ABL piatto non livellato January 31, 2020 02:29PM |
20:16:44.743 : echo:Bilinear Leveling Grid: 20:16:44.743 : echo: 0 1 2 3 4 5 6 20:16:44.748 : echo: 0 -0.000 -0.020 -0.080 -0.060 -0.010 -0.030 -0.137 20:16:44.748 : echo: 1 -0.030 -0.040 -0.080 -0.090 -0.120 -0.130 -0.070 20:16:44.752 : echo: 2 -0.050 -0.030 -0.050 -0.040 -0.000 -0.010 -0.040 20:16:44.752 : echo: 3 +0.040 +0.010 -0.030 -0.050 -0.080 -0.090 -0.120 20:16:44.756 : echo: 4 +0.010 -0.020 -0.020 -0.040 -0.030 -0.010 -0.010 20:16:44.760 : echo: 5 +0.030 +0.040 +0.020 -0.020 -0.030 -0.040 -0.050 20:16:44.760 : echo: 6 +0.070 +0.060 +0.020 +0.000 +0.010 +0.040 +0.050 20:36:24.586 : Configrobe Offset X Y Z, speed Fast and Slow [mm/min], Repetitions (mm): 20:36:24.602 : Config: M851 X0.000 Y24.500 Z-2.380 F1000 S500 R1 20:26:20.537 : Configelta Geometry adjustment: O P H 20:26:20.537 : Config: M666 O105.00 P70.00 H339.754
Re: ABL piatto non livellato February 01, 2020 02:41PM |
20:35:16.953 : echo: 0 1 2 3 4 5 6 20:35:16.953 : echo: 0 +0.067 +0.070 -0.000 -0.090 -0.080 -0.027 +0.032 20:35:16.953 : echo: 1 -0.050 +0.050 -0.010 -0.060 -0.100 -0.070 +0.120 20:35:16.953 : echo: 2 +0.010 -0.090 -0.090 -0.070 -0.070 -0.010 +0.000 20:35:16.953 : echo: 3 -0.010 -0.040 -0.090 -0.110 -0.150 -0.120 -0.120 20:35:16.968 : echo: 4 -0.080 -0.140 -0.140 -0.140 -0.130 -0.110 -0.070 20:35:16.968 : echo: 5 -0.120 -0.120 -0.130 -0.180 -0.170 -0.190 -0.190 20:35:16.968 : echo: 6 +0.020 -0.240 -0.250 -0.230 -0.240 -0.200 -0.100
Re: ABL piatto non livellato February 03, 2020 08:56AM |
Re: ABL piatto non livellato February 03, 2020 03:09PM |
21:07:42.230 : Configrobe Offset X Y Z, speed Fast and Slow [mm/min], Repetitions (mm): 21:07:42.230 : Config: M851 X-2.000 Y20.000 Z-2.318 F1000 S500 R1 21:16:42.380 : Configelta Geometry adjustment: O P H 21:16:42.380 : Config: M666 O110.00 P85.00 H333.400 21:16:15.515 : echo:Bilinear Leveling Grid: 21:16:15.531 : echo: 0 1 2 3 4 5 6 21:16:15.531 : echo: 0 -0.057 -0.143 -0.150 -0.230 -0.220 -0.447 -0.463 21:16:15.531 : echo: 1 -0.067 -0.170 -0.130 -0.180 -0.220 -0.250 -0.213 21:16:15.531 : echo: 2 -0.230 -0.180 -0.130 -0.110 -0.090 -0.090 -0.160 21:16:15.531 : echo: 3 -0.080 -0.020 -0.040 -0.020 -0.060 -0.090 -0.180 21:16:15.531 : echo: 4 -0.060 -0.080 -0.010 +0.050 +0.060 +0.050 +0.000 21:16:15.531 : echo: 5 +0.020 +0.050 +0.100 +0.080 +0.100 +0.060 -0.020 21:16:15.547 : echo: 6 -0.000 +0.050 +0.060 +0.110 +0.080 +0.070 +0.524
Re: ABL piatto non livellato February 03, 2020 03:26PM |
Re: ABL piatto non livellato February 03, 2020 03:40PM |
Ok però non riesco ad andare sotto i 20mm su Y praticamente non ho lo spazio per farlo lo spazio tra Hothend e Bltouch è minimo. Potrebbe magari funzionare meglio la sonda della Delta Anycubic Linear, adattandolo, che sonda sotto il nozzle, memorizzi la griglia e lo togli?Quote
MagoKimbra
Come vedi l'offset grande è su Y e proprio su Y hai il problema... Maggiore è l'offset maggiore è l'errore, soprattutto sulla delta...
Il top sarebbe offset 0 cioè avere la sonda esattamente sul nozzle. Altrimenti avrai sempre un minimo di errore..
