Re: PiBot Optical Reflection Endstop September 07, 2015 09:16AM |
Re: PiBot Optical Reflection Endstop September 07, 2015 11:20AM |
Re: PiBot Optical Reflection Endstop September 07, 2015 11:21AM |
17:15:13.953 : echo: M48 Z-Probe Repeatability test 17:15:16.517 : echo: Positioning the probe... 17:15:23.156 : echo: x: -2.00 y: 67.96 17:15:23.776 : echo: x: -2.00 y: 250.00 17:15:24.917 : echo: x: -2.00 y: 250.00 17:15:24.927 : echo: x: -2.00 y: 250.00 17:15:30.334 : echo: 1 of 10 samples 17:15:30.334 : echo: z: 2.029063 mean: 2.029063 sigma: 0.000000 17:15:32.914 : echo: x: 66.97 y: 24.75 17:15:33.264 : echo: x: 79.67 y: 18.01 17:15:33.394 : echo: x: 84.80 y: 15.81 17:15:33.474 : echo: x: -2.00 y: -13.00 17:15:38.975 : echo: 2 of 10 samples 17:15:38.995 : echo: z: 2.056875 mean: 2.042969 sigma: 0.013906 17:15:41.565 : echo: x: -2.00 y: -13.00 17:15:42.356 : echo: x: -2.00 y: -13.00 17:15:42.356 : echo: x: -2.00 y: -13.00 17:15:42.356 : echo: x: -2.00 y: -13.00 17:15:47.197 : echo: 3 of 10 samples 17:15:47.197 : echo: z: 2.199375 mean: 2.095104 sigma: 0.074600 17:15:49.747 : echo: x: 86.50 y: 80.99 17:15:49.877 : echo: x: -2.00 y: 250.00 17:15:51.056 : echo: x: -2.00 y: 250.00 17:15:51.056 : echo: x: -2.00 y: 250.00 17:15:56.482 : echo: 4 of 10 samples 17:15:56.482 : echo: z: 2.020000 mean: 2.076328 sigma: 0.072329 17:15:59.072 : echo: x: 190.00 y: 250.00 17:16:00.332 : echo: x: 190.00 y: 250.00 17:16:00.352 : echo: x: 190.00 y: 250.00 17:16:00.362 : echo: x: 190.00 y: 250.00 17:16:05.764 : echo: 5 of 10 samples 17:16:05.774 : echo: z: 1.986875 mean: 2.058437 sigma: 0.073929 17:16:08.366 : echo: x: 190.00 y: 250.00 17:16:09.646 : echo: x: 190.00 y: 250.00 17:16:09.646 : echo: x: 190.00 y: 250.00 17:16:09.646 : echo: x: 190.00 y: 250.00 17:16:15.056 : echo: 6 of 10 samples 17:16:15.056 : echo: z: 2.000000 mean: 2.048698 sigma: 0.070914 17:16:17.646 : echo: x: 190.00 y: -13.00 17:16:18.447 : echo: x: 190.00 y: -13.00 17:16:18.447 : echo: x: 190.00 y: -13.00 17:16:18.447 : echo: x: 190.00 y: -13.00 17:16:23.376 : echo: 7 of 10 samples 17:16:23.376 : echo: z: 2.001563 mean: 2.041964 sigma: 0.067694 17:16:25.966 : echo: x: 136.69 y: 78.64 17:16:26.286 : echo: x: 190.00 y: 250.00 17:16:27.404 : echo: x: 190.00 y: 250.00 17:16:27.404 : echo: x: 190.00 y: 250.00 17:16:32.834 : echo: 8 of 10 samples 17:16:32.834 : echo: z: 1.990312 mean: 2.035508 sigma: 0.065586 17:16:35.425 : echo: x: 190.00 y: 250.00 17:16:36.705 : echo: x: 190.00 y: 250.00 17:16:36.705 : echo: x: 190.00 y: 250.00 17:16:36.705 : echo: x: 190.00 y: 250.00 17:16:42.126 : echo: 9 of 10 samples 17:16:42.146 : echo: z: 1.950000 mean: 2.026007 sigma: 0.067422 17:16:44.737 : echo: x: 135.37 y: 102.71 17:16:45.097 : echo: x: 190.00 y: 250.00 17:16:46.091 : echo: x: 190.00 y: 250.00 17:16:46.091 : echo: x: 190.00 y: -13.00 17:16:52.606 : echo: 10 of 10 samples 17:16:52.626 : echo: z: 2.044063 mean: 2.027813 sigma: 0.064191 17:16:56.187 : Mean: 2.027813 17:16:56.187 : Standard Deviation: 0.064191
Re: PiBot Optical Reflection Endstop September 07, 2015 11:42AM |
Re: PiBot Optical Reflection Endstop September 07, 2015 11:51AM |
Io ho trovato linee sulla ramps deboli e quindi do deciso d'alimentare tutto da fuoriQuote
mdcompositi
tu come lo alimenti sulla ramps?
Re: PiBot Optical Reflection Endstop September 07, 2015 11:53AM |
Re: PiBot Optical Reflection Endstop September 07, 2015 11:57AM |
bilanciamist
Ho ordinato 2 pibot, e sto aspettando che arrivino, comunque qualche tempo fa ho lavorato con i fotosensori come quello montato sul pibot, e so che funzionano meglio e a maggiore distanza se sono "incapsulati" cioè chiusi all'interno di una scatola (ovviamente con il lato dei sensori aperto).
Re: PiBot Optical Reflection Endstop September 07, 2015 12:14PM |
Re: PiBot Optical Reflection Endstop September 07, 2015 12:23PM |
Re: PiBot Optical Reflection Endstop September 07, 2015 12:44PM |
Re: PiBot Optical Reflection Endstop September 08, 2015 03:47AM |
Re: PiBot Optical Reflection Endstop September 08, 2015 04:06AM |
Re: PiBot Optical Reflection Endstop September 08, 2015 04:49AM |
scusa ma nemmeno io pensavo a questa banalità ( è proprio qui è stato l'errore!!)Quote
saviothecnic
Per questo ti avevo chiesto le foto di come avevi cablato nella totalità
e ti avevo detto di verificare se non avevi messo su Z max ansiche Min quei connettori tutti vicini è facile sbagliare ma tu hai perseverato
Vabe tutto bene quel che finisce bene
Facci sapere come ti trovi a livello di precisione non vedo l'ora che mi arrivino
Re: PiBot Optical Reflection Endstop September 08, 2015 05:25AM |
Re: PiBot Optical Reflection Endstop September 08, 2015 05:47AM |
scusa ancora, e grazie per la tua solita disponibilità!Quote
MagoKimbra
Scuse accettate (con l'accetta che vorrei darti sul capocollo) perché almeno hai ammesso l'errore a differenza di altri che non rispondono più... Però stiamo attenti su ste cose perché diventate e fate diventare matti anche gli altri....
Via forum non è facile trovare un problema, il massimo che si può fare è fare domande, che più delle volte hanno risposte, ma dopo un pò e bisogna poi ricollegare il tutto ricordandosi di che cosa si stava parlando quindi è facile perdersi in banalità...
Cmq a parte il pilotto, meglio aver trovato il problema e che non era una rottura del modulo o di arduino...
Re: PiBot Optical Reflection Endstop September 08, 2015 08:49AM |
Re: PiBot Optical Reflection Endstop September 08, 2015 11:01AM |
Re: PiBot Optical Reflection Endstop September 08, 2015 10:42PM |
Vengo alla domanda , la distanza in questo caso il sensore la sta prendendo sul bianco o sulla parte superiore del vetro(parte riflessa ?
Re: PiBot Optical Reflection Endstop September 11, 2015 06:44AM |
Re: PiBot Optical Reflection Endstop September 11, 2015 07:55AM |
Re: PiBot Optical Reflection Endstop September 11, 2015 09:22AM |
Scusa questa cosa non l'ho capita mi spieghi meglio le differenze pratiche tra i due modi ?Quote
MagoKimbra
Innanzitutto devi attivare lo z-safe homing, che serve appunto a fare lo zero di Z sul piatto e non sulle home di X e Y..
Ok non sapevo che era un parametro settabile credevo fosse da regolare la distanza del prossimetro o sensore ottico meglio cosi è sicuramente piu facileQuote
MagoKimbra
La sonda la metti dove vuoi rispetto al nozzle, poi setterai l'offset per fare in modo a Z zero il nozzle sia a 0.05 dal piatto...
Re: PiBot Optical Reflection Endstop September 11, 2015 10:08AM |
Re: PiBot Optical Reflection Endstop September 11, 2015 12:52PM |
MagoKimbra
Quindi si attiva Z safe homing. a questo punto il FW quando fa la home, prima fa le home di X e Y e poi sposta il carrello nel centro o alle misure date in Z safe homing X point e Z safe homing Y point e a quel punto fa lo zero di Z.Quote
MagoKimbra
Ok adesso ho capito tutto chiaro
Il Piatto e 240x311 ho quello maggiorato ma come in questa foto quando è a 0 ho la X gia a 10mm piu avanti sul pianoQuote
MagoKimbra
Per quanto riguarda i parametri, ho visto che hai messo 10 come X min...
Quando fai lo zero X deve essere 0, ora se il nozzle è fuori dal piatto non devi mettere 10, ma gli devi dire che sei negativo rispetto allo zero che è l'inizio del piatto...
Poi se il piatto è largo 200 il massimo è 200 in questo modo il centro è 100
e la Y 22mm indeitro nella foto ho avanzato per far capire
Pero la Y è giusto a -22 quando è a Home dato che è 22mm prima del inizio piatot esatto ?
www.saviot.com Stampante Prusa I3 R2.2 By Nicola P.
Ramps 1.4 Con FW MarlinKimba Fusore HE IeC 1.75mm Con Flusso Canalizzatore Estrusori BullDog XL
Piano maggiorato 240*311mm pilotato da SSR 24V con letto scaldante autocostruito
Lavori in Corso Prossimetro Autolivellamento Z Gestione Remota Raspberry PI 2 con OctoPrint
Rilevamento ottico Fine Filo Illuminazione e Visione AreaStampa Remotata In costruzione Trafilatore TL-Plastic
Re: PiBot Optical Reflection Endstop September 11, 2015 02:09PM |
Re: PiBot Optical Reflection Endstop September 23, 2015 06:48PM |
Re: PiBot Optical Reflection Endstop September 24, 2015 03:09AM |
Re: PiBot Optical Reflection Endstop September 24, 2015 04:39AM |
Alberto montata cosi se alzi troppo Z rischi che si rompe tra frame e carrello meglio averlo di lato o avantiQuote
MagoKimbra
Poi appena finisco la evo provo il carrello con il pibot integrato...
Re: PiBot Optical Reflection Endstop September 24, 2015 05:21AM |
Re: PiBot Optical Reflection Endstop September 24, 2015 06:26AM |
Ecco allora avevate già fatto sta cosa e io non avevo capitoQuote
MagoKimbra
Per quanto riguarda gli endstop già c'è, se attivi z_probe per la cartesiana o core è in più rispetto allo z-min,
quindi se metti la zprobe su z-max e lasci l'endstop classico su z-min diventa automaticamente l'endstop di emergenza..
