tempo stimato cura con repetier host October 30, 2014 02:36PM |
Re: tempo stimato cura con repetier host November 07, 2014 04:51AM |
Re: tempo stimato cura con repetier host November 07, 2014 05:03AM |
Re: tempo stimato cura con repetier host November 07, 2014 05:28AM |
Re: tempo stimato cura con repetier host November 07, 2014 07:39AM |
Re: tempo stimato cura con repetier host November 07, 2014 07:59AM |
Re: tempo stimato cura con repetier host November 19, 2014 01:16PM |
Re: tempo stimato cura con repetier host November 20, 2014 08:49AM |
Re: tempo stimato cura con repetier host May 01, 2015 05:41PM |
Re: tempo stimato cura con repetier host May 02, 2015 11:38AM |
; Default R2 start code ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} ;Print time: {print_time} ;Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M109 S{print_temperature} ;Uncomment to add your own temperature line M80 G21 ;metric values M82 ;set extruder to absolute mode M107 ;start with the fan off G90 ;absolute positioning G28 ;move to min endstops G1 Z15 F{Z_TRAVEL_SPEED} G90 ; Absolute positioning M82 ; Extruder in absolute mode ; Activate all used extruder {IF_EXT0}M104 T0 S{TEMP0} G92 E0 ; Reset extruder position ; Wait for all used extruders to reach temperature {IF_EXT0}M109 T0 S{TEMP0} G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 Stampa in corso ...
; Default R2 end code M107 ; Turn off fan ; Disable all extruder G91 ; Relative positioning G1 Z+5 ; Lift nozzle {IF_EXT0}T0 {IF_EXT0}G1 E-1 F300 ; Reduce filament pressure M104 T0 S0 G90 ; Absolute positioning G1 X-40 Y220 F8000 ; Get extruder out of way. G92 E0 ; Reset extruder position M140 S0 ; Disable heated bed G04 F10 M81 ; Turn Off R2
Re: tempo stimato cura con repetier host May 02, 2015 11:48AM |
Re: tempo stimato cura con repetier host May 02, 2015 11:52AM |
bilanciamist
Penso che possa esserci un comando che Cura non digerisce.
Re: tempo stimato cura con repetier host May 02, 2015 01:59PM |
Re: tempo stimato cura con repetier host March 21, 2016 09:49AM |
