Problemi auto livellamento December 08, 2014 02:30PM |
//============================= Bed Auto Leveling =========================== #define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) //DECOMMENTATO DA ME #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to pick the X and Y locations to probe: // - "grid" mode // Probe every point in a rectangular grid // You must specify the rectangle, and the density of sample points // This mode is preferred because there are more measurements. // It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You must specify the X & Y coordinates of all 3 points #define AUTO_BED_LEVELING_GRID // with AUTO_BED_LEVELING_GRID, the bed is sampled in a // AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_LEVELING_GRID // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 20 #define RIGHT_PROBE_BED_POSITION 170 #define BACK_PROBE_BED_POSITION 190 #define FRONT_PROBE_BED_POSITION 20 // set the number of grid points per dimension // I wouldn't see a reason to go above 3 (=9 probing points on the bed) #define AUTO_BED_LEVELING_GRID_POINTS 2 #else // not AUTO_BED_LEVELING_GRID // with no grid, just probe 3 arbitrary points. A simple cross-product // is used to esimate the plane of the print bed #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 20 #define ABL_PROBE_PT_3_X 170 #define ABL_PROBE_PT_3_Y 20 #endif // AUTO_BED_LEVELING_GRID // these are the offsets to the probe relative to the extruder tip (Hotend - Probe) #define X_PROBE_OFFSET_FROM_EXTRUDER -30.0 //VALORE ORIGINALE -25 #define Y_PROBE_OFFSET_FROM_EXTRUDER 6.00 //VALORE ORIGINALE -29 #define Z_PROBE_OFFSET_FROM_EXTRUDER -21.45 //VALORE ORIGINALE -12.35 #define Z_RAISE_BEFORE_HOMING 4 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 4000 // X and Y axis travel speed between probes, in mm/min //ORIGINALE 8000 #define Z_RAISE_BEFORE_PROBING 30 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 20 //How much the extruder will be raised when traveling from between next probing points //ORIGINALE 5 //If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk //The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it. // You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile. #define PROBE_SERVO_DEACTIVATION_DELAY 300 //If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z_SAFE_HOMING enabled!!! #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28) #endif #endif // ENABLE_AUTO_BED_LEVELING
Re: Problemi auto livellamento December 08, 2014 02:56PM |
Re: Problemi auto livellamento December 08, 2014 04:45PM |
Re: Problemi auto livellamento December 08, 2014 05:16PM |
Re: Problemi auto livellamento December 09, 2014 09:38AM |
Re: Problemi auto livellamento December 11, 2014 07:57AM |
Re: Problemi auto livellamento December 11, 2014 09:09AM |
Re: Problemi auto livellamento December 12, 2014 03:42AM |
Re: Problemi auto livellamento December 12, 2014 08:37AM |
Re: Problemi auto livellamento December 13, 2014 12:49PM |
Re: Problemi auto livellamento December 14, 2014 02:03PM |
Re: Problemi auto livellamento December 15, 2014 03:22PM |
Re: Problemi auto livellamento January 05, 2015 08:12AM |
Re: Problemi auto livellamento January 05, 2015 03:47PM |
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
Re: Problemi auto livellamento January 05, 2015 05:44PM |
Re: Problemi auto livellamento January 10, 2015 06:01AM |
Re: Problemi auto livellamento January 10, 2015 08:39AM |
#define HOMING_FEEDRATE {100*60,100*60,4*60,0} // set the homing speeds (mm/min)
#define XY_TRAVEL_SPEED 8000
Re: Problemi auto livellamento January 10, 2015 09:33AM |
Re: Problemi auto livellamento January 10, 2015 01:19PM |
Re: Problemi auto livellamento January 10, 2015 01:26PM |
Re: Problemi auto livellamento January 10, 2015 01:37PM |
