modifica posizione estrusore in fase di livellamento piano March 12, 2015 08:31PM |
Re: modifica posizione estrusore in fase di livellamento piano March 13, 2015 03:23AM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 02:56PM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 03:16PM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 03:59PM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 04:17PM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 04:19PM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 04:25PM |
case 700: // Script for level the build plate going to 3 points { SERIAL_ECHOLN(" --LEVEL PLATE SCRIPT--"); set_ChangeScreen(true); while(!lcd_clicked()){ set_pageShowInfo(0); lcd_update(); } set_pageShowInfo(1); set_ChangeScreen(true);
// prob 1 do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS+10); #if X_MAX_POS > 250 do_blocking_move_to((X_MAX_POS-X_MIN_POS)/2,Y_MAX_POS-10, current_position[Z_AXIS]); #else do_blocking_move_to(20, 190, current_position[Z_AXIS]); #endif do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS], Z_MIN_POS); while(!lcd_clicked()){ manage_heater(); } set_ChangeScreen(true); set_pageShowInfo(2); do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS+10); #if X_MAX_POS > 250 do_blocking_move_to(90, 5, current_position[Z_AXIS]); #else do_blocking_move_to(195, 190, current_position[Z_AXIS]); #endif do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS); while(!lcd_clicked()){ manage_heater(); manage_inactivity(); } set_ChangeScreen(true); set_pageShowInfo(3); do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS+10); #if X_MAX_POS > 250 do_blocking_move_to(205, 5, current_position[Z_AXIS]); #else do_blocking_move_to(20, 20, current_position[Z_AXIS]); #endif do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS); while(!lcd_clicked()){ manage_heater(); manage_inactivity(); } #if X_MAX_POS < 250 set_ChangeScreen(true); set_pageShowInfo(4); do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS+10); do_blocking_move_to(195, 20, current_position[Z_AXIS]); do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS); while(!lcd_clicked()){ manage_heater(); manage_inactivity(); } #endif set_ChangeScreen(true); set_pageShowInfo(5); do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS+10); #if X_MAX_POS > 250 do_blocking_move_to(150, 105, current_position[Z_AXIS]); #else do_blocking_move_to((X_MAX_POS-X_MIN_POS)/2, (Y_MAX_POS-Y_MIN_POS)/2, current_position[Z_AXIS]); #endif do_blocking_move_to(current_position[X_AXIS], current_position[Y_AXIS],Z_MIN_POS);
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 05:02PM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 05:08PM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 05:56PM |
Re: modifica posizione estrusore in fase di livellamento piano March 16, 2015 06:13PM |
