SD originale persa May 05, 2017 12:42PM |
Re: SD originale persa May 05, 2017 12:47PM |
Re: SD originale persa May 07, 2017 12:03PM |
Re: SD originale persa May 07, 2017 12:11PM |
Re: SD originale persa May 07, 2017 12:47PM |
Re: SD originale persa May 07, 2017 01:39PM |
Re: SD originale persa May 08, 2017 03:58AM |
Admin Registered: 12 years ago Posts: 954 |
If you turn on the printer with the SD card in then remove it, add a file and put it back in the printer will not be able to find the card.
Go to SD card in the menu and hit the remove SD card, then the mount SD card option. That will make the printer recognize the SD card again and you should be able to see all your files.
| ---- "Let me make my move" ---- |
Re: SD originale persa May 08, 2017 04:36AM |
Re: SD originale persa June 13, 2017 01:48PM |
[ RISOLTO ] June 13, 2017 01:53PM |
