Problema auto livellamento [Risolto] July 04, 2014 06:00AM |
//============================= Bed Auto Leveling ===========================
#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line)
#ifdef ENABLE_AUTO_BED_LEVELING
// There are 2 different ways to pick the X and Y locations to probe:
// - "grid" mode
// Probe every point in a rectangular grid
// You must specify the rectangle, and the density of sample points
// This mode is preferred because there are more measurements.
// It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive
// - "3-point" mode
// Probe 3 arbitrary points on the bed (that aren't colinear)
// You must specify the X & Y coordinates of all 3 points
//#define AUTO_BED_LEVELING_GRID
// with AUTO_BED_LEVELING_GRID, the bed is sampled in a
// AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid
// and least squares solution is calculated
// Note: this feature occupies 10'206 byte
#ifdef AUTO_BED_LEVELING_GRID
// set the rectangle in which to probe
#define LEFT_PROBE_BED_POSITION 15
#define RIGHT_PROBE_BED_POSITION 170
#define BACK_PROBE_BED_POSITION 180
#define FRONT_PROBE_BED_POSITION 20
// set the number of grid points per dimension
// I wouldn't see a reason to go above 3 (=9 probing points on the bed)
#define AUTO_BED_LEVELING_GRID_POINTS 2
#else // not AUTO_BED_LEVELING_GRID
// with no grid, just probe 3 arbitrary points. A simple cross-product
// is used to esimate the plane of the print bed
#define ABL_PROBE_PT_1_X 209.1
#define ABL_PROBE_PT_1_Y 188.5
#define ABL_PROBE_PT_2_X 29.1
#define ABL_PROBE_PT_2_Y 188.5
#define ABL_PROBE_PT_3_X 29.1
#define ABL_PROBE_PT_3_Y 0
#endif // AUTO_BED_LEVELING_GRID
// these are the offsets to the probe relative to the extruder tip (Hotend - Probe)
#define X_PROBE_OFFSET_FROM_EXTRUDER -10.9
#define Y_PROBE_OFFSET_FROM_EXTRUDER 48.5
#define Z_PROBE_OFFSET_FROM_EXTRUDER -0.5
#define Z_RAISE_BEFORE_HOMING 4 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min
#define Z_RAISE_BEFORE_PROBING 15 //How much the extruder will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when traveling from between next probing points
//If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk
//The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it.
// You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile.
#define PROBE_SERVO_DEACTIVATION_DELAY 1000//
//If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing,
//it is highly recommended you let this Z_SAFE_HOMING enabled!!!
#define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area.
// When defined, it will:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled
// - If stepper drivers timeout, it will need X and Y homing again before Z homing
// - Position the probe in a defined XY point before Z Homing when homing all axis (G28)
// - Block Z homing only when the probe is outside bed area.
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
#endif
#endif // ENABLE_AUTO_BED_LEVELING
Re: Problema auto livellamento July 04, 2014 06:19AM |
Re: Problema auto livellamento July 04, 2014 11:38AM |
// these are the offsets to the probe relative to the extruder tip (Hotend - Probe) #define X_PROBE_OFFSET_FROM_EXTRUDER -5 #define Y_PROBE_OFFSET_FROM_EXTRUDER 47.4 #define Z_PROBE_OFFSET_FROM_EXTRUDER -14.2
Re: Problema auto livellamento July 04, 2014 12:04PM |
Re: Problema auto livellamento July 04, 2014 12:30PM |
Re: Problema auto livellamento July 05, 2014 04:32AM |
Re: Problema auto livellamento July 06, 2014 01:50PM |
Re: Problema auto livellamento July 06, 2014 01:56PM |
Re: Problema auto livellamento July 06, 2014 01:59PM |
Re: Problema auto livellamento July 07, 2014 03:52AM |
Re: Problema auto livellamento July 07, 2014 05:23AM |
#define Z_RAISE_BEFORE_HOMING 5 // (in mm) Raise Z before homing (G28) for Probe Clearance. #define Z_RAISE_BEFORE_PROBING 15
Re: Problema auto livellamento July 07, 2014 10:23AM |
Re: Problema auto livellamento July 07, 2014 10:48AM |
Re: Problema auto livellamento July 07, 2014 11:38AM |
#define Z_RAISE_BEFORE_HOMING 30 // (in mm) Raise Z before homing (G28) for Probe Clearance.
#define Z_RAISE_BEFORE_PROBING 30 //How much the extruder will be raised before traveling to the first probing point.
Re: Problema auto livellamento July 07, 2014 11:56AM |
Re: Problema auto livellamento July 07, 2014 12:35PM |
Re: Problema auto livellamento July 08, 2014 05:20AM |
Re: Problema auto livellamento July 08, 2014 05:21AM |
Re: Problema auto livellamento July 08, 2014 05:25AM |
Re: Problema auto livellamento July 08, 2014 06:14AM |
Re: Problema auto livellamento July 08, 2014 06:38AM |
#define EEPROM_SETTINGS
Re: Problema auto livellamento July 08, 2014 08:07AM |
Re: Problema auto livellamento July 08, 2014 08:09AM |
Re: Problema auto livellamento [Risolto] August 26, 2014 07:13AM |
Re: Problema auto livellamento [Risolto] August 31, 2014 11:14AM |
