Relè su RAMPS 1.4 2015 January 23, 2015 06:56AM |
Re: RELE SU RAMPS 1.4 2015 January 26, 2015 05:04PM |
Re: RELE SU RAMPS 1.4 2015 January 27, 2015 05:10AM |
Re: RELE SU RAMPS 1.4 2015 January 27, 2015 08:48AM |
Re: RELE SU RAMPS 1.4 2015 January 27, 2015 08:57AM |
Re: RELE SU RAMPS 1.4 2015 January 27, 2015 09:56AM |
Moderator Registered: 13 years ago Posts: 1,865 |
Re: RELE SU RAMPS 1.4 2015 January 27, 2015 10:49AM |
ma concordo ke e na sch...
Re: RELE SU RAMPS 1.4 2015 January 27, 2015 11:01AM |
Re: RELE SU RAMPS 1.4 2015 January 27, 2015 11:11AM |
Re: RELE SU RAMPS 1.4 2015 January 27, 2015 11:24AM |
Re: RELE SU RAMPS 1.4 2015 January 28, 2015 07:59AM |
Re: RELE SU RAMPS 1.4 2015 January 28, 2015 10:58AM |
Re: RELE SU RAMPS 1.4 2015 January 28, 2015 11:49AM |
enricodare
schema a posto, ma la modifica al firmware per abilitare la modalità bangbang non te la toglie nessuno
Re: RELE SU RAMPS 1.4 2015 January 28, 2015 12:22PM |
Re: RELE SU RAMPS 1.4 2015 January 28, 2015 02:01PM |
Re: RELE SU RAMPS 1.4 2015 January 28, 2015 02:35PM |
// Bed Temperature Control
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// uncomment this to enable PID on the bed. It uses the same ferquency PWM as the extruder.
// If your PID_dT above is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don't understand the issues involved, you proabaly
// shouldn't use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delived to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn't use it unless you are OK with PWM on your bed. (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#ifdef PIDTEMPBED
//120v 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
//from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, argressive factor of .15 (vs .1, 1, 10)
#define DEFAULT_bedKp 10.00
#define DEFAULT_bedKi .023
#define DEFAULT_bedKd 305.4
//from pidautotune
// #define DEFAULT_bedKp 97.1
// #define DEFAULT_bedKi 1.41
// #define DEFAULT_bedKd 1675.16
// FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
Re: RELE SU RAMPS 1.4 2015 January 29, 2015 07:16AM |
Re: RELE SU RAMPS 1.4 2015 January 29, 2015 07:27AM |
Re: RELE SU RAMPS 1.4 2015 January 29, 2015 07:40AM |
Re: Relè su RAMPS 1.4 2015 January 29, 2015 06:51PM |
Admin Registered: 12 years ago Posts: 954 |
Re: RELE SU RAMPS 1.4 2015 February 24, 2015 06:25PM |
Questa mi giunge nuova che problemi dovrebbero portare usare un SSR ?Quote
BlackWolf80
Così mi chiedo in parole povere qual' é il metodo più affidabile e semplice (possibilmente senza toccare il firmware) io dal profondo della mia ignoranza in elettronica (e non lo dico per scherzo d'altronde sono un ragioniere :p ) opterei per il relè (gli SSR ho letto che possono dare problemi) voi cosa mi consigliate come soluzione?
Re: RELE SU RAMPS 1.4 2015 February 24, 2015 08:08PM |
saviothecnic
BlackWolf80
Credo sia piu affidabile un SSR che un rele che nel comandare un carico ha piu rischio di incollarsi
e poi essendo meccanico non supporta un ciclo veloce di attacca stacca in caso si comanda il piano in PWM
Io ho montato cosi foto sotto unica cosa che vi dico si deve collegare positivo diretto e negativo pilotato dal SSR
forse sara tecnologia NPN se si collega interompendo il positivo con negativo diretto non va
Nel caso del SSR non serve il diodo perche ovviamente non ci sono bobine che si caricano e danno extratensione al distacco
Invece in caso di rele ovviamente il diodo è utile manda in corto entratensioni inverse quando si stacca eccitazione bobina
Proprio ora stavo facendo una prova ma avendo messo il piano maggiorato da 240x311 e pcb riscaldante da 200x300 anche dopo 20 minuti acceso a ciucciare circa 11A overvoltato a 14V non arrivo a piu di 75°C
Quindi mi sa che devo passare ad alimentare a 24V il piano è gia predisposto a farlo so che la ramps potrebbe arrivarci con delle modifiche sapete quali ?
Questo è come ho messo io SSR
Grazie
Re: RELE SU RAMPS 1.4 2015 February 25, 2015 02:56AM |
Ok ho letto e mi sono tranquillizzatoQuote
BlackWolf80
QUI un esempio poi mi pare di aver letto altri problemi simili, mentre zero problemi con i relè meccanici, io appunto ho montato un 40A con diodo e va alla grande, il piano arriva in pochi minuti a temperatura e ci resta rock solid senza problemi, poi non saprei se gli SSR creano realmente problemi o meno ma ho preferito andare sul sicuro e collaudato.
Re: Relè su RAMPS 1.4 2015 February 25, 2015 10:22AM |
Re: Relè su RAMPS 1.4 2015 February 25, 2015 12:18PM |
Interessante trovo esempio foto di come è stato costruito un piano in questa maniera ?Quote
enricodare
serve per costruirsi un heatbed da soli, montandoli sotto un piano in alluminio
Re: Relè su RAMPS 1.4 2015 February 25, 2015 03:27PM |
Re: Relè su RAMPS 1.4 2015 February 26, 2015 02:28AM |
Re: Relè su RAMPS 1.4 2015 March 14, 2015 10:26AM |
Re: Relè su RAMPS 1.4 2015 March 17, 2015 06:38PM |
Re: Relè su RAMPS 1.4 2015 March 18, 2015 02:20PM |
