Identificare e Settare pins liberi su Ramp1.4 April 12, 2014 05:42PM |
in pratica volevo sapere se qualcuno di voi ha mai utilizzato queste funzioni e come si possono definire i pin evidenziati in rosso...Quote
//This is for controlling a fan to cool down the stepper drivers //it will turn on when any driver is enabled //and turn off after the set amount of seconds from last driver being disabled again #define CONTROLLERFAN_PIN -1 //Pin used for the fan to cool controller (-1 to disable) #define CONTROLLERFAN_SECS 60 //How many seconds, after all motors were disabled, the fan should run #define CONTROLLERFAN_SPEED 255 // == full speed // When first starting the main fan, run it at full speed for the // given number of milliseconds. This gets the fan spinning reliably // before setting a PWM value. (Does not work with software PWM for fan on Sanguinololu) #define FAN_KICKSTART_TIME 1000 // Extruder cooling fans // Configure fan pin outputs to automatically turn on/off when the associated // extruder temperature is above/below EXTRUDER_AUTO_FAN_TEMPERATURE. // Multiple extruders can be assigned to the same pin in which case // the fan will turn on when any selected extruder is above the threshold. #define EXTRUDER_0_AUTO_FAN_PIN -1 #define EXTRUDER_1_AUTO_FAN_PIN -1 #define EXTRUDER_2_AUTO_FAN_PIN -1 #define EXTRUDER_AUTO_FAN_TEMPERATURE 50 #define EXTRUDER_AUTO_FAN_SPEED 255 // == full speed
Re: Identificare e Settare pins liberi su Ramp1.4 April 13, 2014 01:58PM |
una guida su come si programmano i pin in Marlin la potresti fare
Re: Identificare e Settare pins liberi su Ramp1.4 April 13, 2014 06:11PM |
#if MOTHERBOARD == 33 || MOTHERBOARD == 35 #define FAN_PIN 4 // (Sprinter config) (Cambiato il 9 in 4) #else #define FAN_PIN 4 // IO pin. Buffer needed #endif
// Extruder cooling fans // Configure fan pin outputs to automatically turn on/off when the associated // extruder temperature is above/below EXTRUDER_AUTO_FAN_TEMPERATURE. // Multiple extruders can be assigned to the same pin in which case // the fan will turn on when any selected extruder is above the threshold. #define EXTRUDER_0_AUTO_FAN_PIN 5 #define EXTRUDER_1_AUTO_FAN_PIN -1 #define EXTRUDER_2_AUTO_FAN_PIN -1 #define EXTRUDER_AUTO_FAN_TEMPERATURE 50 #define EXTRUDER_AUTO_FAN_SPEED 255 // == full speed
Re: Identificare e Settare pins liberi su Ramp1.4 April 16, 2014 02:14PM |
Re: Identificare e Settare pins liberi su Ramp1.4 April 17, 2014 04:34PM |
Re: Identificare e Settare pins liberi su Ramp1.4 April 28, 2014 06:59PM |
#if MOTHERBOARD == 33 || MOTHERBOARD == 35 || MOTHERBOARD == 67 || MOTHERBOARD == 68
#define FAN_PIN 4 // EX 9 IO pin. Buffer needed
#else
#endif
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency // which is not ass annoying as with the hardware PWM. On the other hand, if this frequency // is too low, you should also increment SOFT_PWM_SCALE. #define FAN_SOFT_PWM
Re: Identificare e Settare pins liberi su Ramp1.4 April 30, 2014 03:33PM |
Re: Identificare e Settare pins liberi su Ramp1.4 June 11, 2015 05:28AM |
Re: Identificare e Settare pins liberi su Ramp1.4 June 28, 2015 11:48AM |
Re: Identificare e Settare pins liberi su Ramp1.4 June 28, 2015 11:51AM |
Re: Identificare e Settare pins liberi su Ramp1.4 August 10, 2015 05:15PM |
Re: Identificare e Settare pins liberi su Ramp1.4 July 31, 2019 05:15PM |
Re: Identificare e Settare pins liberi su Ramp1.4 August 02, 2019 01:37AM |
mattia952
...vorrei collegare la ventola per l'ugello della mia stampate al pin libero 11...
Re: Identificare e Settare pins liberi su Ramp1.4 August 02, 2019 03:42AM |
Re: Identificare e Settare pins liberi su Ramp1.4 August 02, 2019 04:12AM |
mattia952
...abilitando il "controllo servo" su quei pin ?
Re: Identificare e Settare pins liberi su Ramp1.4 August 02, 2019 11:32AM |
Re: Identificare e Settare pins liberi su Ramp1.4 August 03, 2019 11:03AM |
mattia952
...come hai fatto a settare le due ventole sui pin 4 e 5?
Re: Identificare e Settare pins liberi su Ramp1.4 August 04, 2019 05:37AM |
Re: Identificare e Settare pins liberi su Ramp1.4 August 05, 2019 01:31AM |
mattia952
Ok perfetto e per settarle cosa hai modificato nel firmware?
Re: Identificare e Settare pins liberi su Ramp1.4 August 05, 2019 02:24AM |
Re: Identificare e Settare pins liberi su Ramp1.4 August 05, 2019 06:07PM |
