Valori negativi temperatura heatbed [ RISOLTO ] August 01, 2014 09:23AM |
Re: Valori negativi temperatura heatbed August 01, 2014 09:55AM |
Re: Valori negativi temperatura heatbed August 01, 2014 10:57AM |
Re: Valori negativi temperatura heatbed August 01, 2014 11:06AM |
Re: Valori negativi temperatura heatbed August 01, 2014 11:14AM |
Re: Valori negativi temperatura heatbed August 01, 2014 11:18AM |
Re: Valori negativi temperatura heatbed August 01, 2014 11:19AM |
Re: Valori negativi temperatura heatbed August 01, 2014 11:23AM |
Re: Valori negativi temperatura heatbed August 01, 2014 11:30AM |
//=============================Thermal Settings ============================
// Set this if you want to define the constants in the thermistor circuit
// and work out temperatures algebraically - added by AB.
// See [en.wikipedia.org]
// BETA is the B value
// RS is the value of the series resistor in ohms
// R_INF is R0.exp(-BETA/T0), where R0 is the thermistor resistance at T0 (T0 is in kelvin)
// Normally T0 is 298.15K (25 C). If you write that expression in brackets in the #define the compiler
// should compute it for you (i.e. it won't need to be calculated at run time).
// If the A->D converter has a range of 0..1023 and the measured voltage is V (between 0 and 1023)
// then the thermistor resistance, R = V.RS/(1023 - V)
// and the temperature, T = BETA/ln(R/R_INF)
// To get degrees celsius (instead of kelvin) add -273.15 to T
// This DOES assume that all extruders use the same thermistor type.
#define BED_USES_THERMISTOR
#define HEATER_0_USES_THERMISTOR
#define HEATER_1_USES_THERMISTOR
#define HEATER_2_USES_THERMISTOR
#define ABS_ZERO -273.15
#define AD_RANGE 16383
#ifdef REPRAPPRO_HUXLEY
// Bed thermistor: VISHAY BC COMPONENTS NTCS0603E3104FXT - All Huxleys with heated bed PCB
#define BED_BETA 4100.0
#define BED_NTC 100000.0
// Extruder thermistor: RS 198-961 100k ohm 10% DO-35 NTC thermistor - All Huxleys before 25/2/14
// #define E_BETA 3960.0
// #define E_NTC 100000.0
// Extruder thermistor: Digikey 480-3137-ND - All Huxleys shipped after 25/2/14
#define E_BETA 4138.0
#endif
#ifdef REPRAPPRO_MENDEL
// Extruder thermistor: RS 198-961 100k ohm 10% DO-35 NTC thermistor - All Mendels before 1/4/13
//#define E_BETA 3960.0
// Bed thermistor: RS 484-0149; EPCOS B57550G103J - All Mendels before 1/4/13
#define BED_BETA 3480.0
#define BED_NTC 10000.0
#endif
#ifdef REPRAPPRO_MENDEL2
// Bed thermistor: Rapid 61-0446 ; Semitec 103GT-2 - All Mendel2 shipped after 1/4/13 (launch)
// #define BED_BETA 4126.0
// #define BED_NTC 10000.0
// Bed thermistor: Farnell 1299930 ; EPCOS B57863S103F040 - All Mendel2 shipped after 29/5/14
//#define BED_BETA 3988.0
// Extruder thermistor: RS 198-961 100k ohm 10% DO-35 NTC thermistor - All Mendel2 shipped after 1/4/13 (launch)
// Extruder thermistor: Digikey 480-3137-ND - All Mendels shipped after 25/2/14
#endif
#define E_RS SERIAL_R
#define E_R_INF ( E_NTC*exp(-E_BETA/298.15) )
#define BED_RS SERIAL_R
#define BED_R_INF ( BED_NTC*exp(-BED_BETA/298.15) )
Re: Valori negativi temperatura heatbed August 01, 2014 11:36AM |
Re: Valori negativi temperatura heatbed August 01, 2014 11:48AM |
Re: Valori negativi temperatura heatbed August 01, 2014 11:52AM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:07PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:12PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:13PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:21PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:26PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:28PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:39PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:42PM |
bilanciamist
respira e calmati, se già perdi la calma figurati al momento delle calibrazioni di fino.
nel caso in questione, nel tuo firmware sono attive solo queste definizioni:
perchè le altre sono inattive, dipende tutto dal comando #ifdef REPRAPPRO_MENDEL2, poichè la tua stampante è definita come #define REPRAPPRO_MENDEL2. Se le hanno messe devi lasciarle come stanno, semmai dovresti perdere un pò di tempo per dirci che stampante hai con precisione, e magari dove l'hai comprata.
Per capire se il modello selezionato nel firmware è giusto oppure no.
LE DO FUOCO SE NN PARTE AL VOLO!
Re: Valori negativi temperatura heatbed August 01, 2014 12:43PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:47PM |
Re: Valori negativi temperatura heatbed August 01, 2014 12:58PM |
#endif
Re: Valori negativi temperatura heatbed August 01, 2014 01:03PM |
Re: Valori negativi temperatura heatbed August 01, 2014 03:05PM |
lol
