Sostituire A4988 con DRV8825 (su Ramps 1.4) [RISOLTO] February 06, 2014 10:11AM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 10:59AM |
Admin Registered: 11 years ago Posts: 954 |
The DRV8825 carrier was designed to be as similar to our A4988 stepper motor driver carriers as possible, and it can be used as a drop in replacement for the A4988 carrier in many applications because it shares the same size, pinout, and general control interface.
---- "Let me make my move" ---- |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 11:31AM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 12:39PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 12:42PM |
The pin used to supply logic voltage to the A4988 is used as the DRV8825’s FAULT output, since the DRV8825 does not require a logic supply (and the A4988 does not have a fault output). Note that it is safe to connect the FAULT pin directly to a logic supply (there is a 1.5k resistor between the IC output and the pin to protect it), so the DRV8825 module can be used in systems designed for the A4988 that route logic power to this pin.
The SLEEP pin on the DRV8825 is not pulled up by default like it is on the A4988, but the carrier board does connect it to the FAULT pin through a 10k resistor. Therefore, systems intended for the A4988 that route logic power to the FAULT pin will effectively have a 10k pull-up on the SLEEP pin. (This 10k resistor is not present on the initial (md20a) version of the DRV8825 carrier.)
The DRV8825 uses a different naming convention for the stepper motor outputs, but they are functionally the same as the corresponding pins on the A4988 carrier, so the same connections to both drivers result in the same stepper motor behavior. On both boards, the first part of the label identifies the coil (so you have coils “A” and “B” on the DRV8825 and coils “1” and “2” on the A4988).
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 01:11PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 02:08PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 02:15PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 02:26PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 03:06PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 03:10PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 03:11PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 06, 2014 03:20PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) February 07, 2014 07:33AM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) [RISOLTO] February 12, 2014 06:25AM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) [RISOLTO] February 12, 2014 06:44AM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) [RISOLTO] February 12, 2014 01:50PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) [RISOLTO] July 17, 2014 03:48PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) [RISOLTO] July 21, 2014 04:15PM |
Re: Sostituire A4988 con DRV8825 (su Ramps 1.4) [RISOLTO] July 22, 2014 11:47AM |
