Re: Sensore Autobed leveling - BLTOUCH May 23, 2016 09:49AM |
Re: Sensore Autobed leveling - BLTOUCH May 28, 2016 02:37PM |
Re: Sensore Autobed leveling - BLTOUCH June 07, 2016 06:45AM |
Re: Sensore Autobed leveling - BLTOUCH June 07, 2016 05:45PM |
Re: Sensore Autobed leveling - BLTOUCH June 08, 2016 08:45AM |
Re: Sensore Autobed leveling - BLTOUCH June 08, 2016 06:23PM |
Re: Sensore Autobed leveling - BLTOUCH June 16, 2016 02:35AM |
Re: Sensore Autobed leveling - BLTOUCH June 16, 2016 06:16AM |
Re: Sensore Autobed leveling - BLTOUCH June 16, 2016 07:31AM |
Re: Sensore Autobed leveling - BLTOUCH June 17, 2016 05:06AM |
Re: Sensore Autobed leveling - BLTOUCH June 18, 2016 03:02AM |
Re: Sensore Autobed leveling - BLTOUCH June 18, 2016 01:39PM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 04:55AM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 05:02AM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 05:51AM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 06:19AM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 07:44AM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 09:57AM |
18:12:30.260 : Config:Home offset (mm): 18:12:30.264 : Config: M206 X0.00 Y0.00 Z-1.70 18:12:30.264 : Config:Hotend offset (mm): 18:12:30.264 : Config: M218 T0 X0.00 Y0.00 Z0.00 18:12:30.264 : Config:Z Probe offset (mm) 18:12:30.268 : Config: M666 P-1.65Che differenza c'è fra home offset e probe ofset
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 12:26PM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 01:01PM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 01:06PM |
Re: Sensore Autobed leveling - BLTOUCH June 19, 2016 02:42PM |
Re: Sensore Autobed leveling - BLTOUCH June 21, 2016 02:33AM |
Re: Sensore Autobed leveling - BLTOUCH July 13, 2016 05:52PM |
Re: Sensore Autobed leveling - BLTOUCH July 14, 2016 05:27AM |
Re: Sensore Autobed leveling - BLTOUCH July 14, 2016 03:04PM |
Re: Sensore Autobed leveling - BLTOUCH July 15, 2016 02:38AM |
claustro
Io ho risolto abbastanza bene mettendo la calibrazione a 9 punti. Adesso stampa bene con solo un attimo di attenzione allo Z off set
Re: Sensore Autobed leveling - BLTOUCH July 15, 2016 03:04AM |
Re: Sensore Autobed leveling - BLTOUCH July 15, 2016 04:33AM |
#define AUTO_BED_LEVELING_FEATURE #define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Leveling is Enabled. #define AUTO_BED_LEVELING_GRID #define LEFT_PROBE_BED_POSITION 20 #define RIGHT_PROBE_BED_POSITION 220 #define FRONT_PROBE_BED_POSITION 20 #define BACK_PROBE_BED_POSITION 250 #define MIN_PROBE_EDGE 10 #define AUTO_BED_LEVELING_GRID_POINTS 3 #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 15 #define ABL_PROBE_PT_3_X 180 #define ABL_PROBE_PT_3_Y 15 #define X_PROBE_OFFSET_FROM_EXTRUDER 30 #define Y_PROBE_OFFSET_FROM_EXTRUDER -34 #define Z_PROBE_OFFSET_FROM_EXTRUDER -1.6 #define XY_TRAVEL_SPEED 10000 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 10 #define Z_RAISE_BETWEEN_PROBINGS 5 #define Z_RAISE_AFTER_PROBING 5
Re: Sensore Autobed leveling - BLTOUCH July 15, 2016 07:26AM |
