installazione Bltouch May 13, 2020 03:25PM |
21:01:19.540 : Printer reset detected - initializing 21:01:19.543 : start 21:01:19.543 : Info:Echo:MK4duo_4.3.6 21:01:19.549 : Echo:Last Updated: May 13 2020 21:00:01 | Author: (none, default config) 21:01:19.549 : Echo:Compiled: May 13 2020 21:01:19.553 : Echo:Free Memory: 4732 PlannerBufferBytes: 1200 21:01:19.562 : Error:EEPROM CRC mismatch - (stored) 19051 != 1792 (calculated)! 21:01:19.565 : Echo:Factory Settings Loaded 21:01:19.569 : Config: G21 ; Units in (mm) 21:01:19.569 : Configteps per unit: 21:01:19.573 : Config: M92 X80.000 Y80.000 Z200.000 T0 E74.000 21:01:19.577 : Config:Maximum feedrates (units/s): 21:01:19.581 : Config: M203 X300.000 Y300.000 Z2.000 T0 E100.000 21:01:19.585 : Config:Maximum Acceleration (units/s2): 21:01:19.590 : Config: M201 X3000 Y3000 Z50 T0 E3000 21:01:19.598 : Config:Acceleration (units/s2): P V T* R: 21:01:19.602 : Config: M204 P3000.000 V3000.000 T0 R10000.000 21:01:19.606 : Config:Advanced variables: B S V: 21:01:19.610 : Config: M205 B20000 S0.000 V0.000 21:01:19.614 : Config:Jerk: X Z T* E: 21:01:19.618 : Config: M205 X10.000 Y10.000 Z0.400 T0 E5.000 21:01:19.630 : Config:Heater Sensor parameters: H P T A B C R L O: 21:01:19.639 : Config: M305 H0 P13 T1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0 21:01:19.651 : Config:Heater parameters: H P A B C L O U I: 21:01:19.655 : Config: M306 H0 P10 A40 B230 C255 L5 O290 U1 I0 21:01:19.663 : Config:Heater PID parameters: H P I D: 21:01:19.663 : Config: M301 H0 P40.00 I7.00 D60.00 21:01:19.676 : Config:Heater Sensor parameters: H P T A B C R L O: 21:01:19.684 : Config: M305 H-1 P14 T1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0 21:01:19.696 : Config:Heater parameters: H P A B C L O U I: 21:01:19.700 : Config: M306 H-1 P8 A80 B255 C255 L5 O150 U1 I0 21:01:19.708 : Config:Heater PID parameters: H P I D: 21:01:19.712 : Config: M301 H255 P10.00 I1.00 D305.00 21:01:19.716 : Config:Fans: P U L F I H : 21:01:19.720 : Config: M106 P0 U9 L0 F250 I0 21:01:19.725 : Configervo Angles: P L U: 21:01:19.729 : Config: M281 P0 L10 U90 21:01:19.729 : Config:Auto Bed Leveling: 21:01:19.729 : Config: M420 S0 21:01:19.733 : Configrobe Offset (mm): 21:01:19.737 : Config: M851 X29.000 Y2.000 Z-5.000 21:01:19.737 : Configtepper Direction: 21:01:19.741 : Config: M569 X0 Y1 Z0 T0 E0 21:01:19.745 : Configtepper driver control: 21:01:19.745 : Config: M569 D0 P0 R500000 21:01:21.985 : Printer reset detected - initializing 21:01:21.985 : start 21:01:21.989 : Info:Echo:MK4duo_4.3.6 21:01:21.993 : Echo:Last Updated: May 13 2020 21:00:01 | Author: (none, default config) 21:01:21.997 : Echo:Compiled: May 13 2020 21:01:22.001 : Echo:Free Memory: 4732 PlannerBufferBytes: 1200 21:01:22.010 : Error:EEPROM CRC mismatch - (stored) 19051 != 1792 (calculated)! 21:01:22.014 : Echo:Factory Settings Loaded 21:01:22.018 : Config: G21 ; Units in (mm) 21:01:22.018 : Configteps per unit: 21:01:22.022 : Config: M92 X80.000 Y80.000 Z200.000 T0 E74.000 21:01:22.026 : Config:Maximum feedrates (units/s): 21:01:22.030 : Config: M203 X300.000 Y300.000 Z2.000 T0 E100.000 21:01:22.034 : Config:Maximum Acceleration (units/s2): 21:01:22.039 : Config: M201 X3000 Y3000 Z50 T0 E3000 21:01:22.043 : Config:Acceleration (units/s2): P V T* R: 21:01:22.047 : Config: M204 P3000.000 V3000.000 T0 R10000.000 21:01:22.055 : Config:Advanced variables: B S V: 21:01:22.059 : Config: M205 B20000 S0.000 V0.000 21:01:22.063 : Config:Jerk: X Z T* E: 21:01:22.067 : Config: M205 X10.000 Y10.000 Z0.400 T0 E5.000 21:01:22.080 : Config:Heater Sensor parameters: H P T A B C R L O: 21:01:22.088 : Config: M305 H0 P13 T1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0 21:01:22.100 : Config:Heater parameters: H P A B C L O U I: 21:01:22.104 : Config: M306 H0 P10 A40 B230 C255 L5 O290 U1 I0 21:01:22.108 : Config:Heater PID parameters: H P I D: 21:01:22.112 : Config: M301 H0 P40.00 I7.00 D60.00 21:01:22.124 : Config:Heater Sensor parameters: H P T A B C R L O: 21:01:22.133 : Config: M305 H-1 P14 T1 A100000.0 B4092.0 C0.0000000000 R4700.0 L0 O0 21:01:22.145 : Config:Heater parameters: H P A B C L O U I: 21:01:22.149 : Config: M306 H-1 P8 A80 B255 C255 L5 O150 U1 I0 21:01:22.157 : Config:Heater PID parameters: H P I D: 21:01:22.157 : Config: M301 H255 P10.00 I1.00 D305.00 21:01:22.165 : Config:Fans: P U L F I H : 21:01:22.169 : Config: M106 P0 U9 L0 F250 I0 21:01:22.174 : Configervo Angles: P L U: 21:01:22.174 : Config: M281 P0 L10 U90 21:01:22.178 : Config:Auto Bed Leveling: 21:01:22.178 : Config: M420 S0 21:01:22.182 : Configrobe Offset (mm): 21:01:22.186 : Config: M851 X29.000 Y2.000 Z-5.000 21:01:22.186 : Configtepper Direction: 21:01:22.190 : Config: M569 X0 Y1 Z0 T0 E0 21:01:22.190 : Configtepper driver control: 21:01:22.194 : Config: M569 D0 P0 R500000 21:01:25.731 : ErrorTOP called because of BLTouch error - restart with M999 21:01:26.144 : FIRMWARE_NAME:MK4duo 4.3.6 FIRMWARE_URL:marlinkimbra.it PROTOCOL_VERSION:2.0 MACHINE_TYPE:CoreXY EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 21:01:26.180 : X:0.00 Y:0.00 Z:0.000 E:0.0000 21:01:26.181 : DebugLevel:6 21:01:26.181 : Echo:Unknown command: "M80" 21:01:26.181 : DebugLevel:6 21:01:48.303 : Resend:14
Re: installazione Bltouch May 14, 2020 02:55AM |
M999 - Restart after being stopped by error
M80
Re: installazione Bltouch May 14, 2020 10:35AM |
Re: installazione Bltouch May 14, 2020 12:05PM |
Re: installazione Bltouch May 14, 2020 12:59PM |
Re: installazione Bltouch May 16, 2020 03:47PM |
Re: installazione Bltouch May 17, 2020 08:04AM |
#define LEFT_PROBE_BED_POSITION 20 #define RIGHT_PROBE_BED_POSITION 260 #define FRONT_PROBE_BED_POSITION 20 #define BACK_PROBE_BED_POSITION 200
/** START AUTO BED LEVELING LINEAR or AUTO BED LEVELING BILINEAR **/ // Set the boundaries for probing (where the probe can reach).
Re: installazione Bltouch May 17, 2020 10:33AM |
Re: installazione Bltouch May 17, 2020 12:11PM |
Re: installazione Bltouch May 17, 2020 01:41PM |
Re: installazione Bltouch May 18, 2020 03:15AM |
MagoKimbra
1) si li calcola in base a quelli presi, ma essendo fuori dalla zona potrebbero esserci errori, naturalmente quella parte non puoi andarla a sondare per via dell'offset della probe.
Re: installazione Bltouch May 18, 2020 01:04PM |
Re: installazione Bltouch May 19, 2020 09:03AM |
