Re: Commenti e modifiche per la guida al setup MarlinKimbra January 06, 2015 08:58AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 06, 2015 09:12AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 06, 2015 09:18AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 07, 2015 12:21PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 07, 2015 01:17PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 07, 2015 01:41PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 21, 2015 08:08PM |
"motherboards": "BOARD_RAMPS_13_EFB",
#if MB(RAMPS_13_EFB ) || MB(RAMPS_13_EFF) || MB(AZTEEG_X3) || MB(AZTEEG_X3_PRO) #define ORIG_FAN_PIN 9 // 9 (Sprinter config) #else
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 21, 2015 08:46PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 22, 2015 02:21AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 22, 2015 03:04AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 22, 2015 03:32AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 22, 2015 05:18AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 22, 2015 05:42AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 22, 2015 08:09PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 23, 2015 02:48AM |
supermonte
si ma per esempio i driver toshiba li perde...
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 24, 2015 03:21PM |
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins. const bool X_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool E_MIN_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool X_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Y_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. const bool Z_MAX_ENDSTOP_INVERTING = true; // set to true to invert the logic of the endstop. //#define DISABLE_MAX_ENDSTOPS //#define DISABLE_MIN_ENDSTOPS // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruders // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruders #define DISABLE_INACTIVE_EXTRUDER false //disable only inactive extruders and keep active extruder enabled #define INVERT_X_DIR true // for Mendel set to false, for Orca set to true #define INVERT_Y_DIR true // for Mendel set to true, for Orca set to false #define INVERT_Z_DIR false // for Mendel set to false, for Orca set to true #define INVERT_E0_DIR true // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E1_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E2_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false #define INVERT_E3_DIR false // for direct drive extruder v9 set to true, for geared extruder set to false // ENDSTOP SETTINGS: // Sets direction of endstops when homing; 1=MAX, -1=MIN #define X_HOME_DIR 1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define E_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // Travel limits after homing #define X_MAX_POS 190 #define X_MIN_POS 0 #define Y_MAX_POS 190 #define Y_MIN_POS 0 #define Z_MAX_POS 190 #define Z_MIN_POS 0 #define E_MIN_POS 0
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 24, 2015 05:56PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 25, 2015 06:27AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 25, 2015 07:07AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 25, 2015 08:11AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra January 25, 2015 08:46AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra February 16, 2015 09:39AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra February 16, 2015 02:12PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra February 16, 2015 03:37PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra February 18, 2015 07:28AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra February 18, 2015 08:03AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra February 18, 2015 09:51AM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra February 20, 2015 05:35PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra March 10, 2015 03:23PM |
Re: Commenti e modifiche per la guida al setup MarlinKimbra March 11, 2015 07:19AM |
Arduino: 1.0.6 (Windows NT (unknown)), Board: "Arduino Mega 2560 or Mega ADK" D:\arduino-1.0.6\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -ID:\arduino-1.0.6\hardware\arduino\cores\arduino -ID:\arduino-1.0.6\hardware\arduino\variants\mega -ID:\arduino-1.0.6\libraries\Wire -IC:\Users\mario_000\Documents\Arduino\libraries\U8glib -ID:\arduino-1.0.6\libraries\LiquidCrystal -ID:\arduino-1.0.6\libraries\SPI C:\Users\MARIO_~1\AppData\Local\Temp\build2287097810838138022.tmp\BlinkM.cpp -o C:\Users\MARIO_~1\AppData\Local\Temp\build2287097810838138022.tmp\BlinkM.cpp.o In file included from /Marlin.h:23, from BlinkM.cpp:5: /pins.h:4369:1: warning: "/*" within comment /pins.h:4378:1: warning: "/*" within comment D:\arduino-1.0.6\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega2560 -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -ID:\arduino-1.0.6\hardware\arduino\cores\arduino -ID:\arduino-1.0.6\hardware\arduino\variants\mega -ID:\arduino-1.0.6\libraries\Wire -IC:\Users\mario_000\Documents\Arduino\libraries\U8glib -ID:\arduino-1.0.6\libraries\LiquidCrystal -ID:\arduino-1.0.6\libraries\SPI C:\Users\MARIO_~1\AppData\Local\Temp\build2287097810838138022.tmp\cardreader.cpp -o C:\Users\MARIO_~1\AppData\Local\Temp\build2287097810838138022.tmp\cardreader.cpp.o In file included from /Marlin.h:23, from cardreader.cpp:1: /pins.h:4369:1: warning: "/*" within comment /pins.h:4378:1: warning: "/*" within comment In file included from cardreader.cpp:6: /language.h:52:1: warning: "MACHINE_NAME" redefined /language.h:48:1: warning: this is the location of the previous definition In file included from /language.h:264, from cardreader.cpp:6: /language_it.h:52:1: warning: "MSG_MIN" redefined In file included from cardreader.cpp:6: /language.h:162:1: warning: this is the location of the previous definition In file included from /language.h:264, from cardreader.cpp:6: /language_it.h:53:1: warning: "MSG_MAX" redefined In file included from cardreader.cpp:6: /language.h:163:1: warning: this is the location of the previous definition ........... Marlin_main.cpp:4649: error: 'PAUSE_PIN_INVERTING' was not declared in this scope Marlin_main.cpp:4734: warning: only initialized variables can be placed into program memory area Marlin_main.cpp:4762: warning: unused variable 'area' Marlin_main.cpp:5075: warning: only initialized variables can be placed into program memory area Marlin_main.cpp:5616: warning: unused variable 'csteps' Marlin_main.cpp:5835: warning: only initialized variables can be placed into program memory area Marlin_main.cpp:5837: warning: only initialized variables can be placed into program memory area Marlin_main.cpp:3933: warning: unused variable 'codenum' Marlin_main.cpp: In function 'void FlushSerialRequestResend()': Marlin_main.cpp:5846: warning: only initialized variables can be placed into program memory area Marlin_main.cpp: In function 'void ClearToSend()': Marlin_main.cpp:5857: warning: only initialized variables can be placed into program memory area Marlin_main.cpp: In function 'void kill()': Marlin_main.cpp:6383: warning: only initialized variables can be placed into program memory area Marlin_main.cpp:6384: warning: only initialized variables can be placed into program memory area Marlin_main.cpp: In function 'void pause()': Marlin_main.cpp:6400: error: 'PAUSE_PIN_INVERTING' was not declared in this scope Marlin_main.cpp:6403: warning: only initialized variables can be placed into program memory area Marlin_main.cpp: In function 'void Stop()': Marlin_main.cpp:6416: warning: only initialized variables can be placed into program memory area Marlin_main.cpp:6417: warning: only initialized variables can be placed into program memory area /ultralcd.h: At global scope: /ultralcd.h:22: warning: 'blink' defined but not used
