avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. April 27, 2014 09:49AM |
Re: avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. April 27, 2014 10:08AM |
Google search
Problem:
Avrdude dislikes your lovely 328-PU chips and says "avrdude: Yikes! Invalid device signature." or "avrdude: Expected signature for ATMEGA328P is 1E 95 0F"
Soln:- This problem happens becoz ur arduino uses 328p - pu and if u bought 328pu(a couple dollars cheap).
The soln is to modify Arduino > hardware >tools>avr>etc and open avrdude.conf file as word document.keep backup of this file incase u mess up.
find 1E 95 0F text under Atmega328 and change it to 1E 95 14 and save.
restart arduino environment and burn bootloaders on all ur chips.use status leds as mogul said.they help a lot.
After burning change the text in avrdude.conf file back to 1E 95 0F and restart arduino ide.Then u can uplode code normally.
Re: avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. April 27, 2014 12:48PM |
Re: avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. April 27, 2014 02:00PM |
Re: avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. May 03, 2014 08:32AM |
Re: avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check. May 03, 2014 10:01AM |
