Aiuto tecnico per Mks 1.3 e display digitale July 27, 2018 12:03PM |
Re: Aiuto tecnico per Mks 1.3 e display digitake July 27, 2018 01:23PM |
Re: Aiuto tecnico per Mks 1.3 e display digitake July 27, 2018 02:08PM |
Re: Aiuto tecnico per Mks 1.3 e display digitale July 28, 2018 07:24AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale July 29, 2018 06:04AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale July 29, 2018 06:47AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale July 29, 2018 09:00AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale July 30, 2018 06:33AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale July 30, 2018 11:51AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale July 30, 2018 12:28PM |
Re: Aiuto tecnico per Mks 1.3 e display digitale July 31, 2018 04:07PM |
Re: Aiuto tecnico per Mks 1.3 e display digitale August 01, 2018 04:08AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale August 01, 2018 06:10AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale August 01, 2018 09:43AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale August 01, 2018 10:32AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale August 02, 2018 11:13AM |
Re: Aiuto tecnico per Mks 1.3 e display digitale August 04, 2018 06:17AM |
# Panel panel.enable true # set to true to enable the panel code # on glcd EXP1 is to left and EXP2 is to right, pin 1 is bottom left, pin 2 is top left etc. # +5v is EXP1 pin 10, Gnd is EXP1 pin 9 panel.lcd reprap_discount_glcd # panel.spi_channel 0 # spi channel to use ; GLCD EXP1 Pins 3,5 (MOSI, SCLK) panel.spi_cs_pin 0.16 # spi chip select ; GLCD EXP1 Pin 4 panel.encoder_a_pin 3.25!^ # encoder pin ; GLCD EXP2 Pin 3 panel.encoder_b_pin 3.26!^ # encoder pin ; GLCD EXP2 Pin 5 panel.click_button_pin 1.30!^ # click button ; GLCD EXP1 Pin 2 panel.buzz_pin 1.31 # pin for buzzer ; GLCD EXP1 Pin 1 panel.back_button_pin 2.11!^ # back button ; GLCD EXP2 Pin 8 panel.external_sd false # set to true if there is an extrernal sdcard on the panel panel.external_sd.spi_channel 1 # set spi channel the sdcard is on panel.external_sd.spi_cs_pin 0.28 # set spi chip select for the sdcard (or any spare pin) panel.external_sd.sdcd_pin 0.27!^ # sd detect signal (set to nc if no sdcard detect) (or any spare pin)
