Delta Calibrazione June 10, 2016 02:49PM |
owers and rod nomenclature for the following defines:
// C, Y-axis
// DELTA_ALPHA_CA=120° | DELTA_ALPHA_CB=120°
// |______ X-axis
// A B
//Endstop Offset Adjustment - All values are in mm and must be negative (to move down away from endstop switches)
#define TOWER_A_ENDSTOP_ADJ 0 // Front Left Tower
#define TOWER_B_ENDSTOP_ADJ 0 // Front Right Tower
#define TOWER_C_ENDSTOP_ADJ 0 // Rear Tower
//Tower Position Adjustment - Adj x Degrees around delta radius (- move clockwise / + move anticlockwise)
#define TOWER_A_POSITION_ADJ 0 //Front Left Tower
#define TOWER_B_POSITION_ADJ 0 //Front Right Tower
#define TOWER_C_POSITION_ADJ 0 //Rear Tower
//Tower Radius Adjustment - Adj x mm in/out from centre of printer (- move in / + move out)
#define TOWER_A_RADIUS_ADJ 0 //Front Left Tower
#define TOWER_B_RADIUS_ADJ 0 //Front Right Tower
#define TOWER_C_RADIUS_ADJ 0 //Rear Tower
//Diagonal Rod Adjustment - Adj diag rod for Tower by x mm from DELTA_DIAGONAL_ROD value
#define TOWER_A_DIAGROD_ADJ -5 //Front Left Tower
#define TOWER_B_DIAGROD_ADJ -5 //Front Right Tower
#define TOWER_C_DIAGROD_ADJ -5 //Rear Tower
Re: Delta Calibrazione June 10, 2016 04:01PM |
Re: Delta Calibrazione June 10, 2016 04:17PM |
Re: Delta Calibrazione June 10, 2016 04:25PM |
Re: Delta Calibrazione June 10, 2016 04:30PM |
Re: Delta Calibrazione June 10, 2016 04:33PM |
Re: Delta Calibrazione June 10, 2016 04:39PM |
Re: Delta Calibrazione June 10, 2016 05:01PM |
