X-10 (come dovrebbe essere)
Sull'asse X funziona:
Send: M122
Recv: Min : X-10.00 Y10.00 Z10.00 Max : X200.00 Y200.00 Z210.00
Recv: ok P31 B7
March 22, 2020 06:40AM
Non e' che devo forzare la modifica del MAX che ora mi da 210? probabilmente il software considera che la mia stampante e' 200 x 200 x 200?
Sono sceso e ho messo manualmente a 0 l'asse Z visto che il display segnava 0.
Poi ho mandato i comandi per i software_endstop max a 200 per X, 200 per Y e 180 per Z... ora il risultato e' questo:
Send: M122
Recv: echoconfused smileyoft endstopsyawning smileyn
Recv: Minangry smiley-10.00 Y-10.00 Z10.00 Maxangry smiley200.00 Y200.00 Z190.00
Recv: ok P31 B7
Boia mondo sti 10mm
Edited 4 time(s). Last edit at 03/22/2020 09:26AM by lanjazz.
March 22, 2020 09:56AM
Per ora fai cosi disabilita i software endstop con M122 S0, nel frattempo cerco di capire dov'è il problema, perché davvero non riesco a capire cosa succeda....
March 22, 2020 11:32AM
Va bene grazie mille.
Metti questo file in src/core/endstop/ sovrascrivendo il vecchio e ricompila...
Riprova a fare M122 e vediamo cosa succede...
open | download - endstops.cpp (31.9 KB)
March 22, 2020 11:53AM
Ora provo. Grazie
Dammi conferma che ogni volta che cambio qualcosa devo dare M502 e poi M500.... spero di si.... scusa
March 22, 2020 12:15PM
Funziona!!!!
Send: M122
Recv: Min : X-10.00 Y-10.00 Z0.00 Max : X200.00 Y200.00 Z180.00
Recv: ok P31 B7
Grazie Mago per il tempo che mi hai dedicato.
Una sola ultima conferma... se ora io dovessi cambiare firmware... non credo ma non si sa mai.... questo problema si ripresenta o si tratta di un fix che hai fatto e rimarra' a posto anche da compilatore?
Edited 2 time(s). Last edit at 03/23/2020 01:38AM by lanjazz.
