Re: Marlin rivisitato per più estrusori e singolo hotend September 07, 2014 04:34PM |
Re: Marlin rivisitato per più estrusori e singolo hotend September 17, 2014 06:16PM |
codice normale.... G60 ; memorizzo posizione G1 X20 Y0 Z1 F8000 ; mi sposto fuori G1 E-100 ;retract T2 ;cambio estrusore G1 E100 ; carico il nuovo filo G1 E150 ; Spurgo G1 Y20 Z20 ; taglio il fio sul piatto G61 X Y Z F6000 ; torno sul punto di stampa per continuare
Re: Marlin rivisitato per più estrusori e singolo hotend September 18, 2014 03:15AM |
Moderator Registered: 11 years ago Posts: 1,865 |
Re: Marlin rivisitato per più estrusori e singolo hotend September 18, 2014 10:29AM |
Re: Marlin rivisitato per più estrusori e singolo hotend October 12, 2014 09:09AM |
/***********************************************************************\ **************************** Define type printer ********************** ***********************************************************************/ #define CARTESIAN //#define COREXY //#define DELTA //#define SCARA
#ifndef MOTHERBOARD #define MOTHERBOARD 33 #endif
// This defines the number of Driver extruders #define DRIVER_EXTRUDERS 1 // This defines the number of extruder real or virtual #define EXTRUDERS 1
#if EXTRUDERS > 1 #define SINGLENOZZLE //This is used for singlenozzled multiple extrusion configuration #endif
/*********************************************************************** *********************** Multiextruder MKR4 *************************** *********************************************************************** * * * Setting for more extruder width rele system * * * * Firmware by MagoKimbra magokimbra@hotmail.com * * * * See pins.h for pin command rele * * * ***********************************************************************/ //#define MKR4 #ifdef MKR4 #define DELAY_R 500 // Delay for switch rele #endif // END MKR4 //**********************************************************************
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,3200,625,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit #define DEFAULT_MAX_FEEDRATE {300,300,2,100,100,100,100} // X, Y, Z, E0, E1, E2, E3 (mm/sec) #define DEFAULT_RETRACTION_MAX_FEEDRATE {110,110,110,110} // E0, E1, E2, E3 (mm/sec)
Re: MarlinKimbra October 27, 2014 06:28PM |
Re: MarlinKimbra November 05, 2014 03:37AM |
Re: MarlinKimbra November 05, 2014 03:50AM |
Re: MarlinKimbra November 05, 2014 06:20AM |
Re: MarlinKimbra November 05, 2014 06:42AM |
Re: MarlinKimbra November 05, 2014 03:23PM |
Re: MarlinKimbra November 06, 2014 03:38AM |
Re: MarlinKimbra November 06, 2014 03:58AM |
Re: MarlinKimbra November 06, 2014 04:36AM |
Re: MarlinKimbra November 06, 2014 05:16AM |
Re: MarlinKimbra November 06, 2014 05:35AM |
Re: MarlinKimbra November 06, 2014 05:48AM |
Re: MarlinKimbra November 06, 2014 01:38PM |
Re: MarlinKimbra November 07, 2014 05:47AM |
Re: MarlinKimbra November 10, 2014 05:55PM |
Re: MarlinKimbra November 10, 2014 06:00PM |
Re: MarlinKimbra November 10, 2014 06:15PM |
Re: MarlinKimbra November 13, 2014 11:00AM |
Re: MarlinKimbra November 14, 2014 05:43AM |
#define LASERBEAM
Re: MarlinKimbra November 16, 2014 12:27PM |
Re: MarlinKimbra November 23, 2014 07:17PM |
//#define FIRMWARE_TESTUsate 115200 baudrate e il monitor seriale di arduino.
Re: MarlinKimbra November 24, 2014 01:28PM |
Re: MarlinKimbra November 24, 2014 05:00PM |
Re: MarlinKimbra November 25, 2014 07:23AM |
3ntrlab
#include "complimenti@valanga"
#if (TI_AVANZA_TEMPO = true)
think_about (SET_PID_PARM_OR_BBANG(extuder_no))
#endif
Davide
Re: MarlinKimbra November 25, 2014 08:15AM |
