Problema motori Prusa I3 [RISOLTO] April 03, 2014 04:51AM |
Re: Problema motori Prusa I3 April 03, 2014 06:15AM |
Re: Problema motori Prusa I3 April 03, 2014 07:49AM |
Re: Problema motori Prusa I3 April 03, 2014 07:54AM |
Re: Problema motori Prusa I3 April 03, 2014 07:56AM |
Re: Problema motori Prusa I3 April 03, 2014 08:46AM |
Re: Problema motori Prusa I3 April 03, 2014 10:26AM |
//// Calibration variables
// X, Y, Z, E steps per unit - Metric Prusa Mendel with Wade extruder:
#define _AXIS_STEP_PER_UNIT {32, 32, 1000,700}
// Metric Prusa Mendel with Makergear geared stepper extruder:
//#define _AXIS_STEP_PER_UNIT {80,80,3200/1.25,1380}
// MakerGear Hybrid Prusa Mendel:
// Z axis value is for .9 stepper(if you have 1.8 steppers for Z, you need to use 2272.7272)
//#define _AXIS_STEP_PER_UNIT {104.987, 104.987, 4545.4544, 1487}
//// MOVEMENT SETTINGS
const int NUM_AXIS = 4; // The axis order in all axis related arrays is X, Y, Z, E
#define _MAX_FEEDRATE {500, 500, 5, 45} // (mm/sec)
#define _HOMING_FEEDRATE {1500,1500,50} // (mm/min) !!
#define _AXIS_RELATIVE_MODES {false, false, false, false}
#define MAX_STEP_FREQUENCY 30000 // Max step frequency
//For the retract (negative Extruder) move this maxiumum Limit of Feedrate is used
//The next positive Extruder move use also this Limit,
//then for the next (second after retract) move the original Maximum (_MAX_FEEDRATE) Limit is used
#define MAX_RETRACT_FEEDRATE 100 //mm/sec
//// Acceleration settings
// X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define _ACCELERATION 1000 // Axis Normal acceleration mm/s^2
#define _RETRACT_ACCELERATION 2000 // Extruder Normal acceleration mm/s^2
#define _MAX_XY_JERK 20.0
#define _MAX_Z_JERK 0.4
#define _MAX_E_JERK 5.0 // (mm/sec)
//#define _MAX_START_SPEED_UNITS_PER_SECOND {25.0,25.0,0.2,10.0}
#define _MAX_ACCELERATION_UNITS_PER_SQ_SECOND {3000,3000,50,3000} // X, Y, Z and E max acceleration in mm/s^2 for printing moves or retracts
// Minimum planner junction speed. Sets the default minimum speed the planner plans for at the end
// of the buffer and all stops. This should not be much greater than zero and should only be changed
// if unwanted behavior is observed on a user's machine when running at very slow speeds.
#define MINIMUM_PLANNER_SPEED 0.05 // (mm/sec)
#define DEFAULT_MINIMUMFEEDRATE 0.0 // minimum feedrate
#define DEFAULT_MINTRAVELFEEDRATE 0.0
#define _MIN_SEG_TIME 20000
// If defined the movements slow down when the look ahead buffer is only half full
#define SLOWDOWN
const int dropsegments=5; //everything with less than this number of steps will be ignored as move and joined with the next movement
Re: Problema motori Prusa I3 April 03, 2014 11:20AM |
Questi sono valori assoluti, che vuol dire superiore a 1000?Quote
puoi provare a variarla da 5 a 2, per provare se va meglio, ma solo dopo aver settato i giusti step per X Y e ZQuote
Re: Problema motori Prusa I3 April 03, 2014 11:25AM |
Re: Problema motori Prusa I3 April 03, 2014 11:38AM |
Re: Problema motori Prusa I3 April 03, 2014 11:43AM |
Re: Problema motori Prusa I3 April 03, 2014 11:47AM |
Re: Problema motori Prusa I3 April 03, 2014 11:53AM |
Re: Problema motori Prusa I3 April 03, 2014 11:58AM |
Re: Problema motori Prusa I3 April 03, 2014 12:04PM |
Re: Problema motori Prusa I3 April 03, 2014 12:20PM |
Re: Problema motori Prusa I3 April 03, 2014 12:26PM |
Re: Problema motori Prusa I3 April 03, 2014 12:33PM |
Re: Problema motori Prusa I3 April 03, 2014 12:45PM |
Re: Problema motori Prusa I3 April 03, 2014 01:34PM |
#define _MAX_Z_JERK 0.4 // portalo a 0.2
Re: Problema motori Prusa I3 April 03, 2014 01:37PM |
Re: Problema motori Prusa I3 April 03, 2014 01:41PM |
Re: Problema motori Prusa I3 April 04, 2014 03:36AM |
Re: Problema motori Prusa I3 April 04, 2014 05:33AM |
Re: Problema motori Prusa I3 April 04, 2014 08:49AM |
Re: Problema motori Prusa I3 [RISOLTO] April 04, 2014 11:49AM |
Re: Problema motori Prusa I3 [RISOLTO] April 04, 2014 12:00PM |
