errore m999 August 09, 2014 05:42AM |
Re: errore m999 August 09, 2014 06:01AM |
Moderator Registered: 12 years ago Posts: 964 |
Re: errore m999 August 09, 2014 06:06AM |
Re: errore m999 August 09, 2014 06:14AM |
Re: errore m999 August 09, 2014 06:27AM |
Re: errore m999 August 09, 2014 06:37AM |
Re: errore m999 August 09, 2014 07:02AM |
#if MOTHERBOARD == 35 #define HEATER_0_PIN 8 #else #define HEATER_0_PIN 10 // EXTRUDER 1 #endif #if MOTHERBOARD == 33 || MOTHERBOARD == 36 || MOTHERBOARD == 67 #define HEATER_1_PIN -1 #else #define HEATER_1_PIN 9 // EXTRUDER 2 (FAN On Sprinter) #endif #if MOTHERBOARD == 77 #define HEATER_0_PIN 10 #define HEATER_1_PIN 12 #define HEATER_2_PIN 6 #elif MOTHERBOARD == 68 #define HEATER_2_PIN 16 #define HEATER_3_PIN 17 #define HEATER_4_PIN 4 #define HEATER_5_PIN 5 #define HEATER_6_PIN 6 #define HEATER_7_PIN 11 #else #define HEATER_2_PIN -1 #endif #define TEMP_0_PIN 13 // ANALOG NUMBERING #define TEMP_1_PIN 15 // ANALOG NUMBERING
Re: errore m999 August 09, 2014 07:59AM |
Re: errore m999 August 09, 2014 08:19AM |
Re: errore m999 August 09, 2014 08:32AM |
Re: errore m999 August 09, 2014 08:43AM |
Re: errore m999 August 09, 2014 09:00AM |
Re: errore m999 August 09, 2014 10:21AM |
Re: errore m999 August 09, 2014 12:10PM |
Ivan Bortolin
Quando non si è esperti (ma anche quando lo si è, a maggior ragione), se si interviene sull'elettronica per fare manutenzione o altro, la tensione va SEMPRE tolta!!! Per quello sulle mie stampanti installo il bottone di emergenza.
Re: errore m999 August 09, 2014 12:20PM |
Re: errore m999 August 13, 2014 03:25AM |
