Ancora su enstop e firmware April 27, 2014 11:10AM |
// Uncomment the following line to enable CoreXY kinematics // #define COREXY // coarse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #endif // The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops. const bool Y_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops. const bool Z_ENDSTOPS_INVERTING = true; // set to true to invert the logic of the endstops. //#define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS // Disable max endstops for compatibility with endstop checking routine #if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS) #define DISABLE_MAX_ENDSTOPS #endif // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR false // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR true // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 180 #define X_MIN_POS 0 #define Y_MAX_POS 180 #define Y_MIN_POS 0 #define Z_MAX_POS 180 #define Z_MIN_POS 0 #define X_MAX_LENGTH (X_MAX_POS - X_MIN_POS) #define Y_MAX_LENGTH (Y_MAX_POS - Y_MIN_POS) #define Z_MAX_LENGTH (Z_MAX_POS - Z_MIN_POS) // The position of the homing switches //#define MANUAL_HOME_POSITIONS // If defined, MANUAL_*_HOME_POS below will be used //#define BED_CENTER_AT_0_0 // If defined, the center of the bed is at (X=0, Y=0) //Manual homing switch locations: // For deltabots this means top and center of the cartesian print volume. #define MANUAL_X_HOME_POS 0 #define MANUAL_Y_HOME_POS 0 #define MANUAL_Z_HOME_POS 0 //#define MANUAL_Z_HOME_POS 402 // For delta: Distance between nozzle and print surface after homing. //// MOVEMENT SETTINGS #define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E #define HOMING_FEEDRATE {50*60, 50*60, 2*60, 0} // set the homing speeds (mm/min)
Re: Ancora su enstop e firmware April 27, 2014 11:54AM |
Re: Ancora su enstop e firmware April 27, 2014 12:38PM |
#define X_HOME_DIR -1 #define Y_HOME_DIR -1in
#define X_HOME_DIR 1 #define Y_HOME_DIR 1
Re: Ancora su enstop e firmware April 27, 2014 01:35PM |
Re: Ancora su enstop e firmware April 27, 2014 01:42PM |
il boso
il cabinista dell'altro post sono io... sai il problema sorge dal fatto che nella guida della i3.. mette proprio x a dx e y davanti...
io quando avevo la i2 non ho mai avuto problemi con gli endstop... ora invece sono quelli che mi danno maggiori problemi... stavo quasi pensando di smontarli e rifare i collegamenti a sn e dietro..
Re: Ancora su enstop e firmware April 27, 2014 01:47PM |
Re: Ancora su enstop e firmware April 27, 2014 02:03PM |
Re: Ancora su enstop e firmware April 27, 2014 02:12PM |
BluBliz
Un'ultima cosa, l'estrusore gira al contrario, ho consumato qualche centimetro di PLA ma quando gli dico estrudi lui ritira e viceversa.
Risolvo settando a "false" #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false, o devo fare altro?
Grazie ancora
Re: Ancora su enstop e firmware April 27, 2014 02:56PM |
Re: Ancora su enstop e firmware April 28, 2014 02:36AM |
Re: Ancora su enstop e firmware April 28, 2014 05:13AM |
Re: Ancora su enstop e firmware April 29, 2014 02:44PM |
