Repetier -Server su Raspeberry PI October 17, 2014 05:29AM |
Re: Repetier -Server su Raspeberry PI October 17, 2014 05:46AM |
Re: Repetier -Server su Raspeberry PI October 17, 2014 05:52AM |
Moderator Registered: 12 years ago Posts: 1,865 |
Re: Repetier -Server su Raspeberry PI October 17, 2014 05:56AM |
enricodare
caspita, 24° in casa, stai ancora in maniche corte :-)
Re: Repetier -Server su Raspeberry PI October 18, 2014 09:06AM |
Re: Repetier -Server su Raspeberry PI October 18, 2014 01:26PM |
Re: Repetier -Server su Raspeberry PI October 18, 2014 02:25PM |
Re: Repetier -Server su Raspeberry PI October 18, 2014 06:52PM |
Re: Repetier -Server su Raspeberry PI October 19, 2014 02:47AM |
Re: Repetier -Server su Raspeberry PI October 19, 2014 04:08AM |
Re: Repetier -Server su Raspeberry PI October 19, 2014 04:32AM |
Re: Repetier -Server su Raspeberry PI October 19, 2014 04:41AM |
Re: Repetier -Server su Raspeberry PI October 19, 2014 07:38AM |
system: actions: - action: printer off command: gpio mode 7 in confirm: You are about to turn off the printer. name: Turn off printer
Re: Repetier -Server su Raspeberry PI October 19, 2014 08:14AM |
- action: luce on command: gpio -g mode 24 out name: luce on - action: luce off command: gpio -g mode 24 in name: luce off - action: alimentore on command: gpio -g mode 23 out name: alimentore on - action: alimentore off command: gpio -g mode 23 in confirm: Stai per spegnere l'alimentatore. name: alimentatore off
Re: Repetier -Server su Raspeberry PI October 19, 2014 06:42PM |
Re: Repetier -Server su Raspeberry PI October 20, 2014 05:52AM |
Re: Repetier -Server su Raspeberry PI October 20, 2014 06:14AM |
Re: Repetier -Server su Raspeberry PI October 20, 2014 11:08AM |
Re: Repetier -Server su Raspeberry PI October 21, 2014 01:07PM |
Re: Repetier -Server su Raspeberry PI October 22, 2014 11:57AM |
grazie per la segnalazioneQuote
yaki
Ciao
mi aggrego, discussione molto interessante
ho appena letto di questo, con supporto per piu stampanti
[diy3dprinting.blogspot.it]
[xyzbots.com] anche controller cnc
[github.com]
Re: Repetier -Server su Raspeberry PI December 14, 2014 04:48PM |
Changing monitoring state from 'Offline' to 'Opening serial port' Connecting to: /dev/ttyAMA0 Connected to: Serial(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=17.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor Changing monitoring state from 'Opening serial port' to 'Connecting' Connection closed, closing down monitorGrazie a chi mi aiuterà
Re: Repetier -Server su Raspeberry PI January 30, 2015 11:28AM |
Re: Repetier -Server su Raspeberry PI February 07, 2015 04:49PM |
Re: Repetier -Server su Raspeberry PI February 07, 2015 08:40PM |
Re: Repetier -Server su Raspeberry PI February 08, 2015 07:32PM |
Re: Repetier -Server su Raspeberry PI February 09, 2015 03:06AM |
Re: Repetier -Server su Raspeberry PI February 17, 2015 07:56AM |
Interessante come cosa ho letto un po la discussione alla fine tra i vari sistemi quale conviene ?Quote
MagoKimbra
Repetier Server su una Raspberry Pi...
Se volete posso scrivere una guida, ma solo se c'è interesse perché lunghetta come cosa, ma non difficilissima, bisogna solo prestare un pò d'attenzione
Scusa ma usando un NoIp o DNDNS o simili e nattando il mac della scheda WiFi del Pi non lo si risolve questo problema ?Quote
MagoKimbra
N.B. Io non ho un ip pubblico statico, quindi alla prossima accensione del modem questo link non sarà più valido..
Re: Repetier -Server su Raspeberry PI February 18, 2015 03:16AM |
Re: Repetier -Server su Raspeberry PI February 18, 2015 08:07AM |
Re: Repetier -Server su Raspeberry PI February 18, 2015 08:13AM |
Grazie della dritta ora ho un Modulo BT sulla ramps ma a parte che sul fisso non mi va in granche beneQuote
3ntrlab
I crash su raspberry+octoprint sono fondamentalmente dovuti a due fattori:
1) SD card troppo lenta. Il minimo sindacale e' una class 6. OCIO che ci sono in giro una infinita' di sd tarocche....
2) Timeout seriali troppo corti.
Per il resto uso octoprint con crescente soddisfazione
