SD letta male o problemi di firmware ??? April 03, 2020 12:52PM |
Re: SD letta male o problemi di firmware ??? April 04, 2020 10:55AM |
Re: SD letta male o problemi di firmware ??? April 04, 2020 04:19PM |
Re: SD letta male o problemi di firmware ??? April 05, 2020 06:31AM |
Re: SD letta male o problemi di firmware ??? April 05, 2020 06:41PM |
Re: SD letta male o problemi di firmware ??? April 06, 2020 06:18AM |
Re: SD letta male o problemi di firmware ??? April 06, 2020 06:31AM |
Re: SD letta male o problemi di firmware ??? April 06, 2020 09:12AM |
;FLAVOR:Marlin ;TIME:1055 ;Filament used: 1.01057m ;Layer height: 0.2 ;MINX:135.98 ;MINY:114.159 ;MINZ:0.3 ;MAXX:174.02 ;MAXY:146.343 ;MAXZ:13.1 ;Generated with Cura_SteamEngine 4.5.0 M140 S20 M105 M190 S20 M104 S20 M105 M109 S20 M82 ;absolute extrusion mode G28 ;Home G1 Z15.0 F6000 ;Move the platform down 15mm
Re: SD letta male o problemi di firmware ??? April 06, 2020 05:14PM |
Re: SD letta male o problemi di firmware ??? April 07, 2020 02:43AM |
G1 X20.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line G1 X20.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
Re: SD letta male o problemi di firmware ??? April 09, 2020 06:36PM |
Re: SD letta male o problemi di firmware ??? April 10, 2020 04:43AM |
// Travel limits after homing (units are in mm) #define X_MIN_POS -50 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define X_MAX_POS 280 // con il piano in vetro completo 310 #define Y_MAX_POS 220// 280 con piano in vetro completo #define Z_MAX_POS 200
