dubbio su pulizia ugello microswiss mk10 August 16, 2018 03:10PM |
Re: dubbio su pulizia ugello microswiss mk10 August 16, 2018 04:59PM |
Re: dubbio su pulizia ugello microswiss mk10 August 17, 2018 05:28AM |
Re: dubbio su pulizia ugello microswiss mk10 August 17, 2018 06:15AM |
Re: dubbio su pulizia ugello microswiss mk10 August 17, 2018 07:46AM |
Re: dubbio su pulizia ugello microswiss mk10 August 17, 2018 07:50AM |
Re: dubbio su pulizia ugello microswiss mk10 August 17, 2018 09:16AM |
Re: dubbio su pulizia ugello microswiss mk10 August 17, 2018 06:47PM |
Re: dubbio su pulizia ugello microswiss mk10 August 18, 2018 04:47AM |
Re: dubbio su pulizia ugello microswiss mk10 August 18, 2018 05:23AM |
Re: dubbio su pulizia ugello microswiss mk10 August 18, 2018 06:12AM |
Re: dubbio su pulizia ugello microswiss mk10 August 18, 2018 03:13PM |
Re: dubbio su pulizia ugello microswiss mk10 August 19, 2018 05:27AM |
Re: dubbio su pulizia ugello microswiss mk10 August 19, 2018 12:44PM |
Re: dubbio su pulizia ugello microswiss mk10 August 20, 2018 05:49AM |
Re: dubbio su pulizia ugello microswiss mk10 August 20, 2018 05:55AM |
losco
...ma i pezzi erano assolutamente magri tanto che sembravano fili sovrapposti non uniti
Re: dubbio su pulizia ugello microswiss mk10 August 20, 2018 10:45AM |
M92 E300.9
M92 E295.0
Re: dubbio su pulizia ugello microswiss mk10 August 21, 2018 03:29AM |
Re: dubbio su pulizia ugello microswiss mk10 August 21, 2018 04:42AM |
Re: dubbio su pulizia ugello microswiss mk10 August 27, 2018 04:25AM |
Re: dubbio su pulizia ugello microswiss mk10 September 02, 2018 10:48AM |
; generated by Slic3r 1.3.0 on 2018-05-18 at 17:58:25 ; external perimeters extrusion width = 0.44mm (3.86mm^3/s) ; perimeters extrusion width = 0.56mm (10.05mm^3/s) ; infill extrusion width = 0.50mm (8.93mm^3/s) ; solid infill extrusion width = 0.56mm (5.03mm^3/s) ; top infill extrusion width = 0.56mm (4.02mm^3/s) ; support material extrusion width = 0.44mm (9.66mm^3/s)
; filament used = 2986.3mm (7.2cm3) ; total filament cost = 0.0 ; avoid_crossing_perimeters = 1 ; bed_shape = 10x10,210x10,210x210,10x210 ; bed_temperature = 95 ; before_layer_gcode = ; between_objects_gcode = ; bridge_acceleration = 0 ; bridge_fan_speed = 50 ; brim_connections_width = 2 ; brim_width = 3 ; complete_objects = 0 ; cooling = 0 ; default_acceleration = 0 ; disable_fan_first_layers = 3 ; duplicate_distance = 6 ; end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n" ; end_gcode = M104 S0 ; turn off hotend\nM140 S0 ; turn off bed \nG28 X0 ; home X axis\nM84 ; disable motors\n ; extruder_clearance_height = 20 ; extruder_clearance_radius = 20 ; extruder_offset = 0x0 ; extrusion_axis = E ; extrusion_multiplier = 1 ; fan_always_on = 0 ; fan_below_layer_time = 60 ; filament_colour = #FFFFFF ; filament_cost = 0 ; filament_density = 0 ; filament_diameter = 1.75 ; filament_max_volumetric_speed = 0 ; filament_notes = "" ; first_layer_acceleration = 0 ; first_layer_bed_temperature = 100 ; first_layer_extrusion_width = 200% ; first_layer_speed = 30 ; first_layer_temperature = 245 ; gcode_arcs = 0 ; gcode_comments = 0 ; gcode_flavor = reprap ; has_heatbed = 1 ; infill_acceleration = 0 ; infill_first = 0 ; interior_brim_width = 2 ; layer_gcode = ; max_fan_speed = 100 ; max_layer_height = 0.3 ; max_print_speed = 80 ; max_volumetric_speed = 0 ; min_fan_speed = 35 ; min_layer_height = 0.15 ; min_print_speed = 10 ; min_skirt_length = 10 ; notes = ; nozzle_diameter = 0.4 ; only_retract_when_crossing_perimeters = 1 ; ooze_prevention = 0 ; output_filename_format = [input_filename_base].gcode ; perimeter_acceleration = 0 ; post_process = ; pressure_advance = 0 ; printer_notes = ; resolution = 0 ; retract_before_travel = 2 ; retract_layer_change = 0 ; retract_length = 2 ; retract_length_toolchange = 10 ; retract_lift = 0 ; retract_lift_above = 0 ; retract_lift_below = 0 ; retract_restart_extra = 0 ; retract_restart_extra_toolchange = 0 ; retract_speed = 40 ; skirt_distance = 6 ; skirt_height = 1 ; skirts = 1 ; slowdown_below_layer_time = 5 ; spiral_vase = 0 ; standby_temperature_delta = -5 ; start_filament_gcode = "; Filament gcode\n" ; start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\nG92 E0 ; reset extruder\nG1 E3 F1200 ; prime extruder 3mm\nG1 E2 F1200 ; retract extruder 1mm\nG92 E0 ; reset extruder\n ; temperature = 240 ; threads = 4 ; toolchange_gcode = ; travel_speed = 300 ; use_firmware_retraction = 0 ; use_relative_e_distances = 0 ; use_set_and_wait_bed = 0 ; use_set_and_wait_extruder = 0 ; use_volumetric_e = 0 ; vibration_limit = 0 ; wipe = 0 ; z_offset = -0.08 ; z_steps_per_mm = 0 ; adaptive_slicing = 0 ; adaptive_slicing_quality = 75% ; dont_support_bridges = 0 ; extrusion_width = 0 ; first_layer_height = 0.27 ; infill_only_where_needed = 0 ; interface_shells = 0 ; layer_height = 0.25 ; match_horizontal_surfaces = 0 ; raft_layers = 0 ; regions_overlap = 0 ; seam_position = aligned ; sequential_print_priority = 0 ; support_material = 1 ; support_material_angle = 0 ; support_material_buildplate_only = 0 ; support_material_contact_distance = 0.05 ; support_material_enforce_layers = 0 ; support_material_extruder = 1 ; support_material_extrusion_width = 0 ; support_material_interface_extruder = 1 ; support_material_interface_extrusion_width = 0 ; support_material_interface_layers = 3 ; support_material_interface_spacing = 0 ; support_material_interface_speed = 100% ; support_material_max_layers = 0 ; support_material_pattern = pillars ; support_material_spacing = 5 ; support_material_speed = 100 ; support_material_threshold = 60% ; xy_size_compensation = 0 ; bottom_infill_pattern = rectilinear ; bottom_solid_layers = 3 ; bridge_flow_ratio = 1 ; bridge_speed = 60 ; external_perimeter_extrusion_width = 0 ; external_perimeter_speed = 50% ; external_perimeters_first = 0 ; extra_perimeters = 1 ; fill_angle = 45 ; fill_density = 30% ; fill_gaps = 1 ; fill_pattern = honeycomb ; gap_fill_speed = 20 ; infill_every_layers = 1 ; infill_extruder = 1 ; infill_extrusion_width = 0 ; infill_overlap = 15% ; infill_speed = 80 ; overhangs = 1 ; perimeter_extruder = 1 ; perimeter_extrusion_width = 0 ; perimeter_speed = 80 ; perimeters = 4 ; small_perimeter_speed = 15 ; solid_infill_below_area = 70 ; solid_infill_every_layers = 7 ; solid_infill_extruder = 1 ; solid_infill_extrusion_width = 0 ; solid_infill_speed = 50% ; thin_walls = 1 ; top_infill_extrusion_width = 0 ; top_infill_pattern = rectilinear ; top_solid_infill_speed = 80% ; top_solid_layers = 3
Re: dubbio su pulizia ugello microswiss mk10 September 03, 2018 06:29AM |
