Re: Sensore Autobed leveling - BLTOUCH January 31, 2017 09:33AM |
Re: Sensore Autobed leveling - BLTOUCH January 31, 2017 09:39AM |
MagoKimbra
E' normale che scenda di 3 4 cm dopo g28 c'è il il delta safe homing attivo...
Re: Sensore Autobed leveling - BLTOUCH January 31, 2017 09:43AM |
Re: Sensore Autobed leveling - BLTOUCH January 31, 2017 10:38AM |
MagoKimbra
é normale che cambia quei valori se sono sballati...
M502 richiama i valori di default ma poi vanno memorizzati in eeprom con M500...
SENDING:M666 L Config:Current Delta geometry values: Config (Endstop Adj): -2.544 Config:Y (Endstop Adj): -1.148 Config:Z (Endstop Adj): 0.000 Config (ZProbe ZOffset): -2.205 Config:A (Tower A Radius Correction): -2.795 Config:B (Tower B Radius Correction): -4.819 Config:C (Tower C Radius Correction): 0.000 Config:I (Tower A Position Correction): 0.000 Config:J (Tower B Position Correction): 0.000 Config:K (Tower C Position Correction): 0.000 Config:U (Tower A Diagonal Rod Correction): 0.000 Config:V (Tower B Diagonal Rod Correction): 0.000 Config:W (Tower C Diagonal Rod Correction): 0.000 Config:R (Delta Radius): 78.9947 Config (Diagonal Rod Length): 151.9954 Config (Delta Segments per second): 160.0 Config:H (Z-Height): 338.754
Re: Sensore Autobed leveling - BLTOUCH February 01, 2017 06:12AM |
Re: Sensore Autobed leveling - BLTOUCH February 01, 2017 07:09AM |
>>> m320 v1 SENDING:M320 V1 Echo:ABL: Off Echo:Bilinear Leveling Grid: Echo: Echo: Echo: -0.003 +0.026 +0.048 +0.064 +0.052 +0.075 +0.062 +0.073 +0.048 +0.071 +0.052 +0.038 -0.022 -0.051 -0.062 -0.072 -0.048 -0.003 +0.005 -0.015 -0.072 Echo: +0.001 +0.040 +0.039 +0.071 +0.101 +0.087 +0.061 +0.077 +0.085 +0.062 +0.026 -0.001 -0.028 -0.062 -0.085 -0.115 -0.097 -0.090 -0.061 -0.111 -0.131 Echo: +0.028 +0.062 +0.062 +0.049 +0.077 +0.088 +0.075 +0.064 +0.059 +0.038 +0.050 -0.001 -0.015 -0.039 -0.076 -0.088 -0.116 -0.152 -0.161 -0.136 -0.143 Echo: +0.011 +0.007 +0.010 +0.049 +0.021 +0.049 +0.052 +0.053 +0.065 +0.070 +0.052 +0.014 +0.010 -0.039 -0.042 -0.082 -0.138 -0.138 -0.149 -0.153 -0.176 Echo: -0.030 +0.003 -0.013 -0.000 +0.016 +0.011 +0.025 +0.050 +0.046 +0.030 +0.039 +0.003 +0.004 -0.050 -0.079 -0.122 -0.134 -0.187 -0.186 -0.178 -0.155 Echo: -0.022 -0.010 +0.026 +0.023 +0.022 +0.004 +0.036 +0.047 +0.033 +0.037 +0.016 -0.013 -0.039 -0.027 -0.085 -0.097 -0.099 -0.140 -0.171 -0.179 -0.124 Echo: -0.047 -0.050 -0.037 +0.012 +0.001 +0.022 +0.028 +0.025 +0.011 -0.011 -0.002 +0.011 -0.010 -0.025 -0.076 -0.081 -0.099 -0.124 -0.164 -0.190 -0.149 Echo: -0.051 -0.039 -0.023 -0.012 +0.023 +0.014 +0.013 -0.001 +0.009 -0.004 +0.012 -0.012 -0.045 -0.053 -0.073 -0.113 -0.133 -0.147 -0.165 -0.159 -0.061 Echo: -0.076 -0.035 -0.011 -0.012 +0.010 -0.024 +0.001 +0.023 +0.001 -0.000 -0.012 -0.028 -0.041 -0.075 -0.090 -0.116 -0.120 -0.141 -0.214 -0.224 -0.175 Echo: -0.066 -0.060 -0.060 -0.027 -0.003 -0.023 -0.014 +0.012 -0.023 -0.049 -0.049 -0.063 -0.039 -0.070 -0.116 -0.125 -0.150 -0.176 -0.178 -0.202 -0.165 Echo: -0.061 -0.046 -0.038 -0.027 -0.001 -0.001 -0.013 -0.024 -0.039 -0.023 -0.051 -0.059 -0.062 -0.086 -0.123 -0.114 -0.127 -0.148 -0.213 -0.204 -0.175 Echo: -0.076 -0.076 -0.064 -0.051 -0.026 -0.009 -0.008 -0.009 -0.023 -0.024 -0.023 -0.039 -0.027 -0.072 -0.098 -0.099 -0.125 -0.175 -0.174 -0.201 -0.174 Echo: -0.084 -0.050 -0.029 -0.038 -0.024 -0.011 -0.020 -0.025 -0.054 -0.042 -0.052 -0.063 -0.060 -0.052 -0.075 -0.084 -0.112 -0.165 -0.188 -0.204 -0.188 Echo: -0.075 -0.052 -0.047 -0.035 -0.016 -0.038 -0.039 -0.016 -0.039 -0.040 -0.024 -0.066 -0.064 -0.060 -0.091 -0.071 -0.102 -0.133 -0.164 -0.165 -0.128 Echo: -0.038 -0.037 -0.041 -0.038 -0.023 -0.010 -0.034 -0.049 -0.039 -0.039 -0.029 -0.023 -0.061 -0.073 -0.076 -0.135 -0.112 -0.134 -0.137 -0.153 -0.126 Echo: -0.066 -0.048 -0.051 -0.026 -0.026 -0.004 -0.032 -0.000 -0.023 -0.014 -0.025 -0.036 -0.025 -0.064 -0.071 -0.076 -0.126 -0.125 -0.137 -0.175 -0.160 Echo: -0.064 -0.062 -0.049 -0.037 -0.040 -0.038 -0.038 -0.036 -0.039 -0.040 -0.053 -0.052 -0.075 -0.075 -0.091 -0.113 -0.110 -0.150 -0.164 -0.171 -0.195 Echo: -0.040 -0.047 -0.059 -0.064 -0.050 -0.024 -0.021 -0.039 -0.059 -0.072 -0.074 -0.063 -0.073 -0.066 -0.074 -0.095 -0.126 -0.125 -0.163 -0.191 -0.218 Echo: -0.064 -0.049 -0.040 -0.040 -0.038 -0.023 -0.041 -0.036 -0.040 -0.016 -0.036 -0.035 -0.059 -0.070 -0.090 -0.095 -0.106 -0.119 -0.145 -0.186 -0.228 Echo: -0.050 -0.045 -0.066 -0.062 -0.033 -0.038 -0.009 -0.012 -0.027 -0.007 +0.001 -0.001 -0.014 -0.052 -0.064 -0.061 -0.086 -0.113 -0.126 -0.162 -0.215 >>> m666 l SENDING:M666 L Config:Current Delta geometry values: Config (Endstop Adj): -0.695 Config:Y (Endstop Adj): -1.328 Config:Z (Endstop Adj): 0.000 Config (ZProbe ZOffset): -2.280 Config:A (Tower A Radius Correction): -0.040 Config:B (Tower B Radius Correction): 0.123 Config:C (Tower C Radius Correction): 0.000 Config:I (Tower A Position Correction): 0.000 Config:J (Tower B Position Correction): 0.000 Config:K (Tower C Position Correction): 0.000 Config:U (Tower A Diagonal Rod Correction): 0.000 Config:V (Tower B Diagonal Rod Correction): 0.000 Config:W (Tower C Diagonal Rod Correction): 0.000 Config:R (Delta Radius): 101.4947 Config (Diagonal Rod Length): 227.2549 Config (Delta Segments per second): 160.0 Config:H (Z-Height): 339.585
Re: Sensore Autobed leveling - BLTOUCH February 02, 2017 01:06AM |
Re: Sensore Autobed leveling - BLTOUCH February 13, 2017 05:33PM |
Re: Sensore Autobed leveling - BLTOUCH February 14, 2017 01:43AM |
Prendi Originale se non vuoi sorprese io al epoca non ho trovato su [www.indiegogo.com] dato che la campagna acquisti era terminataQuote
Enexus
Ciao a tutti, sono nuovo e abbastanza inesperto ma cerco di imparare in fretta
Incuriosito da questo sensore ho provato a cercarlo su Amazon ma ho invece trovato ed ordinato questo Geeetech 3D Touch che sembra esserne il gemello
Re: Sensore Autobed leveling - BLTOUCH February 14, 2017 01:45AM |
Ciao lo ho io identico montato sulla kossel della 3DMakerlab e non ho potuto per problemi di tempo testarlo nella funzionalità effettiva, ma montato e testato sommariamente sulla Trigorilla e va bene fa tutto quello che deve fare senza problemi.Quote
Enexus
Incuriosito da questo sensore ho provato a cercarlo su Amazon ma ho invece trovato ed ordinato questo Geeetech 3D Touch che sembra esserne il gemello link.
Volevo sapere se qualcuno lo ha provato od eventualmente se vi sembra compatibile con qualsiasi stampante, avrei intenzione di montarlo su una Anycubic Delta che monta una Trigorilla motherboard...
Qui ho trovato anche una wiki wiki 3d touch
Grazie per l'aiuto
Re: Sensore Autobed leveling - BLTOUCH February 14, 2017 02:58AM |
Micron792
Toglietemi una curiosità forse mi sto sbagliando ma ho re installato sulla Vulcanus il nuovo Mk4 duo e sto testando il bltouch ma ho avuto l'impressione che malgrado l'astina scenda e salga facendo M119 fosse guasto perché lo stato non cambiava ed ottengo sempre not Triggered, ma leggendo addietro ho forse toppato è dato per guasto frettolosamente perché un utente ha scritto " non resta attivo come i classici endstop, ma da un impulso molto breve di chiusura allo scatto del pin. Quel mini impulso è sufficiente a far rilevare la home. Quindi difficile vederlo tra gli endstop attivatisi"
Mi confermate così siccome l'ho smontato e messo da parte lo rimonto e riprendo la taratura per iAbl?
Grazie
Re: Sensore Autobed leveling - BLTOUCH February 14, 2017 03:47AM |
Re: Sensore Autobed leveling - BLTOUCH February 14, 2017 07:25AM |
Enexus
Grazie per le risposte, mi rincuorano Comunque nel link alla guida che ho linkato sopra vedo che dice di modificare nel firmware una assegnazione in pin.h al pin assegnato a max pos, questo credo perché nella guida va vedere che il sensore lo va ad alimentare proprio al posto del max pos sulla motherboard in figura... Io non credo di dover fare questa modifica visto che la Trigorilla ha proprio un ingresso dedicato ai Servo, correggetemi se sbaglio... ^^
Re: Sensore Autobed leveling - BLTOUCH February 15, 2017 04:32AM |
Re: Sensore Autobed leveling - BLTOUCH February 15, 2017 04:59AM |
Re: Sensore Autobed leveling - BLTOUCH February 15, 2017 07:03AM |
Re: Sensore Autobed leveling - BLTOUCH February 16, 2017 09:54AM |
15:46:32.138 : Bed X:0.00 Y: 0.00 Z: 0.6917 New Z probe offset = -1.5917 15:46:32.138 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:32.949 : Bed X:0.00 Y: 0.00 Z: 0.7041 New Z probe offset = -1.6041 15:46:32.949 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:33.807 : Bed X:0.00 Y: 0.00 Z: 0.7041 New Z probe offset = -1.6041 15:46:33.807 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:34.665 : Bed X:0.00 Y: 0.00 Z: 0.6668 New Z probe offset = -1.5668 15:46:34.665 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:35.586 : Bed X:0.00 Y: 0.00 Z: 0.7041 New Z probe offset = -1.6041 15:46:35.586 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:36.444 : Bed X:0.00 Y: 0.00 Z: 0.7663 New Z probe offset = -1.6663 15:46:36.444 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:37.271 : Bed X:0.00 Y: 0.00 Z: 0.8284 New Z probe offset = -1.7284 15:46:37.271 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:38.113 : Bed X:0.00 Y: 0.00 Z: 0.8533 New Z probe offset = -1.7533 15:46:38.113 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:38.940 : Bed X:0.00 Y: 0.00 Z: 0.9030 New Z probe offset = -1.8030 15:46:38.940 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:39.782 : Bed X:0.00 Y: 0.00 Z: 0.8782 New Z probe offset = -1.7782 15:46:39.782 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:40.593 : Bed X:0.00 Y: 0.00 Z: 0.8284 New Z probe offset = -1.7284 15:46:40.593 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:41.420 : Bed X:0.00 Y: 0.00 Z: 0.7911 New Z probe offset = -1.6911 15:46:41.420 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:42.231 : Bed X:0.00 Y: 0.00 Z: 0.7911 New Z probe offset = -1.6911 15:46:42.231 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:43.089 : Bed X:0.00 Y: 0.00 Z: 0.7787 New Z probe offset = -1.6787 15:46:43.089 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:43.979 : Bed X:0.00 Y: 0.00 Z: 0.7166 New Z probe offset = -1.6166 15:46:43.979 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:44.930 : Bed X:0.00 Y: 0.00 Z: 0.7166 New Z probe offset = -1.6166 15:46:44.930 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:45.788 : Bed X:0.00 Y: 0.00 Z: 0.7041 New Z probe offset = -1.6041 15:46:45.788 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:46.677 : Bed X:0.00 Y: 0.00 Z: 0.7041 New Z probe offset = -1.6041 15:46:46.677 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:47.489 : Bed X:0.00 Y: 0.00 Z: 0.7041 New Z probe offset = -1.6041 15:46:47.489 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:48.315 : Bed X:0.00 Y: 0.00 Z: 0.7166 New Z probe offset = -1.6166 15:46:48.315 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:49.173 : Bed X:0.00 Y: 0.00 Z: 0.7166 New Z probe offset = -1.6166 15:46:49.173 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:46:50.109 : Bed X:0.00 Y: 0.00 Z: 0.7414 New Z probe offset = -1.6414 15:46:50.109 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992
15:59:12.949 : Bed X:0.00 Y: 0.00 Z: 0.5301 New Z probe offset = -1.4301 15:59:12.949 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:14.852 : Bed X:0.00 Y: 0.00 Z: 0.5922 New Z probe offset = -1.4922 15:59:14.852 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:16.365 : Bed X:0.00 Y: 0.00 Z: 0.6047 New Z probe offset = -1.5047 15:59:16.365 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:18.034 : Bed X:0.00 Y: 0.00 Z: 0.6295 New Z probe offset = -1.5295 15:59:18.034 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:19.360 : Bed X:0.00 Y: 0.00 Z: 0.6295 New Z probe offset = -1.5295 15:59:19.360 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:20.889 : Bed X:0.00 Y: 0.00 Z: 0.6668 New Z probe offset = -1.5668 15:59:20.889 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:22.418 : Bed X:0.00 Y: 0.00 Z: 0.7290 New Z probe offset = -1.6290 15:59:22.418 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:23.978 : Bed X:0.00 Y: 0.00 Z: 0.7538 New Z probe offset = -1.6538 15:59:23.978 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:25.569 : Bed X:0.00 Y: 0.00 Z: 0.7787 New Z probe offset = -1.6787 15:59:25.569 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:27.191 : Bed X:0.00 Y: 0.00 Z: 0.8284 New Z probe offset = -1.7284 15:59:27.191 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:28.783 : Bed X:0.00 Y: 0.00 Z: 0.7911 New Z probe offset = -1.6911 15:59:28.783 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:30.389 : Bed X:0.00 Y: 0.00 Z: 0.7414 New Z probe offset = -1.6414 15:59:30.389 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:31.887 : Bed X:0.00 Y: 0.00 Z: 0.7166 New Z probe offset = -1.6166 15:59:31.887 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:33.291 : Bed X:0.00 Y: 0.00 Z: 0.7290 New Z probe offset = -1.6290 15:59:33.291 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992 15:59:34.726 : Bed X:0.00 Y: 0.00 Z: 0.7166 New Z probe offset = -1.6166 15:59:34.726 : X:-1.00 Y:36.00 Z:15.90 E:0.00 Count Alpha:15820 Beta:15744 Teta:17992
Re: Sensore Autobed leveling - BLTOUCH February 24, 2017 03:23PM |
Re: Sensore Autobed leveling - BLTOUCH February 24, 2017 04:21PM |
Re: Sensore Autobed leveling - BLTOUCH February 24, 2017 05:43PM |
Re: Sensore Autobed leveling - BLTOUCH March 10, 2017 05:47AM |
Re: Sensore Autobed leveling - BLTOUCH March 10, 2017 06:00AM |
Graziano
Salve Raga,
Per ragioni di tempo di arrivo e costo della sonda , ho sostituito il BLtouch originale, che mi aveva abbandonato con quello clone di Geeetech, ma una volta montato sulla stampante non riesco a farlo funzionare, mi esegue perfettamente i test di funzionamento, ma quando vado a eseguire il comando di home degli assi, nella fase di discesa verso il piatto il perno tastatore si ritrae accendendo il led, invece di rimanere esteso con led spento per effettuare home dell'asse Z.
Ho selezionato nel MK 4.3.1 opzione Z Probe Servo, come consigliato dal Mago per far funzionare i cloni, ho spuntato Dedicate Z Probe servo endstop Pin, selezionando Z Min Pin e in Z probe type endstop, Electronic Normally Grid.
Ho attivato il servo, in Enable servo support Servos, ho messo 1 in Number Servos e in Z endstop Servos 0.
Non riesco a capire dove sia l'errore, dimenticavo ho provato a lanciare il comando M119 per testare lo stato degli endstop e della sonda, eseguendo per quest'ultima la prova sia quando il perno tastatore è Up, sia quando è Down, ma risulta essere Not Triggered vedi sotto.
21:16:57.043 : Reporting endstop status
21:16:57.043 : x_min: NOT TRIGGERED
21:16:57.043 : y_min: NOT TRIGGERED
21:16:57.047 : z_min: NOT TRIGGERED
21:16:57.047 : z_probe: NOT TRIGGERED
Re: Sensore Autobed leveling - BLTOUCH March 10, 2017 09:02AM |
Re: Sensore Autobed leveling - BLTOUCH March 10, 2017 09:45AM |
rdware
Provo a fare una domanda...
Vorrei montare anch'io un sensore di autolivellamento e avevo pensato al BLTouch, ma il problema è che utilizzo il modulo RRD Fan Extender che occupa tutte e quattro le serie di pin della RAMPS dedicate ai servi.
Notavo però nei datasheet che il modulo usa solo i pin D4 e D5 e non il D6 e D11.
Detto che nella peggiore delle ipotesi posso spostare tranquillamente la ventola automatica dell'estrusore sul pin dedicato e quella per il piatto sul D9 ( tanto uso un solo estrusore ), secondo voi è possibile creando un apposito adattatore continuare ad utilizzare il modulo RRD e collegare il BLTouch ai pin D6 o D11?
#define SERVO0_PIN 11a
#define SERVO0_PIN 1 // era 11
Re: Sensore Autobed leveling - BLTOUCH March 10, 2017 09:56AM |
Re: Sensore Autobed leveling - BLTOUCH March 10, 2017 10:01AM |
Re: Sensore Autobed leveling - BLTOUCH March 10, 2017 10:05AM |
Re: Sensore Autobed leveling - BLTOUCH March 11, 2017 03:56AM |
Re: Sensore Autobed leveling - BLTOUCH March 13, 2017 04:44AM |
Soluzione ancora più semplice direi...Quote
rangerone1
Anche io ho il modulo aggiuntivo per le ventole ma per non precludermi l' utilizzo del servo l' ho installato spostato di un foro. Praticamente ho lasciato libero la prima porta per il servo e i pin che comandano le due uscite del modulo sono shiftate di un posto..... funziona
Re: Sensore Autobed leveling - BLTOUCH March 13, 2017 03:52PM |
