Geeetech Prusa I3 Pro B Manual Bed leveling e Autohome problem April 27, 2020 04:31AM |
Re: Geeetech Prusa I3 Pro B Manual Bed leveling e Autohome problem April 28, 2020 07:54AM |
* The "Manual Probe" provides a means to do "Auto" Bed Leveling without a probe. * Use G29 repeatedly, adjusting the Z height at each point with movement commands * or (with LCD_BED_LEVELING) the LCD controller. */ //#define PROBE_MANUALLY //#define MANUAL_PROBE_START_Z 0.2 /**
#define NOZZLE_TO_PROBE_OFFSET { 10, 10, 0 } // Most probes should stay away from the edges of the bed, but // with NOZZLE_AS_PROBE this can be negative for a wider probing area. #define MIN_PROBE_EDGE 10
#define Z_PROBE_LOW_POINT -2 // Farthest distance below the trigger-point to go before stopping
#define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define X_MAX_POS X_BED_SIZE #define Y_MAX_POS Y_BED_SIZE #define Z_MAX_POS 200
//#define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10"
/ Manually set the home position. Leave these undefined for automatic settings. // For DELTA this is the top-center of the Cartesian print volume. //#define MANUAL_X_HOME_POS 0 //#define MANUAL_Y_HOME_POS 0 //#define MANUAL_Z_HOME_POS 0
