Insolito rumore dei motori January 02, 2015 06:24PM |
Re: Insolito rumore dei motori January 03, 2015 06:10PM |
Re: Insolito rumore dei motori January 03, 2015 06:20PM |
Re: Insolito rumore dei motori January 03, 2015 07:40PM |
Marcolinux
Sembra che a nessuno importi di questo post ....anche con 20 visualizzazioni nessuna risposta
Re: Insolito rumore dei motori January 04, 2015 02:05AM |
Re: Insolito rumore dei motori January 04, 2015 05:05AM |
Re: Insolito rumore dei motori January 05, 2015 10:57AM |
Re: Insolito rumore dei motori January 06, 2015 06:02AM |
Re: Insolito rumore dei motori January 06, 2015 10:15AM |
Re: Insolito rumore dei motori January 06, 2015 10:52AM |
Re: Insolito rumore dei motori January 06, 2015 01:21PM |
Re: Insolito rumore dei motori January 06, 2015 03:06PM |
Re: Insolito rumore dei motori January 08, 2015 10:04AM |
Re: Insolito rumore dei motori January 08, 2015 10:26AM |
#define DEFAULT_MAX_FEEDRATE #define DEFAULT_MAX_ACCELERATION
Re: Insolito rumore dei motori January 08, 2015 10:30AM |
Re: Insolito rumore dei motori January 08, 2015 02:34PM |
Re: Insolito rumore dei motori January 08, 2015 06:52PM |
Re: Insolito rumore dei motori January 09, 2015 08:50AM |
Re: Insolito rumore dei motori January 09, 2015 06:06PM |
Re: Insolito rumore dei motori January 10, 2015 10:22AM |
Re: Insolito rumore dei motori January 10, 2015 10:52AM |
#define X_STEP_PIN 54 #define X_DIR_PIN 55 #define X_ENABLE_PIN 38 #define X_MIN_PIN 3 #define X_MAX_PIN 2 #define Y_STEP_PIN 60 #define Y_DIR_PIN 61 #define Y_ENABLE_PIN 56 #define Y_MIN_PIN 14 #define Y_MAX_PIN 15 #define Z_STEP_PIN 46 #define Z_DIR_PIN 48 #define Z_ENABLE_PIN 62 #define Z_MIN_PIN 18 #define Z_MAX_PIN 19 #define E_STEP_PIN 26 #define E_DIR_PIN 28 #define E_ENABLE_PIN 24 #define Q_STEP_PIN 36 #define Q_DIR_PIN 34 #define Q_ENABLE_PIN 30 #define LED_PIN 13 #define FAN_PIN 9 #define PS_ON_PIN 12 #define nema17frequency 100 // 100 microsecondi void setup() { pinMode(FAN_PIN , OUTPUT); pinMode(LED_PIN , OUTPUT); pinMode(PS_ON_PIN, OUTPUT); analogWrite(PS_ON_PIN, LOW); pinMode(X_STEP_PIN, OUTPUT); pinMode(X_DIR_PIN, OUTPUT); pinMode(X_ENABLE_PIN, OUTPUT); pinMode(Y_STEP_PIN, OUTPUT); pinMode(Y_DIR_PIN, OUTPUT); pinMode(Y_ENABLE_PIN, OUTPUT); pinMode(Z_STEP_PIN, OUTPUT); pinMode(Z_DIR_PIN, OUTPUT); pinMode(Z_ENABLE_PIN, OUTPUT); pinMode(E_STEP_PIN, OUTPUT); pinMode(E_DIR_PIN, OUTPUT); pinMode(E_ENABLE_PIN, OUTPUT); pinMode(Q_STEP_PIN, OUTPUT); pinMode(Q_DIR_PIN, OUTPUT); pinMode(Q_ENABLE_PIN, OUTPUT); digitalWrite(X_ENABLE_PIN, LOW); digitalWrite(Y_ENABLE_PIN, LOW); digitalWrite(Z_ENABLE_PIN, LOW); digitalWrite(E_ENABLE_PIN, LOW); digitalWrite(Q_ENABLE_PIN, LOW); Serial.begin(115200); } unsigned long prevMillis; void loop () { if (millis() %1000 <500) digitalWrite(LED_PIN, HIGH); else digitalWrite(LED_PIN, LOW); if (millis() %1000 <300) { digitalWrite(FAN_PIN, LOW); } else { digitalWrite(FAN_PIN, HIGH); } if (millis() %2000 <1000) { digitalWrite(X_DIR_PIN , HIGH); digitalWrite(Y_DIR_PIN , HIGH); digitalWrite(Z_DIR_PIN , HIGH); digitalWrite(E_DIR_PIN , HIGH); digitalWrite(Q_DIR_PIN , HIGH); } else { digitalWrite(X_DIR_PIN , LOW); digitalWrite(Y_DIR_PIN , LOW); digitalWrite(Z_DIR_PIN , LOW); digitalWrite(E_DIR_PIN , LOW); digitalWrite(Q_DIR_PIN , LOW); } digitalWrite(X_STEP_PIN , HIGH); digitalWrite(Y_STEP_PIN , HIGH); digitalWrite(Z_STEP_PIN , HIGH); digitalWrite(E_STEP_PIN , HIGH); digitalWrite(Q_STEP_PIN , HIGH); delayMicroseconds(nema17frequency); digitalWrite(X_STEP_PIN , LOW); digitalWrite(Y_STEP_PIN , LOW); digitalWrite(Z_STEP_PIN , LOW); digitalWrite(E_STEP_PIN , LOW); digitalWrite(Q_STEP_PIN , LOW); }
Re: Insolito rumore dei motori January 10, 2015 11:40AM |
Re: Insolito rumore dei motori January 10, 2015 12:50PM |
Re: Insolito rumore dei motori January 10, 2015 04:49PM |
Re: Insolito rumore dei motori January 10, 2015 04:50PM |
