Re: doppio hotend per hips o pva September 12, 2015 11:51AM |
Re: doppio hotend per hips o pva September 12, 2015 12:09PM |
Re: doppio hotend per hips o pva September 15, 2015 10:54AM |
Re: doppio hotend per hips o pva September 15, 2015 11:44AM |
Re: doppio hotend per hips o pva September 15, 2015 12:26PM |
Re: doppio hotend per hips o pva September 15, 2015 05:51PM |
Re: doppio hotend per hips o pva September 16, 2015 06:43AM |
Re: doppio hotend per hips o pva September 17, 2015 06:01AM |
Re: doppio hotend per hips o pva September 18, 2015 08:36AM |
Re: doppio hotend per hips o pva September 18, 2015 08:44AM |
Re: doppio hotend per hips o pva September 18, 2015 08:45AM |
Re: doppio hotend per hips o pva September 18, 2015 08:57AM |
Re: doppio hotend per hips o pva September 18, 2015 10:39AM |
Re: doppio hotend per hips o pva September 19, 2015 12:12PM |
Re: doppio hotend per hips o pva September 19, 2015 12:19PM |
Re: doppio hotend per hips o pva September 20, 2015 09:51PM |
Re: doppio hotend per hips o pva September 21, 2015 04:36AM |
Re: doppio hotend per hips o pva September 21, 2015 05:22AM |
Re: doppio hotend per hips o pva September 21, 2015 08:49AM |
Re: doppio hotend per hips o pva September 21, 2015 09:00AM |
Re: doppio hotend per hips o pva September 21, 2015 09:19AM |
Re: doppio hotend per hips o pva September 21, 2015 09:27AM |
Re: doppio hotend per hips o pva September 21, 2015 09:35AM |
MagoKimbra
Scusate se mi intrometto, va bene l'alimentatore esterno ma devi mettere le masse in comune altrimenti non gira il servo... E se l'alimentatore non è ben filtrato potresti portare interferenze tramite la massa...
Re: doppio hotend per hips o pva September 21, 2015 01:32PM |
Re: doppio hotend per hips o pva September 21, 2015 02:26PM |
Re: doppio hotend per hips o pva September 24, 2015 10:08AM |
Re: doppio hotend per hips o pva September 24, 2015 10:15AM |
Re: doppio hotend per hips o pva September 24, 2015 11:03AM |
//define Z_SAFE_HOMING
// #define AUTO_BED_LEVELING_FEATURE
#define ENABLE_SERVOS // Number of servos // If you select a configuration below, this will receive a default value and does not need to be set manually // set it manually if you have more servos than extruders and wish to manually control some // leaving it defining as 0 will disable the servo subsystem #define NUM_SERVOS 1 // Servo index starts with 0 for M280 command // Servo Endstops // This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes. // Use M666 H to set the z-probe vertical offset from the nozzle. Store that setting with M500. // Define nr servo for endstop -1 not define. Servo index start 0 #define X_ENDSTOP_SERVO_NR -1 #define Y_ENDSTOP_SERVO_NR -1 #define Z_ENDSTOP_SERVO_NR -1 #define X_ENDSTOP_SERVO_ANGLES {0,0} // X Axis Extend and Retract angles #define Y_ENDSTOP_SERVO_ANGLES {0,0} // Y Axis Extend and Retract angles #define Z_ENDSTOP_SERVO_ANGLES {100,15} // Z Axis Extend and Retract angles // Servo deactivation // // With this option servos are powered only during movement, then turned off to prevent jitter. //#define DEACTIVATE_SERVOS_AFTER_MOVE // Delay (in microseconds) before turning the servo off. This depends on the servo speed. // 300ms is a good value but you can try less delay. // If the servo can't reach the requested position, increase it. #define SERVO_DEACTIVATION_DELAY 300
Re: doppio hotend per hips o pva September 24, 2015 11:27AM |
Re: doppio hotend per hips o pva September 24, 2015 12:07PM |
