Abilitare lcd 12864 RIAPERTO May 11, 2014 01:40PM |
Re: Abilitare lcd 12864 May 11, 2014 02:23PM |
Re: Abilitare lcd 12864 May 11, 2014 02:38PM |
Re: Abilitare lcd 12864 May 11, 2014 02:45PM |
// This uses the LiquidCrystal_I2C library ( [bitbucket.org] ) // Make sure it is placed in the Arduino libraries directory.
Re: Abilitare lcd 12864 May 11, 2014 02:49PM |
Re: Abilitare lcd 12864 May 11, 2014 02:59PM |
Re: Abilitare lcd 12864 May 11, 2014 03:26PM |
//LCD and SD support //#define ULTRA_LCD //general LCD support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) //#define SDSUPPORT // Enable SD Card Support in Hardware ConsolePer esempio proverei il doglcd, visto che è un 128x64 come il tuo, oppure il normale:
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
Re: Abilitare lcd 12864 May 11, 2014 04:47PM |
//LCD and SD support #define ULTRA_LCD //general lcd support, also 16x2 #define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) #define SDSUPPORT // Enable SD Card Support in Hardware Console #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER //automatic expansion #if defined (REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER) #define DOGLCD #define U8GLIB_ST7920 #define REPRAP_DISCOUNT_SMART_CONTROLLER #endif #if defined(ULTIMAKERCONTROLLER) || defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL) #define ULTIPANEL #define NEWPANEL #endif #if defined(REPRAPWORLD_KEYPAD) #define NEWPANEL #define ULTIPANEL #endif #if defined(RA_CONTROL_PANEL) #define ULTIPANEL #define NEWPANEL #define LCD_I2C_TYPE_PCA8574 #define LCD_I2C_ADDRESS 0x27 // I2C Address of the port expander #endif Take away the // comment slashes on all of these statements, as shown above
Re: Abilitare lcd 12864 May 11, 2014 04:59PM |
Re: Abilitare lcd 12864 May 11, 2014 05:11PM |
Re: Abilitare lcd 12864 May 11, 2014 05:13PM |
Re: Abilitare lcd 12864 RIAPERTO May 12, 2014 04:53PM |
Re: Abilitare lcd 12864 RIAPERTO May 12, 2014 04:59PM |
Re: Abilitare lcd 12864 RIAPERTO May 12, 2014 05:07PM |
Re: Abilitare lcd 12864 RIAPERTO May 12, 2014 05:11PM |
xmarco69
Diodo D1 su ramps o su display? nel caso di display non ho jumper da muovere se non quello della luce che ho gia' spostato.
Grazie comunque per la risposta
Re: Abilitare lcd 12864 RIAPERTO May 14, 2014 01:03PM |
MagoKimbra
xmarco69
ramps. Lcd pur essendo attaccato alla ramps prende alimentazione da Arduino il quale si alimenta o tramite USB o tramite powerjack o tramite alimentazione che arriva dalla ramps con il diodo d1, che va messo solo se si usa alimentazione a 12v sulla ramps altrimenti si rompe arduino!!!
Re: Abilitare lcd 12864 RIAPERTO May 14, 2014 02:03PM |
xmarco69
MagoKimbra
xmarco69
Ciao ho guardato un altro tuo post dove elenchi come e' fatta una ramps: [forums.reprap.org] quindi se non ho capito male basta che ponticello il terzo pin (partendo da sx) di AUX1??? uso chiaramente un alimentatore da 12 volt.
Grazie
Re: Abilitare lcd 12864 RIAPERTO June 25, 2014 06:52PM |
Re: Abilitare lcd 12864 RIAPERTO June 28, 2014 04:01AM |
Re: Abilitare lcd 12864 June 29, 2014 01:41PM |
Re: Abilitare lcd 12864 June 29, 2014 03:41PM |
Re: Abilitare lcd 12864 June 29, 2014 04:09PM |
Re: Abilitare lcd 12864 June 29, 2014 04:53PM |
Re: Abilitare lcd 12864 June 30, 2014 08:26AM |
Re: Abilitare lcd 12864 June 30, 2014 08:30AM |
Re: Abilitare lcd 12864 June 30, 2014 08:42AM |
Re: Abilitare lcd 12864 June 30, 2014 09:48AM |
Galeots
Ho provato ha invertire i cavi ma niente le librerie ci sono e la mia scheda è una rambo merlin aggiornato al 1.2.
il mio lcd [www.ebay.it]
Re: Abilitare lcd 12864 RIAPERTO June 30, 2014 10:20AM |
Re: Abilitare lcd 12864 RIAPERTO June 30, 2014 10:23AM |
Re: Abilitare lcd 12864 RIAPERTO July 07, 2014 05:11AM |
//LCD and SD support #define ULTRA_LCD //general LCD support, also 16x2 #define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) #define SDSUPPORT // Enable SD Card Support in Hardware Console #define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) #define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder #define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking //#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store. //#define ULTIPANEL //the UltiPanel as on Thingiverse #define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click #define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org] //#define MAKRPANEL // The RepRapDiscount Smart Controller (white PC // [reprap.org] //#define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC // [reprap.org] //#define G3D_PANEL // The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC // [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER // The RepRapWorld REPRAPWORLD_KEYPAD v1.1 // [reprapworld.com] //#define REPRAPWORLD_KEYPAD //#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click // The Elefu RA Board Control Panel // [www.elefu.com] // REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARUDINO library folder: [github.com] //#define RA_CONTROL_PANEL
