Marlin e Heater Cartridge 12V/40W
March 23, 2014 09:14AM
Ciao Ragazzi!
Che numero devo inserire in Marlin, tra quelli in lista, per questa Heater Cartridge? [www.ebay.it]
//=============================Thermal Settings ============================
//--NORMAL IS 4.7kohm PULLUP!-- 1kohm pullup can be used on hotend sensor, using correct resistor and table
//// Temperature sensor settings:
// -2 is thermocouple with MAX6675 (only for sensor 0)
// -1 is thermocouple with AD595
// 0 is not used
// 1 is 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
// 2 is 200k thermistor - ATC Semitec 204GT-2 (4.7k pullup)
// 3 is mendel-parts thermistor (4.7k pullup)
// 4 is 10k thermistor !! do not use it for a hotend. It gives bad resolution at high temp. !!
// 5 is 100K thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (4.7k pullup)
// 6 is 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
// 7 is 100k Honeywell thermistor 135-104LAG-J01 (4.7k pullup)
// 71 is 100k Honeywell thermistor 135-104LAF-J01 (4.7k pullup)
// 8 is 100k 0603 SMD Vishay NTCS0603E3104FXT (4.7k pullup)
// 9 is 100k GE Sensing AL03006-58.2K-97-G1 (4.7k pullup)
// 10 is 100k RS thermistor 198-961 (4.7k pullup)
// 60 is 100k Maker's Tool Works Kapton Bed Thermister
// 1k ohm pullup tables - This is not normal, you would have to have changed out your 4.7k for 1k
// (but gives greater accuracy and more stable PID)
// 51 is 100k thermistor - EPCOS (1k pullup)
// 52 is 200k thermistor - ATC Semitec 204GT-2 (1k pullup)
// 55 is 100k thermistor - ATC Semitec 104GT-2 (Used in ParCan & J-Head) (1k pullup)
Grazie!
Re: Marlin e Heater Cartridge 12V/40W
March 23, 2014 01:51PM
Ciao quelli dovrebbero essere il setup dei sensori di temperatura, quello che hai acquistato รจ un riscaldatore da 12v 40w.
Prusa i2 arduino mega ramps 1.4 lcd marlin v1
March 23, 2014 04:13PM
Hai ragione! Sono un babbo! Grazie smiling smiley
March 24, 2014 04:26PM
Dai nessun problema ho fatto casini anche io all'inizio e continuo, infatti non riesco a far funzionare il display. mentre tutto il resto va. Arrrrgggg che rabbia.
