Re: doppio hotend per hips o pva September 24, 2015 12:38PM |
Re: doppio hotend per hips o pva September 25, 2015 11:00AM |
[email protected]
3) Per il corretto posizionamento della camma del servo mandi un comando M280 P0 S65 e inserisci la camma colla punta in direzione dell' asse dello stepper. Dopo di questo puoi dare i comandi di cambio hotend T0 e T1 e verificare la corretta commutazione.
Gianni
Re: doppio hotend per hips o pva September 25, 2015 11:05AM |
Re: doppio hotend per hips o pva September 25, 2015 12:55PM |
Re: doppio hotend per hips o pva September 25, 2015 01:19PM |
Re: doppio hotend per hips o pva September 25, 2015 01:27PM |
Re: doppio hotend per hips o pva September 26, 2015 12:01PM |
Re: doppio hotend per hips o pva September 26, 2015 01:11PM |
Re: doppio hotend per hips o pva September 26, 2015 02:37PM |
Re: doppio hotend per hips o pva September 27, 2015 09:42AM |
#define DEFAULT_MAX_FEEDRATE {300, 300, 2, 45, 45, 100, 100} #define MANUAL_FEEDRATE {40*60, 40*60, 3*60, 60} // Feedrates for manual moves along X, Y, Z, E from panel #define DEFAULT_MINIMUMFEEDRATE 0.0 // minimum feedrate #define DEFAULT_MINTRAVELFEEDRATE 0.0 // Maximum start speed for accelerated moves. X, Y, Z, E0...(per extruder) #define DEFAULT_MAX_ACCELERATION {2000, 2000, 10, 1000, 1000, 1000, 1000} // Maximum acceleration in mm/s^2 for retracts E0... (per extruder) #define DEFAULT_RETRACT_ACCELERATION {3000, 3000, 3000, 3000} // X, Y, Z and E* maximum acceleration in mm/s^2 for printing moves #define DEFAULT_ACCELERATION 2500 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves #define DEFAULT_TRAVEL_ACCELERATION 3000
Re: doppio hotend per hips o pva September 27, 2015 11:36AM |
/***************************************************************************************** ********************************** Axis feedrate **************************************** *****************************************************************************************/ // X, Y, Z, E0...(per extruder). (mm/sec) #define DEFAULT_MAX_FEEDRATE {300, 300, 2, 100, 100, 100, 100} #define MANUAL_FEEDRATE {50*60, 50*60, 4*60, 60} // Feedrates for manual moves along X, Y, Z, E from panel #define DEFAULT_MINIMUMFEEDRATE 0.0 // minimum feedrate #define DEFAULT_MINTRAVELFEEDRATE 0.0 // Minimum planner junction speed. Sets the default minimum speed the planner plans for at the end // of the buffer and all stops. This should not be much greater than zero and should only be changed // if unwanted behavior is observed on a user's machine when running at very slow speeds. #define MINIMUM_PLANNER_SPEED 0.05 // (mm/sec) /*****************************************************************************************/ /***************************************************************************************** ******************************** Axis accelleration ************************************* *****************************************************************************************/ // Maximum start speed for accelerated moves. X, Y, Z, E0...(per extruder) #define DEFAULT_MAX_ACCELERATION {1000,1000,50,500,500,500,500} // Maximum acceleration in mm/s^2 for retracts E0... (per extruder) #define DEFAULT_RETRACT_ACCELERATION {10000, 10000, 10000, 10000} // X, Y, Z and E* maximum acceleration in mm/s^2 for printing moves #define DEFAULT_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves #define DEFAULT_TRAVEL_ACCELERATION 3000 /*****************************************************************************************/
Re: doppio hotend per hips o pva September 27, 2015 01:50PM |
Re: doppio hotend per hips o pva September 28, 2015 12:02PM |
Re: doppio hotend per hips o pva September 28, 2015 12:32PM |
Re: doppio hotend per hips o pva September 28, 2015 12:57PM |
Re: doppio hotend per hips o pva September 29, 2015 03:40AM |
Re: doppio hotend per hips o pva September 29, 2015 05:41AM |
Re: doppio hotend per hips o pva September 29, 2015 08:45AM |
Re: doppio hotend per hips o pva September 30, 2015 02:14AM |
Re: doppio hotend per hips o pva October 12, 2015 12:53PM |
Re: doppio hotend per hips o pva October 12, 2015 01:39PM |
Re: doppio hotend per hips o pva October 13, 2015 03:54AM |
Re: doppio hotend per hips o pva October 13, 2015 04:46AM |
Re: doppio hotend per hips o pva November 20, 2015 05:02AM |
CiaoQuote
bilanciamist
il dondolo è una buona idea, ma mi sembra parecchio massiccio... Sarebbe interessante una versione bowden del dondolo.
Per quanto riguarda il prezzo, io conto di usare l'hotend che ho già, ma bisogna vedere se è compatibile, oltre al motore.
Re: doppio hotend per hips o pva November 20, 2015 05:10AM |
Re: doppio hotend per hips o pva November 20, 2015 05:40AM |
non ho capito bene cosa vuoi intendere in merito alla filosofia di base!!Quote
bilanciamist
io sto montando il dondolo standard, anche se per lavoro ultimamente non riesco a trovare il tempo da dedicargli.
Penso che un dondolo bowden sarebbe interessante, ma sarebbe molto difficile da creare, essendo quasi opposto alla filosofia di base del dondolo di concentrare tutto sul carrello con un solo motore...
Re: doppio hotend per hips o pva November 20, 2015 06:08AM |
Re: doppio hotend per hips o pva November 20, 2015 06:28AM |
grazie Gianni per la risposta celere!Quote
[email protected]
Analisi dei pesi (rispetto ad un mono non-bowden e ad un Dondolo bowden):
Dondolo con HE E3D v6 560gr
Dondolo con HE E3D Lite 600gr
BQ WitBox (singolo) 570gr
Dondolo bowden con HE E3D v6 340gr + il peso di un "sistema di pivoting del pendolo che sostituisca l' albero del motore". (il motore pesa 220gr).
Quindi la massa è confrontabile con quella dei mono (non-bowden).
L' ulteriore riduzione dei pesi mediante sistema bowden consente sicuramente velocità di SPOSTAMENTO maggiori. Le velocità di stampa EFFETTIVE (non quelle dichiarate dai produttori furboni come "fino a" o "massima") sono limitate più dal tipo di materiale, all' alltezza del layer, larghezza della linea etc. che dalla massa della testa di estrusione.
Rispetto a molti mono è sicuramente più bilanciato (nel senso che il suo centro di massa è molto vicino al piano X-Z ), porre i distanziali sui supporti dell' asse Z anzichè sull' X-Carriage non è un vezzo. Il sistema di trascinamento (con i componenti che suggerisco) è quasi perfetto e te ne accorgi sia quando stampi le gomme morbide sia quando stampi modelli bicolore molto "strutturati" dove puoi permetterti di attivare incondizionatamente la ritrazione senza che il filamento venga "macinato".
Il Dondolo è stato pensato per stampare con due colori e/o con due materiali e/o con due nozzle di diametro diverso, non per sputare plastica alla "come viene viene", le stampe che di tanto in tanto posto in qualche gruppo o su Thingiverse lo attestano.
Analisi dei costi (rispetto ad un sistema bowden o ad un Dondolo bowden):
Rispetto ad un Dondolo bowden devi aggiungere 1 motore ed 1 driver.
Rispetto ad un bowden "classico" devi aggiungere 1 motore ed 1 driver e sottrarre un servo.
Considerando che un servo costa praticamente come un motore nella peggiore delle ipotesi risparmi un driver (cioè il Dondolo è sempre più economico).
Gianni.
Re: doppio hotend per hips o pva November 20, 2015 06:47AM |
Re: doppio hotend per hips o pva November 20, 2015 07:50AM |
