Re: Ultratronics - LCD e info varie July 14, 2016 01:35PM |
Re: Ultratronics - LCD e info varie July 14, 2016 02:18PM |
Re: Ultratronics - LCD e info varie July 14, 2016 03:24PM |
Re: Ultratronics - LCD e info varie July 14, 2016 03:55PM |
Re: Ultratronics - LCD e info varie July 14, 2016 05:19PM |
Re: Ultratronics - LCD e info varie July 15, 2016 01:09AM |
Re: Ultratronics - LCD e info varie July 15, 2016 02:15AM |
Re: Ultratronics - LCD e info varie July 15, 2016 02:23AM |
Re: Ultratronics - LCD e info varie July 15, 2016 02:39AM |
Re: Ultratronics - LCD e info varie July 15, 2016 03:01PM |
Re: Ultratronics - LCD e info varie July 15, 2016 06:17PM |
Dovrebbe essere il mio stesso modello, io l'ho preso dal sito ufficiale però.Quote
qsecofr
Paso scusa una domanda: il tuo display quanti pollici l'hai preso?
Questo potrebbe andare secondo te?
[www.amazon.com]
La SD presente sul display serve solo ad installare il firmware nel display, poi non serve più; quindi per i gcode uso quella dell'Ultratronics.Quote
qsecofr
altra domanda: vedo che c'è integrata una sd ? si usa quella del lcd o quella integrata?
Re: Ultratronics - LCD e info varie July 16, 2016 02:04AM |
Re: Ultratronics - LCD e info varie July 16, 2016 02:56AM |
Re: Ultratronics - LCD e info varie July 16, 2016 03:14AM |
#define SDSUPPORT // Enable SD Card Support in Hardware Console //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SDEXTRASLOW // Use even slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication //#define SD_EXTENDED_DIR // Show extended directory including file length. Don't use this with Pronterface //#define SD_DISABLED_DETECT #define SD_DETECT_INVERTED #define SD_FINISHED_STEPPERRELEASE true //if sd support and the file is finished: disable steppers? #define SD_FINISHED_RELEASECOMMAND "M84 X Y Z E" // You might want to keep the z enabled so your bed stays in place. #define SDCARD_RATHERRECENTFIRST //reverse file order of sd card menu display. Its sorted practically after the file system block order. //#define MENU_ADDAUTOSTART //#define SD_SETTINGS // Uncomment to enable #define SD_CFG_SECONDS 300 // seconds between update #define CFG_SD_FILE "INFO.CFG" // name of the configuration fileNon ricordo se ho fatto modifiche con il configuratore online, d'altrone la SD è già presente sulla board.
Re: Ultratronics - LCD e info varie July 16, 2016 01:12PM |
Re: Ultratronics - LCD e info varie July 16, 2016 01:33PM |
Re: Ultratronics - LCD e info varie July 16, 2016 01:46PM |
Re: Ultratronics - LCD e info varie July 16, 2016 01:49PM |
Re: Ultratronics - LCD e info varie July 16, 2016 02:07PM |
Re: Ultratronics - LCD e info varie July 16, 2016 02:37PM |
Re: Ultratronics - LCD e info varie July 16, 2016 04:07PM |
cicciom
ma deve essere fat o fat32 il filesystem della scheda?
però la cosa strana è che i pin sono corretti sul fw ed impostando lo stesso con cardinfo immediatamente legge tutti i file della sd
Re: Ultratronics - LCD e info varie July 16, 2016 08:15PM |
Re: Ultratronics - LCD e info varie July 16, 2016 09:19PM |
Re: Ultratronics - LCD e info varie July 17, 2016 04:59AM |
Re: Ultratronics - LCD e info varie July 17, 2016 06:05AM |
Re: Ultratronics - LCD e info varie July 17, 2016 06:34AM |
Re: Ultratronics - LCD e info varie July 18, 2016 01:36AM |
Re: Ultratronics - LCD e info varie July 18, 2016 01:49AM |
Re: Ultratronics - LCD e info varie July 18, 2016 02:01AM |
Re: Ultratronics - LCD e info varie July 18, 2016 02:29AM |
