estrusore
August 21, 2017 08:39AM
Buongiorno mi chiamo giuliano sono nuovo vorrei sapere se qualcuno ha già utilizzato questo estrusore con questo frimware (Marlin-Marlin_v1_Prusa_i3_WORKING ), elettronica ramps 1.4 perchè nn reisco ha farlo funzionare. [www.facebook.com]
open | download - Marlin.rar (445.2 KB)
open | download - Dati estrusore.pdf (257.2 KB)
Re: estrusore
August 21, 2017 10:56AM
Cos'è che non riesci a far andare?
Andrea Lillia
Lillia.net
Pagina Facebook
Re: estrusore
August 22, 2017 09:44AM
Printer is now online.
echo: External Reset
Marlin1.0.0
echo: Last Updated: Jul 5 2017 16:55:11 | Author: (none, default config)
Compiled: Jul 5 2017
echo: Free Memory: 3765 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echoconfused smileyteps per unit:
echo: M92 X80.00 Y80.00 Z2560.00 E600.00
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z1.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X800 Y800 Z100 E100
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S1000.00 T300.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echotongue sticking out smileyID settings:
echo: M301 P63.00 I2.25 D440.00
Error:0
[ERROR] Error:0
: Extruder switched off. MAXTEMP triggered !
Errortongue sticking out smileyrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
[ERROR] Errortongue sticking out smileyrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
praticamete mi da una temperatura di 327 gradi e nn riesco ha settare il parametro giusto per il sensore di temperatura che ho io
Edited 1 time(s). Last edit at 08/22/2017 09:53AM by giulio94.
Re: estrusore
August 22, 2017 10:38AM
Ma hai settato il tuo termistore o hai preso un firmware trovato su internet e lo hai bttato sulla scheda?
Andrea Lillia
Lillia.net
Pagina Facebook
Re: estrusore
August 22, 2017 11:00AM
non è che stai invertendo ingresso termistore con uscita resistenza e viceversa?.... perchè 327° sono tipici di "un corto" tra i fili del termistore..... e visto che la resistenza scaldante e pochi Ohm mentre il termistore è 100K, la resistenza all'ingresso del termistore viene letta come "corto circuito"... e ti mette appunto quel valore...
Davide
Immagina e Crea
My Thingiverse
