Commenti e modifiche al MarlinKimbra firmware setup online December 11, 2014 08:06AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 11, 2014 09:31AM |
Moderator Registered: 11 years ago Posts: 1,865 |
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 12, 2014 05:23PM |
#define ORIG_X_STEP_PIN 54 #define ORIG_X_DIR_PIN 55 #define ORIG_X_ENABLE_PIN 38 #define ORIG_X_MIN_PIN 3 #define ORIG_X_MAX_PIN 2 #define ORIG_Y_STEP_PIN 60 #define ORIG_Y_DIR_PIN 61 #define ORIG_Y_ENABLE_PIN 56 #define ORIG_Y_MIN_PIN 14 #define ORIG_Y_MAX_PIN 15 #define ORIG_Z_STEP_PIN 46 #define ORIG_Z_DIR_PIN 48 #define ORIG_Z_ENABLE_PIN 62 #define ORIG_Z_MIN_PIN 18 #define ORIG_Z_MAX_PIN 19 #define ORIG_E0_STEP_PIN 26 #define ORIG_E0_DIR_PIN 28 #define ORIG_E0_ENABLE_PIN 24 #define ORIG_E1_STEP_PIN 36 #define ORIG_E1_DIR_PIN 34 #define ORIG_E1_ENABLE_PIN 30Questi sono i valori di default di una comunissima ramps 1,4. A fine file pins.h troviamo:
// Original pin assignmats to be used in configuration tool #define X_STEP_PIN ORIG_X_STEP_PIN #define X_DIR_PIN ORIG_X_DIR_PIN #define X_ENABLE_PIN ORIG_X_ENABLE_PIN #define X_MIN_PIN ORIG_X_MIN_PIN #define X_MAX_PIN ORIG_X_MAX_PIN #define Y_STEP_PIN ORIG_Y_STEP_PIN #define Y_DIR_PIN ORIG_Y_DIR_PIN #define Y_ENABLE_PIN ORIG_Y_ENABLE_PIN #define Y_MIN_PIN ORIG_Y_MIN_PIN #define Y_MAX_PIN ORIG_Y_MAX_PIN #define Z_STEP_PIN ORIG_Z_STEP_PIN #define Z_DIR_PIN ORIG_Z_DIR_PIN #define Z_ENABLE_PIN ORIG_Z_ENABLE_PIN #define Z_MIN_PIN ORIG_Z_MIN_PIN #define Z_MAX_PIN ORIG_Z_MAX_PIN #define E0_STEP_PIN ORIG_E0_STEP_PIN #define E0_DIR_PIN ORIG_E0_DIR_PIN #define E0_ENABLE_PIN ORIG_E0_ENABLE_PIN #if DRIVER_EXTRUDERS > 1 #define E1_STEP_PIN ORIG_E1_STEP_PIN #define E1_DIR_PIN ORIG_E1_DIR_PIN #define E1_ENABLE_PIN ORIG_E1_ENABLE_PINIn questo modo ho i pin,che poi verranno usati dal fw, uguali a quelli di default. Ma a che serve tutto ciò? Semplice ora nel file configuration_tipodistampante.h all'inizio possiamo aggiungere queste definizioni come meglio crediamo.
#define X_STEP_PIN ORIG_E1_STEP_PIN #define X_DIR_PIN ORIG_E1_DIR_PIN #define X_ENABLE_PIN ORIG_E1_ENABLE_PINCompiliamo e mandiamo alla scheda. Il momento che voglio ripristinare tutto come prima, basta che cancello queste linee e tutto torna come default.
#define X_STEP_PIN ORIG_E1_STEP_PIN #define X_DIR_PIN ORIG_E1_DIR_PIN #define X_ENABLE_PIN ORIG_E1_ENABLE_PIN // Define this to set a custom name for your generic Mendel, #define CUSTOM_MENDEL_NAME "Prusa I3" // Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines) // You can use an online service to generate a random UUID. (eg [www.uuidgenerator.net]) // #define MACHINE_UUID "00000000-0000-0000-0000-000000000000" //=========================================================================== //=============================Mechanical Settings=========================== //=========================================================================== // coarse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #ifndef ENDSTOPPULLUPS // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined // #define ENDSTOPPULLUP_XMAX // #define ENDSTOPPULLUP_YMAX // #define ENDSTOPPULLUP_ZMAX // #define ENDSTOPPULLUP_XMIN // #define ENDSTOPPULLUP_YMIN // #define ENDSTOPPULLUP_ZMIN // #define ENDSTOPPULLUP_EMIN #endif #ifdef ENDSTOPPULLUPS #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN #define ENDSTOPPULLUP_ZMIN #define ENDSTOPPULLUP_EMIN #endif .........
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 16, 2014 10:19AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 16, 2014 11:17AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 16, 2014 01:18PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 17, 2014 09:37AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 17, 2014 11:19AM |
errore in compilazione:Quote
MagoKimbra
Vai Maralb tutto tuo con la versione delta!!!
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 17, 2014 11:44AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 17, 2014 11:57AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online December 27, 2014 07:52PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online January 09, 2015 01:40PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online January 10, 2015 02:24PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online January 10, 2015 06:39PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online January 11, 2015 08:54AM |
// Show a progress bar on HD44780 LCDs for SD printing #define LCD_PROGRESS_BAR
ultralcd.cpp: In function 'void lcd_goto_menu(void (*)(), uint32_t, bool)': ultralcd.cpp:207: error: 'lcd_set_custom_characters' was not declared in this scope ultralcd.cpp: In function 'void lcd_status_screen()': ultralcd.cpp:218: error: 'progressBarTick' was not declared in this scope
Re: Commenti e modifiche al MarlinKimbra firmware setup online January 11, 2015 09:46AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online January 11, 2015 01:22PM |
MagoKimbra
Qbert25 se allegavi il fw potevo dargli una controllata, cosi a occhio i problemi sono: arduino ide vecchio, monta 1.0.6 e qualcosa di strano con le librerie U8glib... Le hai correttamente installate???
Re: Commenti e modifiche al MarlinKimbra firmware setup online January 11, 2015 01:50PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online January 17, 2015 04:29PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online April 25, 2015 05:40AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online April 25, 2015 07:08AM |
// Same again but for Y Axis. //#define Y_DUAL_STEPPER_DRIVERSe avere i pin giustamente settati per Y2...
Re: Commenti e modifiche al MarlinKimbra firmware setup online May 04, 2015 06:55PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online May 14, 2015 01:48PM |
operator '&&' has no right operand
Re: Commenti e modifiche al MarlinKimbra firmware setup online May 14, 2015 06:10PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online June 05, 2015 04:49PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online June 06, 2015 03:35PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online June 09, 2015 04:39PM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online June 12, 2015 08:29AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online June 12, 2015 09:51AM |
Re: Commenti e modifiche al MarlinKimbra firmware setup online June 12, 2015 11:26AM |
