Re: auto livellamento asse Z August 14, 2015 04:03AM |
Re: auto livellamento asse Z August 14, 2015 09:52AM |
c11610o
Zlob
... Ho provato in tutte le maniere ma non c'e'verso di fare muovere l'asse Z oltre il finecorsa...
non puoi abbassarlo un po' il finecorsa? voler andare oltre quando sei appoggiato non credo sia molto saggio.
Re: auto livellamento asse Z August 15, 2015 10:07PM |
Re: auto livellamento asse Z August 16, 2015 05:19AM |
//#define Z_DUAL_STEPPER_DRIVERS
#if ENABLED(Z_DUAL_STEPPER_DRIVERS)
// Z_DUAL_ENDSTOPS is a feature to enable the use of 2 endstops for both Z steppers - Let's call them Z stepper and Z2 stepper.
// That way the machine is capable to align the bed during home, since both Z steppers are homed.
// There is also an implementation of M666 (software endstops adjustment) to this feature.
// After Z homing, this adjustment is applied to just one of the steppers in order to align the bed.
// One just need to home the Z axis and measure the distance difference between both Z axis and apply the math: Z adjust = Z - Z2.
// If the Z stepper axis is closer to the bed, the measure Z > Z2 (yes, it is.. think about it) and the Z adjust would be positive.
// Play a little bit with small adjustments (0.5mm) and check the behaviour.
// The M119 (endstops report) will start reporting the Z2 Endstop as well.
#define Z2_STEP_PIN E2_STEP_PIN // Stepper to be used to Z2 axis.
#define Z2_DIR_PIN E2_DIR_PIN
#define Z2_ENABLE_PIN E2_ENABLE_PIN
// #define Z_DUAL_ENDSTOPS
#if ENABLED(Z_DUAL_ENDSTOPS)
#define Z2_MAX_PIN 36 //Endstop used for Z2 axis. In this case I'm using XMAX in a Rumba Board (pin 36)
const bool Z2_MAX_ENDSTOP_INVERTING = false;
#define DISABLE_XMAX_ENDSTOP //Better to disable the XMAX to avoid conflict. Just rename "XMAX_ENDSTOP" by the endstop you are using for Z2 axis.
#endif
#endif // Z_DUAL_STEPPER_DRIVERS
Re: auto livellamento asse Z August 16, 2015 08:02AM |
Re: auto livellamento asse Z August 16, 2015 09:07AM |
Re: auto livellamento asse Z August 16, 2015 09:09AM |
Re: auto livellamento asse Z August 16, 2015 09:33AM |
#define Z2_STEP_PIN E2_STEP_PIN // Stepper to be used to Z2 axis. #define Z2_DIR_PIN E2_DIR_PIN #define Z2_ENABLE_PIN E2_ENABLE_PIN
Re: auto livellamento asse Z August 25, 2015 01:48PM |
Re: auto livellamento asse Z August 25, 2015 04:35PM |
Re: auto livellamento asse Z August 29, 2015 02:44PM |
Re: auto livellamento asse Z September 17, 2015 02:11PM |
saviothecnic
Quindi ricapitolando quando si usa un prossimetro si deve disaliblitare la rete di PullUP commentando questa righa//#define ENDSTOPPULLUP_ZMIN
E in caso di PNP si deve invertire la logica con questo comando di vero e falso
const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop.
Magari Mago nel tuo autoconfiguratore alla domanda se vuoi usare un Autolivellamento di Z puoi aggiungere Usi Prossimetro o ServoComando e se usi un prossimetro PNP o NPN
e di conseguenza cambiare queste righe potrebbe essere comodo per i meno pratici
Ora manca solo un stl per montare il prossimetro sulla mia R2 e ci sono
ora non mi resta che montarlo e fare la mod quotata. ...o nel frattempo è cambiato qualcosa?
Re: auto livellamento asse Z September 17, 2015 04:56PM |
Re: auto livellamento asse Z October 26, 2015 09:07AM |
Re: auto livellamento asse Z October 26, 2015 09:19AM |
Se usi il PiBot magari è meglio seguire questo topicQuote
ManuHC
Grazie della ricapitolazione. Stavo proprio cercando un post che rispiegasse tutte le nozioni dateora non mi resta che montarlo e fare la mod quotata.
Forse io ieri ho configurato tutto con autoconfiguratore on line come da schermata sottoQuote
ManuHC
Re: auto livellamento asse Z November 01, 2015 05:33AM |
So che è già stato detto, ma non riesco a capire...|
Re: auto livellamento asse Z November 04, 2015 03:11AM |
Re: auto livellamento asse Z November 13, 2015 01:30AM |
corso_shiba
Si è vero però siccome quello è lo schema per chi usa la 12v quindi non l'ho preso in considerazione e rimosso dal mio ragionamento
alla fine mi è venuto fuori lo schema uguale a quello che hai postato tu solo che è adatto a PNP con alimentazione 5v
per la resistenza interna avevo già seguito il tuo consiglio
[attachment 51088 SensorePNP.png]
Re: auto livellamento asse Z November 13, 2015 01:32AM |
saviothecnic
ManuHC
ManuHC
[attachment 64702 SetupAutoLivellamentoZ.jpg]
Re: auto livellamento asse Z November 13, 2015 02:03AM |
Meglio tardi che Mai se usi il PiBot non ti serve le resistenze perche lo alimenti a 5VQuote
ManuHC
Anche se in astronomico ritardo Savio oggi provo a configurare il tutto come nella screenshot ..
Quello che mi rende ancora titubante è il discorso resistenze....
sotto una foto di come ho assemblato al volo|
Re: auto livellamento asse Z November 13, 2015 02:21AM |
saviothecnic
ManuHC
se usi il prossimetro dato che lavorano meglio a 12 24V allora si perche devi portare quindi abbassare la tensione d' uscita pari alla 5V arduino
io per fare una cosa sicura e non appesantire le linee alim 5V di arduino e ramps ho usato un 7805CT per alimentare Pibot uso il CT perche
ci alimento anche i rele e il RaspBerry e altre cosesotto una foto di come ho assemblato al volo
Re: auto livellamento asse Z November 13, 2015 03:27AM |
Detta in parole povere è un componente che abassa la tensione d'ingresso a 5VQuote
ManuHC
Onestamente questo 7805CT non so cosa sia ....
Re: auto livellamento asse Z November 13, 2015 03:33AM |
saviothecnic
ManuHC
Se vuoi un consiglio compra il PiBot o i cloni costa poco è leggero poco ingombrante e ti faciliti la vita
Io avevo il prosismetro ed ho abbandonato quindi non so consigliarti per quella strada dato che come detto su ho desistito a favore del PiBot
Re: auto livellamento asse Z November 13, 2015 04:35AM |
Esatto il Mago ha la tua stessa scheda quindi ti sa dire sul montaggio e setup fwQuote
ManuHC
Con il pibot quindi non devo aggiungere alcuna resistenza ma solamente collegarlo al posto della Zmin e settare il tutto nel configuration online come nella tua screen?
Questo è il montaggio ma poi la calibrazione dello stesso come va eseguita?
Ammetendo sia già fissato come da video del Mago..
Re: auto livellamento asse Z November 13, 2015 04:46AM |
saviothecnic
ManuHC
Io ho Collegato su Ymax e Xmax perche Zmin e Mmax gli tengo liberi per LCD seriale tanto poi lo definisci su FW
Ho tenuto sia il PiBot che il finecorsa meccanico per sicurezza infatti ho la config probe e EndStop Z nella mia schermata postata
Io ho fatto cosi ho montato il Pibot regolato il potenziometro che acendesse la lampadina blu a circa 10mm tra HE e il piatto il Pibot fisicamente a me è a circa 10mm sopra HE quindi totale lettura circa 15 20mm poi sono andato a definire offset nel fw finche non mi sono trovato che con Z al minimo sto hai famosi 0,5mm dal piano
Re: auto livellamento asse Z November 13, 2015 04:54AM |
Il meccanico è passivo ha solo due fili il PiBot è attivo quindi devi alimentarlo tre fili + - e uscita se il tuo connettore è a tre fili OKQuote
ManuHC
Se il collegamento è pari ad un endstop meccanico non ho nemmeno da sconvolgere fili o connettori se ho capito bene.
Re: auto livellamento asse Z November 13, 2015 04:56AM |
saviothecnic
ManuHC
non devi scablare nulla occhio alla sequenza dei fili nel connettore se vedi il tipoc del PiBot che ti ho citato qualche messy sopra li ho postato le foto di come ho collegato
Re: auto livellamento asse Z June 18, 2016 05:18AM |
Re: auto livellamento asse Z June 19, 2016 05:08AM |
Re: auto livellamento asse Z June 19, 2016 07:48AM |
