Nel tentativo di caricare un firmware su una Mega Ramps ricevo ripetutamente un errore che non capisco. Qualcuno mi può aiutare?
Riporto il messaggio di errore copiato
Arduino:1.8.8 (Windows 10), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch\src/inc/pins.h:26:0,
from sketch\MK4duo.h:104,
from \\C\3d\stampa\R9\Firmware\MK4duo\MK4duo.ino:324:
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\src\boards\33.h:252:0: warning: "ORIG_BEEPER_PIN" redefined
#define ORIG_BEEPER_PIN 37
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\src\boards\33.h:148:0: note: this is the location of the previous definition
#define ORIG_BEEPER_PIN NoPin
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\src\boards\33.h:263:0: warning: "SD_DETECT_PIN" redefined
#define SD_DETECT_PIN 49
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\src\boards\33.h:151:0: note: this is the location of the previous definition
#define SD_DETECT_PIN NoPin
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\src\boards\33.h:264:0: warning: "KILL_PIN" redefined
#define KILL_PIN 41
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\src\boards\33.h:153:0: note: this is the location of the previous definition
#define KILL_PIN NoPin
In file included from sketch\src/inc/pins.h:234:0,
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\configuration_pins.h:143:0: warning: "Z2_MIN_PIN" redefined
#define Z2_MIN_PIN -1
In file included from sketch\MK4duo.h:104:0,
sketch\src/inc/pins.h:189:0: note: this is the location of the previous definition
#define Z2_MIN_PIN NoPin
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\configuration_pins.h:144:0: warning: "Z3_MIN_PIN" redefined
#define Z3_MIN_PIN -1
sketch\src/inc/pins.h:195:0: note: this is the location of the previous definition
#define Z3_MIN_PIN NoPin
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\configuration_pins.h:147:0: warning: "Z2_MAX_PIN" redefined
#define Z2_MAX_PIN -1
sketch\src/inc/pins.h:192:0: note: this is the location of the previous definition
#define Z2_MAX_PIN NoPin
c:\users\stefano\appdata\local\temp\arduino_build_161532\sketch\configuration_pins.h:148:0: warning: "Z3_MAX_PIN" redefined
#define Z3_MAX_PIN -1
sketch\src/inc/pins.h:198:0: note: this is the location of the previous definition
#define Z3_MAX_PIN NoPin
In file included from sketch\MK4duo.h:105:0,
sketch\src/inc/conditionals_post.h:463:0: warning: "X_STALL_SENSITIVITY" redefined
#define X_STALL_SENSITIVITY 0
In file included from sketch\MK4duo.h:70:0,
sketch\Configuration_Overall.h:845:0: note: this is the location of the previous definition
#define X_STALL_SENSITIVITY 8
sketch\src/inc/conditionals_post.h:464:0: warning: "Y_STALL_SENSITIVITY" redefined
#define Y_STALL_SENSITIVITY 0
sketch\Configuration_Overall.h:846:0: note: this is the location of the previous definition
#define Y_STALL_SENSITIVITY 8
sketch\src/inc/conditionals_post.h:465:0: warning: "Z_STALL_SENSITIVITY" redefined
#define Z_STALL_SENSITIVITY 0
sketch\Configuration_Overall.h:847:0: note: this is the location of the previous definition
#define Z_STALL_SENSITIVITY 8
In file included from sketch\MK4duo.h:127:0,
sketch\src/core/planner/planner.h:70:30: warning: static data member '::active_extruder' in unnamed class [-fpermissive]
static constexpr uint8_t active_extruder = 0;
sketch\src/core/planner/planner.h:46:16: note: unnamed class defined here
typedef struct {
Lo sketch usa 125050 byte (49%) dello spazio disponibile per i programmi. Il massimo è 253952 byte.
Le variabili globali usano 4402 byte (53%) di memoria dinamica, lasciando altri 3790 byte liberi per le variabili locali. Il massimo è 8192 byte.
Errore durante il caricamento dello sketch
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni"
