Re: Radds 1.5 elettronica a 32Bit July 05, 2016 05:30PM |
Re: Radds 1.5 elettronica a 32Bit July 05, 2016 05:34PM |
Re: Radds 1.5 elettronica a 32Bit July 05, 2016 05:36PM |
Re: Radds 1.5 elettronica a 32Bit July 05, 2016 05:37PM |
Re: Radds 1.5 elettronica a 32Bit July 06, 2016 04:39AM |
Re: Radds 1.5 elettronica a 32Bit July 23, 2016 04:03AM |
Re: Radds 1.5 elettronica a 32Bit July 23, 2016 06:22AM |
Re: Radds 1.5 elettronica a 32Bit July 24, 2016 05:37AM |
Re: Radds 1.5 elettronica a 32Bit July 24, 2016 05:53AM |
Re: Radds 1.5 elettronica a 32Bit July 24, 2016 11:56AM |
Re: Radds 1.5 elettronica a 32Bit July 24, 2016 12:13PM |
Re: Radds 1.5 elettronica a 32Bit July 24, 2016 12:20PM |
Re: Radds 1.5 elettronica a 32Bit July 24, 2016 12:28PM |
Re: Radds 1.5 elettronica a 32Bit July 24, 2016 01:05PM |
rinter halted. kill() called!|
Re: Radds 1.5 elettronica a 32Bit July 24, 2016 01:10PM |
Re: Radds 1.5 elettronica a 32Bit July 25, 2016 05:15AM |
MK42 401
#define ORIG_TEMP_BED_PIN 4 // ANALOG NUMBERING #57
#define ORIG_TEMP_0_PIN 7 // ANALOG NUMBERING #54
#define ORIG_TEMP_1_PIN 3 // ANALOG NUMBERING #58
#define ORIG_TEMP_2_PIN 6 // ANALOG NUMBERING #55
#define ORIG_TEMP_3_PIN 5 // ANALOG NUMBERING #56
Repetier 402
// Note that on the Due pin A0 on the board is channel 2 on the ARM chip
#define HEATER_0_PIN 13
// Due analog pin #54
#define TEMP_0_PIN 7
#define HEATER_1_PIN 7
#define TEMP_1_PIN 3
// Due analog pin #58
#define HEATER_2_PIN 12
// Due analog pin #55
#define TEMP_2_PIN 6
#define HEATER_3_PIN 11
// Due analog pin #56
#define TEMP_3_PIN 5
// Due analog pin #57
#define TEMP_4_PIN 4
Re: Radds 1.5 elettronica a 32Bit July 25, 2016 02:50PM |
#define ORIG_TEMP_BED_PIN 4 // ANALOG NUMBERING #57 #define ORIG_TEMP_0_PIN 0 // ANALOG NUMBERING #54 #define ORIG_TEMP_1_PIN 1 // ANALOG NUMBERING #58 #define ORIG_TEMP_2_PIN 2 // ANALOG NUMBERING #55 #define ORIG_TEMP_3_PIN 3 // ANALOG NUMBERING #56
Re: Radds 1.5 elettronica a 32Bit July 25, 2016 03:35PM |
Re: Radds 1.5 elettronica a 32Bit July 25, 2016 03:50PM |
Re: Radds 1.5 elettronica a 32Bit July 25, 2016 03:56PM |
Re: Radds 1.5 elettronica a 32Bit July 27, 2016 05:44AM |
Re: Radds 1.5 elettronica a 32Bit July 27, 2016 07:11AM |
pieri70
E' possibile fare un collegamento come quello in figura?
Re: Radds 1.5 elettronica a 32Bit July 27, 2016 07:52AM |
If you want to be a bit more accurate, or if you have cable sizes other than the standard tri-rated ones listed above, you can calculate the minimum cable size yourself.
To ensure a voltage drop of no more than 5% (1.2V), the formula is:
Minimum cable area (in mm2) = 0.0273 x current (in A) x length (in m)
Again, the length here is the distance from the battery to the appliance only, and not all the way back again.
Result
Voltage drop: 0.17
Voltage drop percentage: 0.71%
Voltage at the end: 23.83
Re: Radds 1.5 elettronica a 32Bit August 02, 2016 01:03PM |
Re: Radds 1.5 elettronica a 32Bit August 02, 2016 01:36PM |
Re: Radds 1.5 elettronica a 32Bit August 04, 2016 01:32PM |
Re: Radds 1.5 elettronica a 32Bit September 12, 2016 03:06PM |
Re: Radds 1.5 elettronica a 32Bit September 13, 2016 09:41AM |
lexbay813
Salve, vorrei utilizzare un lettore di schede esterno alla Radds....avete uno schema di come potrei fare i collegamenti? E come dovrei settare il Marlinkimbra?(come display uso il nextion)
Grazie
Re: Radds 1.5 elettronica a 32Bit September 14, 2016 11:02AM |
Re: Radds 1.5 elettronica a 32Bit September 14, 2016 11:40AM |
