Marlinkimbra4due & MAX6675 March 01, 2016 12:53PM |
Re: Marlinkimbra4due & MAX6675 March 01, 2016 02:31PM |
Re: Marlinkimbra4due & MAX6675 March 01, 2016 08:23PM |
Re: Marlinkimbra4due & MAX6675 March 02, 2016 12:16PM |
Re: Marlinkimbra4due & MAX6675 March 02, 2016 12:22PM |
Re: Marlinkimbra4due & MAX6675 March 02, 2016 02:34PM |
Re: Marlinkimbra4due & MAX6675 March 02, 2016 03:52PM |
Re: Marlinkimbra4due & MAX6675 March 03, 2016 02:20PM |
Re: Marlinkimbra4due & MAX6675 March 03, 2016 03:46PM |
Re: Marlinkimbra4due & MAX6675 March 03, 2016 03:53PM |
start
Info: PowerUp
MK4due_4.2.7_dev
Last Updated: Mar 3 2016 21:59:30 | Author: (none, default config)
Compiled: Mar 3 2016
Free Memory: 85776 PlannerBufferBytes: 2688
ok Hardcoded SD Default Settings Loaded
Echo: Hardcoded Default Settings Loaded
Config: Steps per unit:
Config: M92 X80.00 Y80.00 Z80.00 E625.00
Config: Maximum feedrates (mm/s):
Config: M203 X500.00 Y500.00 Z500.00 E100.00
Config: Maximum Acceleration (mm/s2):
Config: M201 X5000 Y5000 Z5000 E1000
Config: Accelerations: P=printing, V=travel and T* R=retract
Config: M204 P3000.00 V3000.00
Config: M204 T0 R10000.00
Config: Advanced variables: S=Min feedrate (mm/s), V=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Config: M205 S0.00 V0.00 B20000 X20.00 Z20.00 E5.00
Config: Home offset (mm):
Config: M206 X0.00 Y0.00 Z0.00
Config: Delta Geometry adjustment:
Config: M666 A0.000 B0.000 C0.000 I0.000 J0.000 K0.000 U0.000 V0.000 W0.000 R110.00 D220.00 H200.00
Config: Endstop Offsets:
Config: M666 X0.00 Y0.00 Z0.00
Config: Z-Probe Offset:
Config: M666 P X0.00 Y0.00 Z-1.00
Config: Material heatup parameters:
Config: M145 S0 H190 B60 F255 (Material PLA)
Config: M145 S1 H240 B100 F255 (Material ABS)
Config: M145 S2 H230 B60 F255 (Material GUM)
Config: PID settings:
Config: M301 H0 P40.00 I7.00 D60.00
Config: Filament settings: Disabled
Info: Power on time:
Info: 0 days 0 hours 0 minutes
Info: Filament printed:
Info: 0 Km 0 m 0 cm 0 mm
First start for temperature finished.
Echo: SD card ok
Re: Marlinkimbra4due & MAX6675 March 04, 2016 03:51AM |
#include util/delay.h
_delay_ms(1);
Re: Marlinkimbra4due & MAX6675 March 04, 2016 06:02AM |
Re: Marlinkimbra4due & MAX6675 March 04, 2016 06:33AM |
Re: Marlinkimbra4due & MAX6675 March 04, 2016 07:45AM |
byte MAX6675::spiread(void) {
int i;
byte d = 0;
for (i=7; i>=0; i--)
digitalWrite(sclk, LOW);
_delay_ms(1);
if (digitalRead(miso)) {
//set the bit to 0 no matter what
d |= (1 << i);
digitalWrite(sclk, HIGH);
_delay_ms(1);
return d;
Re: Marlinkimbra4due & MAX6675 March 04, 2016 08:44AM |
Re: Marlinkimbra4due & MAX6675 March 04, 2016 10:46AM |
Re: Marlinkimbra4due & MAX6675 March 04, 2016 09:33PM |
Re: Marlinkimbra4due & MAX6675 March 05, 2016 02:38AM |
Re: Marlinkimbra4due & MAX6675 March 05, 2016 03:58AM |
Re: Marlinkimbra4due & MAX6675 March 05, 2016 04:27AM |
Re: Marlinkimbra4due & MAX6675 March 05, 2016 04:43AM |
Re: Marlinkimbra4due & MAX6675 March 05, 2016 11:28AM |
Re: Marlinkimbra4due & MAX6675 May 26, 2016 06:01AM |
