Re: Sensore Autobed leveling - BLTOUCH January 22, 2017 03:09PM |
Re: Sensore Autobed leveling - BLTOUCH January 22, 2017 03:17PM |
MagoKimbra
Ok allora ricapitoliamo..
Altezza è giusta...
G30 X0 Y0 ti da Z0 e l'offset
G29 dovrebbe almeno al centro darti valori vicino allo 0...
Se questo non accade c'è qualcosa che non va...
>>> G30 X0 Y0 SENDING:G30 X0 Y0 Bed X:0.00 Y: 0.00 Z: -0.8000 New Z probe offset = -2.5677
Re: Sensore Autobed leveling - BLTOUCH January 22, 2017 04:31PM |
Re: Sensore Autobed leveling - BLTOUCH January 22, 2017 04:35PM |
>>> g28 SENDING:G28 >>> G30 X0 Y0 U1 SENDING:G30 X0 Y0 U1 Bed X:0.00 Y: 0.00 Z: -0.7875 New Z probe offset = -2.5802 >>> m500 SENDING:M500 Echoettings Stored (2013 bytes) >>> g28 SENDING:G28 >>> G30 X0 Y0 SENDING:G30 X0 Y0 Bed X:0.00 Y: 0.00 Z: -0.0500 New Z probe offset = -2.5302
Re: Sensore Autobed leveling - BLTOUCH January 22, 2017 04:51PM |
>>> g29 SENDING:G29 G29 Auto Bed Leveling Echo:Bilinear Leveling Grid: Echo: Echo: Echo: -0.499 -0.478 -0.460 -0.432 -0.409 -0.386 -0.339 -0.311 -0.274 -0.236 -0.251 -0.236 -0.259 -0.257 -0.273 -0.303 -0.274 -0.060 -0.139 -0.128 -0.091 Echo: -0.509 -0.499 -0.454 -0.412 -0.365 -0.338 -0.295 -0.299 -0.275 -0.249 -0.233 -0.238 -0.240 -0.262 -0.291 -0.286 -0.297 -0.215 -0.130 -0.113 -0.169 Echo: -0.497 -0.463 -0.413 -0.363 -0.324 -0.298 -0.271 -0.225 -0.208 -0.175 -0.171 -0.173 -0.186 -0.200 -0.188 -0.213 -0.247 -0.258 -0.125 -0.183 -0.283 Echo: -0.491 -0.467 -0.429 -0.386 -0.327 -0.323 -0.300 -0.288 -0.272 -0.276 -0.263 -0.260 -0.302 -0.299 -0.304 -0.304 -0.329 -0.341 -0.270 -0.286 -0.333 Echo: -0.492 -0.414 -0.373 -0.348 -0.300 -0.276 -0.241 -0.212 -0.200 -0.174 -0.179 -0.163 -0.162 -0.173 -0.185 -0.239 -0.254 -0.295 -0.249 -0.318 -0.353 Echo: -0.458 -0.426 -0.363 -0.336 -0.266 -0.249 -0.222 -0.199 -0.195 -0.149 -0.172 -0.162 -0.154 -0.198 -0.188 -0.226 -0.246 -0.264 -0.222 -0.132 -0.453 Echo: -0.387 -0.337 -0.297 -0.234 -0.211 -0.176 -0.163 -0.125 -0.090 -0.075 -0.088 -0.088 -0.086 -0.109 -0.122 -0.149 -0.175 -0.210 -0.184 -0.122 -0.538 Echo: -0.363 -0.308 -0.247 -0.225 -0.176 -0.150 -0.113 -0.101 -0.085 -0.064 -0.050 -0.062 -0.051 -0.088 -0.135 -0.108 -0.163 -0.189 -0.146 -0.076 -0.500 Echo: -0.349 -0.288 -0.238 -0.199 -0.163 -0.123 -0.063 -0.050 -0.014 +0.000 -0.000 -0.010 -0.013 -0.024 -0.025 -0.101 -0.087 -0.135 -0.103 -0.053 -0.325 Echo: -0.313 -0.255 -0.213 -0.161 -0.114 -0.078 -0.061 -0.038 -0.027 +0.012 +0.001 +0.009 +0.011 -0.011 -0.026 -0.055 -0.088 -0.134 -0.100 -0.036 -0.140 Echo: -0.307 -0.260 -0.197 -0.139 -0.075 -0.041 +0.002 +0.036 +0.051 +0.048 +0.052 +0.084 +0.075 +0.061 +0.053 +0.027 -0.032 -0.083 -0.063 -0.009 -0.146 Echo: -0.274 -0.200 -0.135 -0.086 -0.036 -0.004 +0.048 +0.064 +0.086 +0.089 +0.098 +0.108 +0.089 +0.064 +0.053 +0.025 +0.001 -0.041 -0.060 -0.037 -0.282 Echo: -0.197 -0.139 -0.072 -0.010 +0.025 +0.064 +0.104 +0.124 +0.139 +0.149 +0.154 +0.164 +0.163 +0.153 +0.128 +0.136 +0.065 +0.028 -0.007 +0.024 -0.457 Echo: -0.176 -0.103 -0.047 -0.000 +0.037 +0.073 +0.098 +0.110 +0.149 +0.147 +0.173 +0.173 +0.187 +0.150 +0.141 +0.110 +0.074 +0.028 +0.008 -0.493 -0.578 Echo: -0.105 -0.054 +0.011 +0.054 +0.101 +0.141 +0.172 +0.183 +0.224 +0.221 +0.247 +0.254 +0.276 +0.241 +0.223 +0.196 +0.133 +0.054 +0.026 -0.497 -0.615 Echo: -0.139 -0.036 +0.026 +0.078 +0.136 +0.164 +0.184 +0.211 +0.212 +0.224 +0.247 +0.239 +0.248 +0.216 +0.188 +0.152 +0.111 +0.073 -0.489 -0.500 -0.575 Echo: -0.076 -0.039 +0.040 +0.115 +0.161 +0.201 +0.235 +0.238 +0.251 +0.276 +0.285 +0.301 +0.274 +0.277 +0.252 +0.211 +0.124 -0.449 -0.527 -0.553 -0.558 Echo: +0.034 +0.015 +0.029 +0.097 +0.151 +0.215 +0.240 +0.286 +0.302 +0.311 +0.328 +0.315 +0.301 +0.272 +0.254 +0.215 -0.429 -0.452 -0.506 -0.582 -0.606 Echo: +0.053 -0.022 +0.174 +0.198 +0.196 +0.236 +0.301 +0.324 +0.350 +0.349 +0.351 +0.349 +0.334 +0.311 +0.286 -0.384 -0.418 -0.459 -0.486 -0.562 -0.643 Echo: +0.061 +0.089 -0.001 -0.068 +0.350 +0.310 +0.300 +0.336 +0.363 +0.361 +0.350 +0.348 +0.325 -0.339 -0.341 -0.362 -0.380 -0.434 -0.482 -0.531 -0.626
Re: Sensore Autobed leveling - BLTOUCH January 22, 2017 04:53PM |
Re: Sensore Autobed leveling - BLTOUCH January 22, 2017 05:18PM |
MagoKimbra
Si è normale, perché per sondare la zona bianca il nozzle finirebbe fuori dall'area..
Ora ci siamo al centro hai valori pari allo zero +/-...
Ora come va durante la stampa?
Re: Sensore Autobed leveling - BLTOUCH January 23, 2017 01:48AM |
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 08:23AM |
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 09:17AM |
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 05:31PM |
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 05:36PM |
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 05:42PM |
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 05:59PM |
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 06:06PM |
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 07:01PM |
Sicon
Ecco i risultati (ho fatto semplicemente G28)
#define Z_MIN_ENDSTOP_INVERTING false
#define Z_MIN_PROBE_ENDSTOP_INVERTING false
Quando va a fare l'homing, X e Y perfetti, al Z estrae e ritrae subito, poi alza il Z per il bumping , estrae e ritrae subito nuovamente (e' come se trovasse subito il trigger appena estratto), non si abbassa nemmeno 1 millimetro verso il piatto (che e' a diversi centimetri sotto)
#define Z_MIN_ENDSTOP_INVERTING true
Idem come sopra
#define Z_MIN_PROBE_ENDSTOP_INVERTING true
Idem come sopra
Idem come sopra
In tutti i casi ho sempre con M119 open quando la barra e' su e triggered quando e' giu'
Non so piu' che fare . Sarebbe utile per me capire se anche a voi quando e' esteso leggete 5v dai pin del bltouch che vanno all'endstop e quando e' ritratto 0V, a parte la logica di marlin, per come deve funzionare questo coso DEVE essere 0V sia quando e' esteo che ritratto (sempre open insomma) perche' quando e' esteso deve aspettare che si raggiunga il punto che fa scattare i 5v per 5ms durante la ritrazione per aver trovato il bed e tutto ritratto deve essere 0V perche' non puo' essere triggherato durante la stampa
Re: Sensore Autobed leveling - BLTOUCH January 25, 2017 07:56PM |
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 02:48AM |
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 05:08AM |
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 05:18AM |
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 06:02AM |
MagoKimbra
Ma fai delle prove prima di rovinare nozzle e macchina...
Il primo layer a che altezza lo fai 0,3 0,2???
Se lo fai a 0,2 una volta fatta la home scendi a 0,2 al centro e dovresti avere 0,2 mm tra il nozzle e il piano..poi ti sposti piano piano a destra e sinistra avanti e indietro e vedi se hai sempre la stessa misura, naturalmente dopo aver attivato l'abl..
In teoria non dovresti mai toccare il piano...
Se in un determinato punto tocca controlla con M321 qual'è il valore che ha preso con la probe in quel punto.
Ti scrive le coordinate in griglia e il valore che ha in memoria per quel punto... Cosi verifichi rispetto al movimento che fa e ai valori presi dalla probe..
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 06:37AM |
M320 - Enable/Disable S1=enable S0=disable, V[bool] Print the leveling grid, Z for leveling fade height (Requires ENABLE_LEVELING_FADE_HEIGHT)
//#define ENABLE_LEVELING_FADE_HEIGHT
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 08:59AM |
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 11:20AM |
SENDING:G28 >>> G1Z0.2 >>> M320 S1 SENDING:M320 S1 Echo:ABL: On X Level value in gridx=20 gridy=10 X55.00 Y0.00 Z-0.14 Level value in gridx=19 gridy=10 X50.00 Y0.00 Z-0.14 Level value in gridx=18 gridy=10 X45.00 Y0.00 Z-0.17 Level value in gridx=17 gridy=10 X40.00 Y0.00 Z-0.17 Level value in gridx=16 gridy=10 X35.00 Y0.00 Z-0.11 Level value in gridx=15 gridy=10 X30.00 Y0.00 Z-0.09 Level value in gridx=15 gridy=10 X25.00 Y0.00 Z-0.09 Level value in gridx=14 gridy=10 X20.00 Y0.00 Z-0.05 Level value in gridx=13 gridy=10 X15.00 Y0.00 Z-0.02 Level value in gridx=12 gridy=10 X10.00 Y0.00 Z-0.00 Level value in gridx=11 gridy=10 X5.00 Y0.00 Z0.01 >Level value in gridx=10 gridy=10 X0.00 Y0.00 Z0.01 Level value in gridx=10 gridy=10 X-5.00 Y0.00 Z0.01 Level value in gridx=9 gridy=10 X-10.00 Y0.00 Z0.01 Level value in gridx=8 gridy=10 X-15.00 Y0.00 Z-0.00 Level value in gridx=7 gridy=10 X-20.00 Y0.00 Z-0.03 Level value in gridx=6 gridy=10 X-25.00 Y0.00 Z-0.05 Level value in gridx=5 gridy=10 X-30.00 Y0.00 Z-0.09 Level value in gridx=5 gridy=10 X-35.00 Y0.00 Z-0.09 Level value in gridx=4 gridy=10 X-40.00 Y0.00 Z-0.13 Level value in gridx=3 gridy=10 X-45.00 Y0.00 Z-0.16 Level value in gridx=2 gridy=10 X-50.00 Y0.00 Z-0.20 Level value in gridx=1 gridy=10 X-55.00 Y0.00 Z-0.26 Level value in gridx=0 gridy=10 X-60.00 Y0.00 Z-0.34 Y Level value in gridx=10 gridy=20 X0.00 Y55.00 Z0.29 Level value in gridx=10 gridy=19 X0.00 Y50.00 Z0.24 Level value in gridx=10 gridy=18 X0.00 Y45.00 Z0.25 Level value in gridx=10 gridy=17 X0.00 Y40.00 Z0.20 Level value in gridx=10 gridy=16 X0.00 Y35.00 Z0.17 Level value in gridx=10 gridy=15 X0.00 Y30.00 Z0.17 Level value in gridx=10 gridy=15 X0.00 Y25.00 Z0.17 Level value in gridx=10 gridy=14 X0.00 Y20.00 Z0.09 Level value in gridx=10 gridy=13 X0.00 Y15.00 Z0.08 Level value in gridx=10 gridy=12 X0.00 Y10.00 Z0.05 Level value in gridx=10 gridy=11 X0.00 Y5.00 Z0.04 >Level value in gridx=10 gridy=10 X0.00 Y0.00 Z0.01 Level value in gridx=10 gridy=10 X0.00 Y-5.00 Z0.01 Level value in gridx=10 gridy=9 X0.00 Y-10.00 Z-0.03 Level value in gridx=10 gridy=8 X0.00 Y-15.00 Z-0.05 Level value in gridx=10 gridy=7 X0.00 Y-20.00 Z-0.06 Level value in gridx=10 gridy=6 X0.00 Y-25.00 Z-0.12 Level value in gridx=10 gridy=5 X0.00 Y-30.00 Z-0.17 Level value in gridx=10 gridy=5 X0.00 Y-35.00 Z-0.17 Level value in gridx=10 gridy=4 X0.00 Y-40.00 Z-0.15 Level value in gridx=10 gridy=3 X0.00 Y-45.00 Z-0.16 Level value in gridx=10 gridy=2 X0.00 Y-50.00 Z-0.20 Level value in gridx=10 gridy=1 X0.00 Y-55.00 Z-0.24 Level value in gridx=10 gridy=0 X0.00 Y-60.00 Z-0.31
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 11:24AM |
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 11:44AM |
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 11:55AM |
karnhack
Se non erro questo è lo schema che segue... non ho capito bene se parte da 0 o da 1 ma interrogando la griglia 0 mi restituisce un valore quindi mi pare esatto.
In ogni caso non mi trovo molto... ho cercato di ricostruire il percorso del bltouch durante la calibrazione e non mi sembra coerente... sempre che si sposti di 5mm sua in x che in Y
[attachment 89604 Schermata2017-01-26alle17.23.48.png]
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 11:58AM |
andrea2
Chiedo a chi ha una stampante uguale o simile alla mia, e che ha il bed leveling che funziona a dovere, di postare i dati del g29 a 9 punti.
Vorrei confrontarli con i miei
Grazie in anticipo
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 12:17PM |
Re: Sensore Autobed leveling - BLTOUCH January 26, 2017 12:25PM |
MagoKimbra
Si hai scelto 21 punti quindi divide per 21 il diametro di probe area che è uguale alla radius printing - 5.
Quindi se vai a fare i conti si abbiamo piccoli passi di 5 mm.
