Full Graphics su Ramps 1.4 February 18, 2016 03:28AM |
#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER, ricevo il messaggio d'errore
In file included from sketch/dogm_lcd_implementation.h:40:0, from sketch/ultralcd.cpp:36: sketch/ultralcd_st7920_u8glib_rrd.h: In function 'uint8_t u8g_dev_rrd_st7920_128x64_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)': sketch/ultralcd_st7920_u8glib_rrd.h:40:95: warning: large integer implicitly truncated to unsigned type [-Woverflow] #define ST7920_WRITE_BYTE(a) {ST7920_SWSPI_SND_8BIT((a)&0xf0);ST7920_SWSPI_SND_8BIT((a)<<4);u8g_10MicroDelay();} ^ sketch/ultralcd_st7920_u8glib_rrd.h:63:9: note: in expansion of macro 'ST7920_WRITE_BYTE' ST7920_WRITE_BYTE(0x3E); //extended mode + GDRAM active ^ sketch/ultralcd_st7920_u8glib_rrd.h:40:95: warning: large integer implicitly truncated to unsigned type [-Woverflow] #define ST7920_WRITE_BYTE(a) {ST7920_SWSPI_SND_8BIT((a)&0xf0);ST7920_SWSPI_SND_8BIT((a)<<4);u8g_10MicroDelay();} ^ sketch/ultralcd_st7920_u8glib_rrd.h:67:11: note: in expansion of macro 'ST7920_WRITE_BYTE' ST7920_WRITE_BYTE(0x80); //set x = 0 ^ sketch/ultralcd_st7920_u8glib_rrd.h:40:95: warning: large integer implicitly truncated to unsigned type [-Woverflow] #define ST7920_WRITE_BYTE(a) {ST7920_SWSPI_SND_8BIT((a)&0xf0);ST7920_SWSPI_SND_8BIT((a)<<4);u8g_10MicroDelay();} ^ sketch/ultralcd_st7920_u8glib_rrd.h:94:13: note: in expansion of macro 'ST7920_WRITE_BYTE' ST7920_WRITE_BYTE(0x80); //x=0 ^ sketch/ultralcd_st7920_u8glib_rrd.h:40:95: warning: large integer implicitly truncated to unsigned type [-Woverflow] #define ST7920_WRITE_BYTE(a) {ST7920_SWSPI_SND_8BIT((a)&0xf0);ST7920_SWSPI_SND_8BIT((a)<<4);u8g_10MicroDelay();} ^ sketch/ultralcd_st7920_u8glib_rrd.h:99:13: note: in expansion of macro 'ST7920_WRITE_BYTE' ST7920_WRITE_BYTE(0x80 | 8); //x=64 ^ sketch/ultralcd.cpp: In function 'void config_lcd_level_bed()': ultralcd.cpp:758: error: 'lcd' was not declared in this scope lcd.clear(); ^ sketch/ultralcd.cpp: In function 'void lcd_level_bed_cooling()': ultralcd.cpp:769: error: 'lcd' was not declared in this scope lcd.setCursor(0, 0); ^ ultralcd.cpp:791: error: 'lcd' was not declared in this scope lcd.clear(); ^ sketch/ultralcd.cpp: In function 'void lcd_level_bed()': ultralcd.cpp:800: error: 'lcd' was not declared in this scope lcd.clear(); ^ sketch/ultralcd.cpp: In function 'void lcd_load_material_extrud_1()': ultralcd.cpp:944: error: 'lcd' was not declared in this scope lcd.setCursor(3, 2); ^ sketch/ultralcd.cpp: In function 'void lcd_unload_material_extrud_1()': ultralcd.cpp:990: error: 'lcd' was not declared in this scope lcd.setCursor(3, 2); ^ sketch/ultralcd.cpp: In function 'void lcd_init()': ultralcd.cpp:1418: error: 'lcd' was not declared in this scope lcd.clear(); ^ exit status 1 'lcd' was not declared in this scope...che s'ha da fa?
Re: Full Graphics su Ramps 1.4 February 18, 2016 04:08AM |
Re: Full Graphics su Ramps 1.4 February 23, 2016 07:57AM |
