Regolazione assi con viti a ricircolo December 13, 2014 09:14AM |
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {200,200,3200,625,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit
#define DEFAULT_MAX_FEEDRATE {300,300,2,100,100,100,100} // X, Y, Z, E0, E1, E2, E3 (mm/sec)
#define DEFAULT_RETRACTION_MAX_FEEDRATE {110,110,110,110} // E0, E1, E2, E3 (mm/sec)
#define DEFAULT_MAX_ACCELERATION {500,500,50,500} // X, Y, Z, E maximum start speed for accelerated moves.
#define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Regolazione assi con viti a ricircolo December 13, 2014 09:25AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 09:38AM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,3200,625,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit
Re: Regolazione assi con viti a ricircolo December 13, 2014 09:44AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 09:53AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:01AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:19AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:24AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:32AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:33AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:37AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 11:12AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 11:14AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 01:52PM |
#define HOMING_FEEDRATE {20*60, 20*60, 4*60, 0} // set the homing speeds (mm/min)
#define DEFAULT_AXIS_STEPS_PER_UNIT {640,640,640,625,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit
#define X_MAX_POS 340 #define X_MIN_POS 0 #define Y_MAX_POS 340 #define Y_MIN_POS 0 #define Z_MAX_POS 340 #define Z_MIN_POS 0
Re: Regolazione assi con viti a ricircolo December 13, 2014 02:18PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 02:56PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 03:21PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 05:33PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 06:00PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 06:26PM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 06:40AM |
..... al momento non c'è ne trovano in vendita, ma se si cerca con google si trova il post di ebay vecchio e magari si possono richiedere a chi le vendeva. Riguardo all'elettronica io la uso proprio cosi, cioè con arduino per la stampa, con una interfaccia parallela con mach3 per l'incisione. In teoria ho visto che è possibile usare anche arduino per fresare utilizzando i file con una certa estensione, ma non ci riesco visto che il mio cad è vecchiotto e non mi da tale estensione. Comunque basta farsi uno spinotto unico con tutti i comandi per i driver esterni ed attaccarlo all'elettronica di controllo in base alle necessità, è un attimo.
Re: Regolazione assi con viti a ricircolo December 14, 2014 07:14AM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 09:40AM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 09:52AM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 03:45PM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 06:29PM |
Re: Regolazione assi con viti a ricircolo February 12, 2015 08:11AM |
Re: Regolazione assi con viti a ricircolo February 14, 2015 03:46PM |
