Re: Ultratronics - LCD e info varie July 20, 2016 10:31AM |
Re: Ultratronics - LCD e info varie July 20, 2016 11:19AM |
ok, grazie, poi man mano controllo!Quote
cicciom
che io sappia per il bed si usa il t0 come sensore e mentre gli altri puoi usi t1, t2 t... ma cmq dovresti metterli nel fw i pin di riferimento
Re: Ultratronics - LCD e info varie July 20, 2016 11:35AM |
Re: Ultratronics - LCD e info varie July 20, 2016 11:40AM |
si , quella contrassegnata usbp, solo che quando collego l'USB , il pc non la vede, e non si accendono neanche i led di power!!, i driver li ho messi bene?Quote
cicciom
per mandare il software devi mettere la program port
Re: Ultratronics - LCD e info varie July 20, 2016 12:06PM |
Re: Ultratronics - LCD e info varie July 21, 2016 03:45AM |
In file included from sketch\base.h:69:0,
from sketch\Configuration_Store.cpp:39:
sketch\module/temperature/temperature.h: In function 'bool tooColdToExtrude(uint8_t)':
sketch\module/temperature/temperature.h:52:25: error: 'h' was not declared in this scope
#define HOTEND_INDEX h
sketch\module/temperature/temperature.h:245:52: note: in expansion of macro 'HOTEND_INDEX'
return (allow_cold_extrude ? false : degHotend(HOTEND_INDEX) < extrude_min_temp);
exit status 1
Errore durante la compilazione per la scheda Arduino Due (Programming Port).
[\code]
Re: Ultratronics - LCD e info varie July 21, 2016 03:51AM |
Re: Ultratronics - LCD e info varie July 21, 2016 03:55AM |
Re: Ultratronics - LCD e info varie July 21, 2016 03:57AM |
Re: Ultratronics - LCD e info varie July 21, 2016 03:58AM |
Re: Ultratronics - LCD e info varie July 21, 2016 04:04AM |
Re: Ultratronics - LCD e info varie July 21, 2016 04:16AM |
Re: Ultratronics - LCD e info varie July 21, 2016 04:23AM |
Re: Ultratronics - LCD e info varie July 21, 2016 04:35AM |
Re: Ultratronics - LCD e info varie July 21, 2016 04:38AM |
Re: Ultratronics - LCD e info varie July 21, 2016 05:35AM |
Re: Ultratronics - LCD e info varie July 21, 2016 05:40AM |
Re: Ultratronics - LCD e info varie July 21, 2016 05:44AM |
Re: Ultratronics - LCD e info varie July 21, 2016 05:48AM |
Re: Ultratronics - LCD e info varie July 21, 2016 05:49AM |
Re: Ultratronics - LCD e info varie July 21, 2016 06:27AM |
Re: Ultratronics - LCD e info varie July 21, 2016 06:33AM |
Re: Ultratronics - LCD e info varie July 21, 2016 07:40AM |
Re: Ultratronics - LCD e info varie July 21, 2016 08:24AM |
Re: Ultratronics - LCD e info varie July 21, 2016 10:18AM |
Re: Ultratronics - LCD e info varie July 21, 2016 10:19AM |
Re: Ultratronics - LCD e info varie July 21, 2016 10:27AM |
Re: Ultratronics - LCD e info varie July 21, 2016 10:35AM |
Re: Ultratronics - LCD e info varie July 21, 2016 10:58AM |
Non è proprio come dici tu!!Quote
Paso
Ci sono i led accesi intendi? È un problema che ho riscontrato pure io (e l'avevo già scritto e si nota nelle foto caricate) che i led degli estrusori non utilizzati siano accesi.
Comunque in generale la scheda funziona ed io la uso.
Re: Ultratronics - LCD e info varie July 21, 2016 11:14AM |
