Backup Firmware scheda controllo October 10, 2014 11:57AM |
Re: Backup Firmware scheda controllo October 10, 2014 12:56PM |
Re: Backup Firmware scheda controllo October 10, 2014 01:43PM |
Re: Backup Firmware scheda controllo October 10, 2014 01:52PM |
Re: Backup Firmware scheda controllo October 10, 2014 02:10PM |
Re: Backup Firmware scheda controllo October 10, 2014 02:13PM |
Re: Backup Firmware scheda controllo October 11, 2014 04:36AM |
08:34:27.609 : OpenGL version:1.4.0 - Build 7.14.10.4926 08:34:27.609 : OpenGL extensions:GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_multitexture GL_ARB_point_parameters GL_ARB_shadow GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_EXT_cull_vertex GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_lod_bias GL_EXT_texture_filter_anisotropic GL_EXT_texture3D GL_3DFX_texture_compression_FXT1 GL_IBM_texture_mirrored_repeat GL_NV_blend_square GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_WIN_swap_hint 08:34:27.609 : OpenGL renderer:Intel 945GM 08:34:27.609 : Using fast VBOs for rendering is possible 08:34:33.781 : start 08:34:33.781 : echo: External Reset 08:34:33.781 : 1.0.0 08:34:33.781 : echo: Last Updated: Sep 19 2014 16:55:26 | Author: (none, default config) 08:34:33.781 : Compiled: Sep 19 2014 08:34:33.781 : echo: Free Memory: 3796 PlannerBufferBytes: 1232 08:34:33.781 : echo:Hardcoded Default Settings Loaded 08:34:33.781 : echo: Steps per unit: 08:34:33.781 : echo: M92 X80.50 Y80.50 Z406.00 E83.17 08:34:33.781 : echo:Maximum feedrates (mm/s): 08:34:33.781 : echo: M203 X500.00 Y500.00 Z5.00 E35.00 08:34:33.781 : echo:Maximum Acceleration (mm/s2): 08:34:33.781 : echo: M201 X5000 Y5000 Z90 E10000 08:34:33.781 : echo:Acceleration: S=acceleration, T=retract acceleration 08:34:33.781 : echo: M204 S950.00 T950.00 08:34:33.781 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 08:34:33.781 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 08:34:33.781 : echo:Home offset (mm): 08:34:33.781 : echo: M206 X0.00 Y0.00 Z0.00 08:34:33.781 : echo: PID settings: 08:34:33.781 : echo: M301 P22.20 I1.08 D114.00 08:34:37.203 : echo:No SD Card 08:34:37.265 : [www.sunhokey.com] Machine: Prusa I3 08:34:37.375 : echo:Active Extruder: 0 08:34:37.375 : Begin file list 08:34:37.390 : End file list --M503-- 08:36:03.765 : echo: Steps per unit: 08:36:03.765 : echo: M92 X80.50 Y80.50 Z406.00 E83.17 08:36:03.765 : echo:Maximum feedrates (mm/s): 08:36:03.765 : echo: M203 X500.00 Y500.00 Z5.00 E35.00 08:36:03.765 : echo:Maximum Acceleration (mm/s2): 08:36:03.765 : echo: M201 X5000 Y5000 Z90 E10000 08:36:03.765 : echo:Acceleration: S=acceleration, T=retract acceleration 08:36:03.765 : echo: M204 S950.00 T950.00 08:36:03.765 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 08:36:03.765 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 08:36:03.765 : echo:Home offset (mm): 08:36:03.765 : echo: M206 X0.00 Y0.00 Z0.00 08:36:03.765 : echo: PID settings: 08:36:03.765 : echo: M301 P22.20 I1.08 D114.00 --M501-- 08:37:19.578 : echo:Hardcoded Default Settings Loaded 08:37:19.656 : echo: Steps per unit: 08:37:19.656 : echo: M92 X80.50 Y80.50 Z406.00 E83.17 08:37:19.656 : echo:Maximum feedrates (mm/s): 08:37:19.656 : echo: M203 X500.00 Y500.00 Z5.00 E35.00 08:37:19.656 : echo:Maximum Acceleration (mm/s2): 08:37:19.656 : echo: M201 X5000 Y5000 Z90 E10000 08:37:19.656 : echo:Acceleration: S=acceleration, T=retract acceleration 08:37:19.656 : echo: M204 S950.00 T950.00 08:37:19.656 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 08:37:19.656 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 08:37:19.656 : echo:Home offset (mm): 08:37:19.656 : echo: M206 X0.00 Y0.00 Z0.00 08:37:19.656 : echo: PID settings: 08:37:19.656 : echo: M301 P22.20 I1.08 D114.00
Re: Backup Firmware scheda controllo October 11, 2014 04:43AM |
