Prima stampante 3D homemade November 13, 2019 04:02PM |
Re: Prima stampante 3D homemade November 14, 2019 02:55AM |
Re: Prima stampante 3D homemade November 14, 2019 09:04AM |
Re: Prima stampante 3D homemade November 14, 2019 03:36PM |
Re: Prima stampante 3D homemade February 09, 2020 11:39AM |
Re: Prima stampante 3D homemade February 09, 2020 05:40PM |
Re: Prima stampante 3D homemade February 10, 2020 04:35AM |
Re: Prima stampante 3D homemade February 11, 2020 03:50AM |
Re: Prima stampante 3D homemade February 11, 2020 05:30AM |
#define USE_XMAX_PLUG
//#define USE_XMAX_PLUG
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way. #define INVERT_X_DIR false #define INVERT_Y_DIR true #define INVERT_Z_DIR false
// Direction of endstops when homing; 1=MAX, -1=MIN // :[-1,1] #define X_HOME_DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1
// Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 #define X_MAX_POS X_BED_SIZE #define Y_MAX_POS Y_BED_SIZE #define Z_MAX_POS 200
Re: Prima stampante 3D homemade February 11, 2020 10:12AM |
Re: Prima stampante 3D homemade February 11, 2020 11:46AM |
Re: Prima stampante 3D homemade February 12, 2020 03:23AM |
grazie ai tuoi consigli ora la stampante fa l'homing correttamente su tutti 3 gli assi. Ora mi sorge una domanda: di preciso dove bisogna posizionare l'endstop Z? Presumo che bisogna evitare che l'hotend urti troppo il piatto... o deve appoggiarsi precisamente sul piatto per segnare lo 0?
Re: Prima stampante 3D homemade February 12, 2020 08:53AM |
