Kossel non esegue il G29 Non Risolto December 28, 2019 03:46PM |
#define _CONFIGURATION_DELTA_H_ #define KNOWN_MECH #define CUSTOM_MACHINE_NAME "Kossel" #define DELTA_SEGMENTS_PER_SECOND 200 #define DELTA_SEGMENTS_PER_LINE 20 #define DELTA_DIAGONAL_ROD 320 #define DELTA_SMOOTH_ROD_OFFSET 229 #define DELTA_EFFECTOR_OFFSET 35 #define DELTA_CARRIAGE_OFFSET 35 #define DELTA_HEIGHT 353 #define DELTA_PRINTABLE_RADIUS 115
#define Z_PROBE_SERVO_NR 0 #define Z_SERVO_ANGLES {10,90} //#define PROBE_MANUALLY //#define Z_PROBE_FIX_MOUNTED #define BLTOUCH //#define BLTOUCH_DELAY 375 // (ms) Enable and increase if needed //#define Z_PROBE_ALLEN_KEY //#define Z_PROBE_SENSORLESS #define Z_PROBE_DEPLOY_START_LOCATION {0,0,30} #define Z_PROBE_DEPLOY_END_LOCATION {0,0,30} #define Z_PROBE_RETRACT_START_LOCATION {0,0,30} #define Z_PROBE_RETRACT_END_LOCATION {0,0,30} #define X_PROBE_OFFSET_FROM_NOZZLE -3 #define Y_PROBE_OFFSET_FROM_NOZZLE 23 #define Z_PROBE_OFFSET_FROM_NOZZLE -3
Re: Kossel non esegue il G29 Non Risolto December 29, 2019 02:15AM |
13:57:25.100 : Config: G21 ; Units in (mm) 13:57:25.100 : Configteps per unit: 13:57:25.100 : Config: M92 X100.000 T0 E451.000 13:57:25.100 : Config:Maximum feedrates (units/s): 13:57:25.100 : Config: M203 X500.000 T0 E45.000 13:57:25.100 : Config:Maximum Acceleration (units/s2): 13:57:25.100 : Config: M201 X5000 T0 E1000 13:57:25.116 : Config:Acceleration (units/s2): P V T* R 13:57:25.116 : Config: M204 P2000.000 V2000.000 T0 R5000.000 13:57:25.116 : Config:Advanced: B S V 13:57:25.116 : Config: M205 B20000 S0.000 V0.000 13:57:25.116 : Config:Jerk: X T* E 13:57:25.116 : Config: M205 X10.000 T0 E5.000 13:57:25.116 : Config:Endstop adjustment: 13:57:25.132 : Config: M666 X0.00 Y0.00 Z0.00 13:57:25.132 : Configelta Geometry adjustment: ABC IJK UVW 13:57:25.132 : Config: M666 A0.000 B0.000 C0.000 I0.000 J0.000 K0.000 U0.000 V0.000 W0.000 13:57:25.132 : Configelta Geometry adjustment: R D 13:57:25.132 : Config: M666 R159.00 D320.00 13:57:25.132 : Configelta Geometry adjustment: S L 13:57:25.132 : Config: M666 S200 L20 13:57:25.147 : Configelta Geometry adjustment: O P H 13:57:25.147 : Config: M666 O115.00 P92.00 H347.740 13:57:25.147 : Config:Heater Sensor parameters: H P T A B C R L O: 13:57:25.147 : Config: M305 H0 P0 T4 A100000.0 B4725.0 C0.0000000000 R4700.0 L0 O0 13:57:25.163 : Config:Heater parameters: H P A B C L O U I T: 13:57:25.163 : Config: M306 H0 P3 A40 B230 C255 L5 O275 U1 I0 T0 13:57:25.163 : Config:Heater PID parameters: H P I D: 13:57:25.163 : Config: M301 H0 P40.00 I8.00 D60.00 13:57:25.179 : Config:Heater Sensor parameters: H P T A B C R L O: 13:57:25.179 : Config: M305 H-1 P1 T4 A100000.0 B4725.0 C0.0000000000 R4700.0 L0 O0 13:57:25.179 : Config:Heater parameters: H P A B C L O U I T: 13:57:25.194 : Config: M306 H-1 P2 A40 B230 C255 L5 O150 U0 I0 T0 13:57:25.194 : Config:Fans: P U L X F I H T 13:57:25.194 : Config: M106 P0 U5 L0 X255 F250 I0 H-1 13:57:25.194 : Config:Fans: P U L X F I H T 13:57:25.194 : Config: M106 P1 U6 L0 X255 F250 I0 H-1 13:57:25.194 : Config:Endstops logic: 13:57:25.194 : Config: M123 X0 Y0 Z0 P1 13:57:25.194 : Config:Endstops pullup: 13:57:25.210 : Config: M124 X1 Y1 Z1 P1 13:57:25.210 : Config: M149 C ; Units in Celsius 13:57:25.210 : Configervo Angles: P L U: 13:57:25.210 : Config: M281 P0 L10 U90 13:57:25.210 : Config:Auto Bed Leveling 13:57:25.210 : Config: M420 S0 13:57:25.210 : Configrobe Offset X Y Z, speed Fast and Slow [mm/min], Repetitions (mm): 13:57:25.210 : Config: M851 X-3.000 Y-23.000 Z-3.000 F1000 S500 R1 13:57:25.210 : Config:Material heatup parameters 13:57:25.210 : Config: M145 S0 H190 B60 F255 13:57:25.210 : Config: M145 S1 H240 B100 F255 13:57:25.225 : Config: M145 S2 H230 B60 F255 13:57:25.225 : Configtepper Direction 13:57:25.225 : Config: M569 X0 Y0 Z0 T0 E0 13:57:25.225 : Configtepper driver control 13:57:25.225 : Config: M569 D0 P0 R500000 13:57:25.225 : Stats: Total:35, Finished:35, Failed:0 13:57:25.225 : Stats: Total print time:1d 17h 18m 43s, Longest job:5h 8m 12s 13:57:25.225 : Stats: Power on time:1d 19h 50m 20s 13:57:25.225 : Stats: Filament used:116m 68cm 4mm 13:57:36.426 : X:0.00 Y:0.00 Z:283.600 E:0.0000 14:00:52.524 : DebugLevel:6 14:00:55.570 : X:0.00 Y:0.00 Z:283.600 E:0.0000 14:00:58.366 : ? (L,R,F, out of bounds.
Re: Kossel non esegue il G29 Non Risolto January 01, 2020 07:57AM |
Re: Kossel non esegue il G29 Non Risolto January 02, 2020 01:00AM |
Re: Kossel non esegue il G29 Risolto January 07, 2020 01:05AM |
